Page 10 of 61 FirstFirst ... 678910111213142060 ... LastLast
Results 451 to 500 of 3016
  1. #451
    Headset arrives today! LBS better have my seatpost shim...
    And I just called - it won't be here until Monday/Tuesday!. I'll just have to ride it trials style until then...
  2. #452
    Steel is Real
    Ouch!
    Quote Originally Posted by alexkraemer
    Haha! "Watch out fer yer cornhole buddy." ~ Diedrich Bader - Office Space
    I know the feeling, I have a RS Reverb post on backorder... it's holding up the show. With any luck I'll be putting the rubber to the dirt in about 2 weeks.
    "America is all about speed... Hot, nasty, badass speed!!!"
    -Eleanor Roosevelt, 1936
  3. #453
    Powered by ice cream.
    Reputation: Enel's Avatar
    Ten pages.
    452 posts.
    ~29,500 views.
    I count six complete bikes.
    It must be winter
  4. #454
    Missouri sucks...
    I think we need an official Canfield Forum
  5. #455
    Quote Originally Posted by DFYFZX
    For all 6...I got one...so make that 7 bikes?
  6. #456
    Reputation: coke's Avatar
    Just placed an order for a medium black.
    Question:
    Does anyone know if there will be any issues running a MRP 1x guide and a gxp bb? The manual says to use no spacers, so not sure how this will work.
  7. #457
    Hmmmm....maybe there is a need for a Canfield B/B Forum
  8. #458
    Quote Originally Posted by Enel
    Ten pages.
    452 posts.
    ~29,500 views.
    It must be winter
    It's been snowing every third day here and I need a diversion. I can't drink at work, so thread is my only option
  9. #459
    Ten pages.
    452 posts.
    ~29,500 views.
    It must be winter
    haha, indeed.
    Quote Originally Posted by coke
    Question:
    Coke - I know this sounds crazy and contradicts everything I've read about the GXP stuff, but running GXP with a 2.5mm spacer (or any other BB mounted gadget) seems to work fine. When you get your frame install the crank and see if it works with a washer. If so, you're good to go. I must have a weird set of cranks.
  10. #460
    Reputation: yellowducman's Avatar
    My frame showed up on Wednesday. Yea.
  11. #461
    Reputation: cSquared's Avatar
    MRP just told me that the new D-mount 1x9 guide is coming out soon.
    Can't wait- got one on order for my new Large-
    New Marz- Micro Ti 120 fork-
    Got Chris kings with Edge hoops-
    29" flat Edge Bar-(thanks Mitch Ropelato)
    Got the new 12-36t 9 speed cassette from shimano to run in the back.
    Can't wait.
    I'll post up some picks when it's done-
    C2
  12. #462
    Quote Originally Posted by cSquared
    I just ordered one.
    For about the past month, I've only been using my middle ring to see how 1x9 would work for me. It was fine for everything but a couple hills. I'm thinking with 12-36, I can handle just about anything.
  13. #463
    Trophy Husband
    Reputation: geolover's Avatar
    Question:
    It is possible you may get it to work, but if it doesn't immediately break the non-drive side bearing it'll wear out prematurely...speaking from my own personal experiences.
    Extreme stationary biker.
  14. #464
    Apr 2005
    Ya one with just pictures and info and not people UPS status.
    Enjoy every ride!
  15. #465
    Missouri sucks...
    This thing will be a godsend to all the Truvativ users! Due to the odd seattube angle, the seattube mount type won't work and the Truvativ BB cups are a no go with BB style guides The only option out there that will work, that I'm aware of, is the Paul's chainguide but it's too pricey and doesn't fit the personality of the bike.
    Are there pics on the web anywhere of the MRP D-mount guide?
  16. #466
    The White Jeff W
    Reputation: jeffw-13's Avatar
    I think the Custom DH/FR/Urban forum is the default Canfield forum
    http://forums.mtbr.com/custom-dh-fr-urban-builders/
    No moss...
  17. #467
    Apr 2005
    Jenson has them in stock: http://www.jensonusa.com/store/produ...+1X+Guide.aspx
    Click on seat tube mount.
    edit: Oops! you said D mount.....sorry!
    Enjoy every ride!
  18. #468
    Reputation: whydomylegshurt?'s Avatar
    Question:
    Technically it wont work, you need a shimano/raceface BB/Crank to run the MRP. If you want to get creative, use a BB facing tool to remove 2.5mm of BB shell on the drive side. That should allow you to use the MRP with the GXP BB. Before you go cutting your frame I would take a couple measurements to ensure there are no other issues with the MRP fitting.
  19. #469
    Thanks for the help.
    I went ahead and ordered the mrp 1x. I had a big list of other things I needed to order and decided to give it a try. I'm thinking that if it doesn't work, I'll try filing it down some.
