Page 112 of 119 FirstFirst ... 12 62 102 108 109 110 111 112 113 114 115 116 ... LastLast
Results 2,776 to 2,800 of 2968
  1. #2776
    Reputation: antonio's Avatar
    Jan 2005
    No problem. Enjoy!
  2. #2777
    Reputation: spyghost's Avatar
    Oct 2012
    Who stands 5'8"? What YS frame size for a build with 50mm stem? S or M?
    Canfield Yelli Screamy
  3. #2778
    Jan 2013
    I would go medium. i had a small at 5'7" and had to run a 100mm stem and was still a little cramped seated.Standing had my weight perfect but i thought if i got another one i would go for medium with a shorter stem.
  4. #2779
    Aug 2013
    Quote Originally Posted by spyghost View Post
    I'm same height and went with a medium frame, 120mm fork and 50mm stem. Wait until you sit on the bike before committing to your stem.
  5. #2780
    Apr 2013
    Medium.
    When you can, try a shorter stem too, I like 35mm.
  6. #2781
    Definitely a medium. I'm 5'8" (with long arms) and a 60mm on a medium was short for me.
    Also, my medium YS is up now in the classifieds.
  7. #2782
    Oct 2012
    Any news if any of the pre orders have been shipped?
  8. #2783
    Sep 2013
    Mines at the shop being built this week
  9. #2784
    Reputation: JoshM's Avatar
    My frame came from the 2011 batch of frames that were made in size XL.
    I attempted to mount a 32T raceface n/w ring on my slx cranks in the middle position. One 2.5mm spacer on the drive side BB cup. I am getting interference between chain ring and chainstay.
    The narrow teeth clear the frame, but the wide teeth do not. Chainline sits at 48.5mm, which is 1.5mm too close at least. (I'm pretty sure this frame needs 50 or 51mm as the ideal chainline?)
    I have a .7mm , 1.8mm and 2.5mm spacer as spares. I'm thinking of pulling the driveside bb cup and adding the 1.8mm spacer as well to push the chainline out to 50.3ish millimetre.
    30T is too small, so I need to get this 32T to fit.
  10. #2785
    Sep 2013
    Quote Originally Posted by JoshM View Post
    Be interested how this goes, I'm on a 30T now which is going on the Yelli but would like to move up to a 32T soon. Unless to 2014 frames will take a 32T more easily?
  11. #2786
    I had the same problem. I ended up putting two 2.5mm spacers on the driveside. The problem is that this puts the shimano "stopper plate" out of alignment with the little hole in the crank spindle. I had to really crank down on the shimano button tooth and was worried about too much preload on the BB. My setup was:
    XT triple crank
    32T renthal ring
    Large Yelli
    PS: I hated the chainline with the two 2.5mm spacers. Switched to an XT dobule crank with RF NW 30T ring. I like this setup much better. Details here:
    Yelli Screamy by Canfield ?
  12. #2787
    I found a bb wrench and added the 1.8mm spacer to the mix giving me 4.3mm of spacers (2.5+1.8). It clears now and spins fine and I have a perfect chainline at just a hair over 50mm.
    The 1.8mm and 2.5mm spacers both came in the box with my shimano BB I picked up at my lbs.
  13. #2788
    Feb 2012
    Anyone selling a medium frame? Pm me please. Thanks
  14. #2789
    bicycle rider
    Reputation: morganfletcher's Avatar
    Quote Originally Posted by morganfletcher View Post
    Here's a new pic of mine. Did a rad day out on some sweet trails with it, 2nd ride with 1x10 gears, 1st ride with a Reverb dropper seatpost. (Have three now, all but one bike have them.) Running the MRP 1x guide, using the direct-mount version. Gears are 32x11-36, 10spd, X.9 short-cage rear derailleur, X.9 shifter.
    I love my bike by fnagrom, on Flickr
    Bike was perfect all day. Love it.
    Morgan
    Latest incarnation, rebuilt with some new parts:
    • WTB Volt saddle
    • Chromag OSX bars
    • X1 1x11 drivetrain, 30T front
    • SRAM ROAM 60 wheels
    • Hans Dampf 2.35 tires F&R (pictures show Ardent 2.25 rear)
    • Spank Spike flat pedals
    Pics
    Love it, it's better than ever.
    Morgan
  15. #2790
    ^ any rub with the Dampf in the rear? I found mine rubbed under hard pedaling and cornering.
  16. #2791
    bicycle rider
    I'm running carbon rims, which help a bit with flex, but yeah I get a bit of "hurrr, hurrr, hurrr" on really steep climbs. Worth it. When I hear that sound, I know I'm getting after it. The rubber may self-clearance. The extra tire volume is worth it to me.
    Morgan
  17. #2792
    Alaskan in exile.
    Reputation: nanook93's Avatar
    New toys are awesome...
    It's finally done, and it's all mine!
    nanook93
    Ride what you like, like what you ride.
  18. #2793
    Very nice!!
  19. #2794
    Apr 2014
    Nice work!!!
  20. #2795
    Apr 2014
    Hi to all the yelli owners....Im building small frame in black and Im little confused with the crank,want to install 2x10!Will I have space problem with 26x38 chainrings or not?
    If there is a problem I will go in the 3x10 and take off the 3rd ring with bashguard with 24x32!
    I will post photos when it will finished because right now are in a piecies
    sorry for my bad english!
    build specs
    frame small black
    revelation RCT3 solo air 140mm
    full groupset slx
    novatec 4in1 with Flow ex rims dt swiss competition spokes
    exaform eten dropper
    sixpack leader 750 bar with sixpack sam 50mm stem
    tyres dhl 2.3 front and rear maybe with juice inside
  21. #2796
    Reputation: jkidd_39's Avatar
    Sep 2012
    Quote Originally Posted by Darksoul View Post
    build specs
    frame small black
    full groupset slx
    For a 2x10 X9 crankset you will need one spacer on the drive side and flip the 38t around to offset the big ring outward. (If that makes sense)
  22. #2797
    May 2013
    Wouldn't flipping the big ring compromise shifting? The ramps are only on one side.
  23. #2798
    Sep 2012
    Quote Originally Posted by BlueDragonX View Post
    Hmm. That's a good call. Never thought about that. I'm running a 38t ring in a SS setup so I don't worry about shifting.
  24. #2799
    Apr 2014
    only shimano I want to use...if I go with sram i will get the 1x10 for sure
    anyone else about my problem.....
    my frame....in the first steps.....
    special thanks to member roxie for the nice used frame in perfect condition!
    Attached Thumbnails Attached Thumbnails Yelli Screamy  by Canfield ?-10754586_10204882896769172_1595123862_o.jpg
  25. #2800
    Alaskan in exile.
    I used a Race Face Turbine 2x10 24-36-bash on my large, blue Y-S frame (see a few posts above). The clearance with the 36T ring is REALLY tight; I definitely could NOT run a 38T large ring on mine...
    nanook93
