Results 1 to 9 of 9
    Jul 2013
    100mm forks vs 120mm forks ?????
    I have a set of 100mm forks and Id like to swap them out for a set of 120mm forks.
    So my questions is. Will this change the way the bike will handle? How big of a difference will there be ?
    Assuing the 120 mm fork is 20 mm longer than the 100 mm model:
    You'd end up with a slacker head tube angle (just over 1 degree less) which will slow your steering a bit. Your handle bar would move up about 20 mm. Your seat tube angle and saddle would also change by about 1 degree so your saddle would need a small angle and position adjustment to put it back in the same place relative to your bottom bracket.
    Reputation: Joules's Avatar
    Quote Originally Posted by Slapaho View Post
    yes.
    about that much.
    in all seriousness, you will probably notice it, but it may be an improvement or not depending on how much you like the handling of your bike as it is (if you really like how your bike handles, you probably shouldn't change it). It will not be a drastic difference in any event. And of course there's offset, are the new and old forks the same?
    Reputation: SlowPokePete's Avatar
    Mar 2006
    What length fork is your frame designed for?
    SPP
    Rigid.
    Reputation: peteer01's Avatar
    Apr 2005
    I put a 120mm Manitou Tower Pro on my GT Karakoram 2.0, which came with a 100mm XC 28 fork. I made thread about putting it on that also includes my thoughts after riding it:
    Put a 120mm Manitou Tower Pro on my Karakoram 2.0 (Install story and photos)
    I absolutely love the new fork and I am glad that I did it and thought I'd share my first hand experience, in case that feedback is helpful.
    If you went with a 51 mm offset fork (G2) you might regain any slowness caused by the slacker head tube angle. If you went with a TALAS you could get your front end back to it's original height for climbing. I had just such a fork in the classifieds, but the add expired. I still have it.
    I extended the fork on a Fisher Rig from 80 to 100 a few years ago. I liked the result.
    squish, squish in da fish
    Reputation: fishwrinkle's Avatar
    i did it and 3/4" isn't going to hurt. i'd be surprised if you could even tell.
    Omnipotent
    Hey OP! Did you ever replace the shock with a 120mm? Which brand/version, and how did it work out? I'm about to upgrade shocks as well...
    Thread is about forks
  1. ASR-C XC forks 100mm or 120mm
    By yeti rider in forum Yeti
    Last Post: 05-07-2013, 01:59 PM
  2. 120mm XC forks with QR15 under 400?
    By trailrider24 in forum Shocks and Suspension
    Last Post: 01-20-2013, 09:07 AM
  3. New El Rey with 120mm forks?
    By IvanMTB in forum Ventana
    Last Post: 05-23-2012, 05:09 AM
  4. What 120mm forks are available for 29ers?
    By Just J in forum 29er Components
    Last Post: 03-06-2012, 03:59 AM
  5. RS SID vrs Fox F29 100mm forks?
    By Jaybo in forum 29er Components
    Last Post: 03-04-2012, 08:51 AM