  20. #470
    Trophy Husband
    I ordered one of these:
    http://www.jensonusa.com/store/produ...+Crankset.aspx
  21. #471
    Jan 2011
    I have a noob question about a fork, I found a deal on a 2010 Fox 32 F29 RLC but it has a 53mm Crown offset (Fisher G2) What exactly does that mean and would it work on my YS ? Thanks
  22. #472
    Missouri sucks...
    It means the crown protrudes a few mm further forward than a "normal" fork. A typical fork has around 46mm of offset. It would make your wheelbase slightly longer and theoretically slow down your handling. It will work fine on your bike but I wouldn't call it ideal.
  23. #473
    Jan 2011
    Cool thanks for the explanation and i think i will pass it also was 9mm qr and i found a RockShox RLT Ti with 20mm t/a almost new that i think i will buy instead for the same price.
  24. #474
    Missouri sucks...
    I think a TA is a MUST for this bike Go big or go home!
  25. #475
    Actually, increasing the fork offset will speed up the handling, not slow it down.
  26. #476
    Jan 2011
  27. #477
    Canfield Brothers
    Reputation: flymybike's Avatar
    Quote Originally Posted by whydomylegshurt?
    That's right.
  28. #478
    Or...it might not be noticeable at all.
    I have tried the regular F29 and a G2 F29 on several bikes......it's a little....and I mean VERY little different.You will notice a bigger difference in a change in air pressure/sag than the off set.
  29. #479
    The White Jeff W
    Go big or go home!
    Going along with your theme...2.4 Spec Purgatory on Flows. Unfortunately this is the extent of what I got done so far this weekend.
    No moss...
  30. #480
    Missouri sucks...
    I'm going to run Semis and Ardent 2.4 Gonna try a Bontrager FR3 out front for a while first.
  31. #481
    Trophy Husband
    Quote Originally Posted by jeffw-13
    Did you mount that tubeless? How'd it mount up??? Easy-peasy?
  32. #482
    The White Jeff W
    Im ashamed to say I stuck a tube in there for now. Too cold out in the garage to mess with sealant and too messy to bring it in the house. The Purgatory is "tubeless ready" and was a ***** to stretch over the rim so I'm guessing it will work fine tubeless when I'm ready to go there.
    No moss...
  33. #483
    Buddhak - here's what the flush mount (XXc II Flush) looks like. I had a b**** of a time getting the cups to go in straight with my home-made headset press. No issues with clearance and I like the way the bike handles thus far. I've only gone around my block, but so far I'm in love with the handling. Hope to get a ride in when the weather makes up its mind (dry up or freeze up - this mud is driving me nuts!)
    Attached Thumbnails Attached Thumbnails Yelli Screamy  by Canfield ?-2011-01-22-16.53.29.jpg
  34. #484
    West Chester, PA
    If you wanna give it a try the control casing tires should air up with a floor pump and hold pressure without sealant. Push down on the tire in the area of the valve stem during the first few pumps.
  35. #485
    Buddhak - here's what the flush mount (XXc II Flush) looks like.......
    You had the camera out and posted pic's but none of the whole bike? Come on man, show the goods!
  36. #486
    The White Jeff W
    Quote Originally Posted by 92gli
    Thanks I might give it a go.
    No moss...
  37. #487
    i didn't want to get busted by the seatpost, hose length, or cable routing police! I'll have pics after the first ride next week.
  38. #488
    Don't forget the "rimstickers aren't aligned with the tyre"-police....
  39. #489
    The White Jeff W
    Quote Originally Posted by Gepruts
    *raises hand* See my pic above. I'm anal like that
    No moss...
  40. #490
    Nah. Nothing but love in this thread. All Yellis are good Yellis
  41. #491
    is a 20mm that much stiffer than a qr?
    by the way how does this bike fly?
  42. #492
    Missouri sucks...
    Quote Originally Posted by mellowme17
    Yes. The more travel you run, 120mm range for this bike, the more of a necessity it becomes
    You'll have to ask someone else. I'm not a jumper...
  43. #493
    I'm thinking one of the Canfield Bothers would be most qualified to answer this. I'm guessing the answer to be "quite well".
  44. #494
    FM
    FM is offline
    Reputation: FM's Avatar
    Apr 2003
    Ride #3
    Nice long singletrack climb up to a skills park today, where I hit some jump lines and wood features. Still some loaner parts from my 26" hardtail... XO brakes and a reverb on the way eventually. Fork was locked down for most of these photos.
