Results 1 to 10 of 10
    Reputation: Ufdah's Avatar
    Sep 2012
    140 or 150mm Pike on Spider 29 Comp?
    I'm planning to get a Intense Spider 29 Comp as my main bike complimenting my rigid SS and would like your input. I live in Durango, CO and do a LOT of climbing followed by some great downhill. What size fork do you think would be best and why?
    i am nearly in the same situation.--->Swiss Alps....
    sounds like a DPA is perfect for you!
    i go for a 130mm(Revelation) in case of my "hobbitlike" Body... ;-)
    (lower a/c, cheaper, and stiff enough for me)
    yesss... currently my Spider is over the Atlantic.... :-)
    Reputation: bholwell's Avatar
    Oct 2007
    I'd probably err on the side of caution and go with a 140mm Pike. The 150 should result in a HTA of around 67 degrees; getting pretty slack if you have any considerably steep climbs.
    Tire Design & Development Engineer. The opinions expressed in this forum are solely my own.
    Dec 2005
    I would go for the 140mm. About the same axle to crown height as my 130mm Fox 34 Float on my Spider Comp. Handling is spot on. Make sure you get the 51mm offset pike as well.
    Sep 2012
    Thanks guys! 140mm w/ 51mm offset it is! I appreciate the feedback!
    I am also looking at the Pike but I am more interested with the 150/120 dual position. I am trying to decide if I should go with a Fox 32 Float 120 or go with the Pike dual position.
    If ever I will go with the Pike, most of the time it will be on the 120 setting. Any help is greatly appreciated.
    Oct 2007
    Quote Originally Posted by dromayn View Post
    Unless you're a clyde, I think you'd be happier with a Dual Position Revelation instead of a Pike. You'd be hauling around less weight that you don't need most of the time.
    Fox forks are nice, but in my experience they require more maintenance, and they have poorer small bump compliance. The Rock Shox forks just feel smoother. And there are reportedly issues with some of the 2013 Fox dampers.
    I just replaced my 2012 Fox 34 with a 140mm Pike; can't wait to get it on the trail.
    squish, squish in da fish
    Reputation: fishwrinkle's Avatar
    sorry to derail the thread a little, but i was under the impression the pike was internally adjustable, no?
    ...actually building up my Size "S" Spider.
    As written before, i am no Clydesdale and picked up a black matte Revelation 2014 130mm. 1810g out of the Box, with uncut steerer and Maxle Lite....
    Try do pimp it up with some custom decals like this....
    Reputation: simenf's Avatar
    Nov 2008
    Nice bike and fork. Good match.
    simenf - brainwashed by the big wheel mafia.
  1. Fox 34 float 29 CTD 150mm or Rockshox Pike 29 150mm
    By mo6500 in forum 29er Components
    Last Post: 05-12-2014, 05:06 AM
  2. Pike 150mm on SB95c?
    By Streetdoctor in forum Yeti
    Last Post: 12-31-2013, 08:02 PM
  3. Rip 9 RDO with 150mm Rockshox Pike
    By Colin+M in forum Niner Bikes
    Last Post: 07-12-2013, 07:24 AM
  4. 150mm Pike and the RIP9 RDO ?
    Last Post: 05-22-2013, 07:52 PM
  5. 150mm Pike?
    By Warp in forum Shocks and Suspension
    Last Post: 02-15-2012, 04:21 PM
