Results 1 to 5 of 5
    Reputation: gthcarolina's Avatar
    Mar 2005
    White Brothers Magic 80 knocking at top
    I have this fork second hand so I don't know that much about it. I talked to the folks at the factory before the holidays and I set up the air pressure at 175 based on their recommendations. I was getting way too much sag before. Now the fork is knocking at the top and *maybe* topping out. It's been cold (high 20s to mid 30s) and I've been riding harder now that the fork isn't wallowing on me. Is there another adjustment I should make now? The sound and feel I'm getting is like having a loose front skewer. Not that I have ever ridden a bike without first checking my front skewer.
    germs, needles, milk, death, snakes, mushrooms, heights, crowds, elevators
    Reputation: None's Avatar
    Wow 175 eh. I run 55. But anyhoo, on the bottom of the right leg you'll find the rebound damper. A few turns of this should slow down the rebound from that much pressure and stop the top out problem.
    Mar 2005
    I though 175 was high too!
    Quote Originally Posted by None
    When I ran it at 60--where they suggest you start on the factory PDF-- it sagged all the way down so that I only had about 1 inch of travel left. At the factory they did not seem at all surprised by the pressure numbers. They said the max was 250 lbs, so . . .
    Anyway, maybe I should go back to 100 of so? Even at 200 I can still compress the fork without too much trouble.
    Now, as I recall, you have the Lynskey Ridgeline? I'm on the same bike.
    Reputation: Velobike's Avatar
    Maybe you have exceeded its 20 hour service life.
    Latitude: 5736' Highlands, Scotland
    jrm
    jrm is offline
    Reputation: jrm's Avatar
    Reduce the Compression Psi
    My Fluid 110 only had 5 psi of compression range. But when i reduced the compression psi from i think 5 to around 3 psi it removed the top out.