    <a href="http://www.flickr.com/photos/10323561@N07/5383118965/" title="IMG_0074 by emailsucks98, on Flickr"><img src="http://farm6.static.flickr.com/5130/5383118965_79bb89c7d1_z.jpg" width="640" height="480" alt="IMG_0074" /></a>
    <a href="http://www.flickr.com/photos/10323561@N07/5383119407/" title="IMG_0079 by emailsucks98, on Flickr"><img src="http://farm6.static.flickr.com/5208/5383119407_7e4cbe80bd_z.jpg" width="640" height="480" alt="IMG_0079" /></a>
    <a href="http://www.flickr.com/photos/10323561@N07/5383722434/" title="IMG_0056 by emailsucks98, on Flickr"><img src="http://farm6.static.flickr.com/5044/5383722434_5052e57340_z.jpg" width="640" height="480" alt="IMG_0056" /></a>
    <a href="http://www.flickr.com/photos/10323561@N07/5383722712/" title="IMG_0059 by emailsucks98, on Flickr"><img src="http://farm6.static.flickr.com/5245/5383722712_14d239d822_z.jpg" width="480" height="640" alt="IMG_0059" /></a>
    12-36 9-spd cassette- 36t cog from eBay seller MTBtools
    <a href="http://www.flickr.com/photos/10323561@N07/5383722926/" title="IMG_0062 by emailsucks98, on Flickr"><img src="http://farm6.static.flickr.com/5083/5383722926_b13ec44874_z.jpg" width="480" height="640" alt="IMG_0062" /></a>
    <a href="http://www.flickr.com/photos/10323561@N07/5383723870/" title="IMG_0076 by emailsucks98, on Flickr"><img src="http://farm6.static.flickr.com/5004/5383723870_749b97908c_z.jpg" width="640" height="480" alt="IMG_0076" /></a>
    30t/104bcd non-ramped SS/1x ring by Andersen Machine Works. Works great, cool design. You have to bevel the tabs on the crank spider slightly inwards to clear the chain.
    <a href="http://www.flickr.com/photos/10323561@N07/5383118443/" title="IMG_0064 by emailsucks98, on Flickr"><img src="http://farm6.static.flickr.com/5206/5383118443_5d2f8db2b3_z.jpg" width="640" height="480" alt="IMG_0064" /></a>
    <a href="http://www.flickr.com/photos/10323561@N07/5383723464/" title="IMG_0071 by emailsucks98, on Flickr"><img src="http://farm6.static.flickr.com/5127/5383723464_579191a176_z.jpg" width="480" height="640" alt="IMG_0071" /></a>
    Super fun bike to ride.
    Compared to my 26" AM hardtail, it's like going from a Lotus Elise to Corvette
    Both feel great in different ways.
    The Yelli is definitely much easier on long rides and climbs better, just generally more efficient. Surprisingly, log rides and skinnies are also easier on the big wheels. So far, doesn't feel as flickable as the 26'er on jump lines or on tight switchbacks, but definitely very capable. Corners great at speed too. I notice some adjustment in cornering technique is helping, I am over the front more, steering less and leaning more.
    1x9 with the 30/36 climbing gear feels like it will be perfect for summer epic rides here. The stiff back end with the thru-axle, wide bars and light weight feel great for climbing out of the saddle.
    I likey!
  45. #495
    Trophy Husband
    Quote Originally Posted by FM
    WTF?!
    No mention of the non-ramped version on the website!....so I ordered the ramped version.
    Oil well (oh well ) I guess I'll just have to make do.
    PS - Nice lookin' bike you got yourself there. Looks moist down there too.
  46. #496
    Nice long singletrack climb up to a skills park today, where I hit some jump lines and wood features. ..........
    I likey!
    Very nice! So I'm guessing you ended up buying one? It sounded like you were borrowing it from your other post.
  47. #497
    Dinner for wolves
    Reputation: buddhak's Avatar
    Thank you, brother. I had a Minute in mind until I impulse-bid on a black Reba Team. Looks like I am going with a tapered fork. CFO was not amused. Man gotta do...
    By the way, FM, your YS is so dope I suffered a small seizure looking at the pics. Well done. Now that funds are depleted, my unit will beat up my Karate Monkey and steal all of its components. Right down to the 14 year old compact Deore LX cranks.
    Responds to gravity
  48. #498
    The White Jeff W
    Probably the same one I was bidding on. Settled on plan B - a like new Marzocchi 44 Micro ti tapered for $250 shipped
    No moss...
  49. #499
    FM
    FM is offline
    Apr 2003
    Quote Originally Posted by car_nut
    Thanks guys. Yeah she's mine, came across the right deal at the right time.
    Really looking forward to getting 'er up into the cascades & chelan sawtooths this summer
  50. #500
    Quote Originally Posted by geolover
    WTF?!
    E-mail Russell and tell him what you want. I asked specifically for a SS version and it's awesome because it's spaced slightly inboard (better chain clearance from cranks).
