Results 1 to 12 of 12
    Reputation: subspd's Avatar
    What chainring to replace current one with?
    This is what I have... a 2x10 with 22A/33A and bash guard, 4-bolt, 104/64mm
    The big ring, the 33,t has broken about 4 teeth on it and even with filling them down and trying to bend some back I think it is time to replace it. This is on a Stumpy FSR. I like the 33t ring I think it fits my riding well any suggestions on a replacement?
    Oh and if it make any difference this is a custom SRAM S-1250, 10-speed XC Trail double, GXP spindle, XC guard, 175mm arms, in other words the stock 2011 setup...
    Would like to upgrade to something stronger and lighter if possible.
    Expert Crasher
    Reputation: GreenLightGo's Avatar
    Stronger and lighter = more expensive. Personally, for 33t in that pattern, I would choose a Homebrew ring. If you want a 34t, I would go with Blackspire.
    Happiness depends more on the inward disposition of mind than on outward circumstances. Benjamin Franklin
    thanks greenlightgo I figure on it costing more no doubt. I guess I need to consider going to a 32t or 34t for more options huh?
    Reputation: Shalom's Avatar
    Nov 2008
    e13 also do 33T. Incredibly light and mine has lasted well. For the ultimate though, HbC is pretty much the way to go.
    Are the HBC rings ramped? Couldn't find any info on their site. This is a 2x10 setup.
    Nov 2008
    They do not have to be ramped for shifting. Sure, makes it slightly nicer, but I have had no issue using non-ramped rings. Dan might want to jump in here (or you email him) regarding the increased tooth height of his rings, as that might cause an issue.
    MTB B'dos
    Reputation: LyNx's Avatar
    I'd agree with GLG on the Blackspire and be more specific and say get the Super Pro version. Have to ask, if your current crank has a bash, how'd you trash the chainring so badly?
    I emailed dan to get his thoughts. I am a little leery not having it ramped. Are the blacksphire ramped?
    Not sure how I have done so much damage. Did have the front derailure out of alignment today and just ran with it. That might have caused one of the teeth to break but the other three???
    Reputation: hrdude's Avatar
    Feb 2006
    Rotor Q makes a 33t ring. They are expensive but supposedly have some pedaling advantages.
    Always Learning
    Reputation: BruceBrown's Avatar
    Quote Originally Posted by hrdude View Post
    $93 on the Rotor Online website for the 33T 104mm BCD.
    Couldn't find it got a link? Google didn't bring it up.
    Also I'm thinking of going with a 32t or 34t. How big a difference are we talking going either way from a 33t?
    Always Learning
    Quote Originally Posted by subspd View Post
    Rotor Bike Components
    Well, the Rotor 33T ring is like a 32T at its "narrow" point and like a 34T at its "widest" point on the oval.
    If you want to know differences, just plug your rings and cassette (wheel size, crank length, etc... as well) into the late Uncle Sheldon's gear calculator so you know exactly how things would feel.
  1. Which chainring do I need to replace my bash guard?
    By Zackb911 in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 04-21-2011, 03:07 PM
  2. Replace just the outer Chainring or whole crankset???
    By polarbill1999 in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 10-01-2009, 03:53 PM
  3. Replace a Shimano 200 GS Chainring
    By mikesusangray in forum Vintage, Retro, Classic
    Last Post: 08-25-2009, 10:06 AM
  4. replace the 1st chainring
    By losat250 in forum All Mountain
    Last Post: 09-08-2008, 08:16 PM
  5. Replace Chainring Gears?
    By mpingo in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 10-17-2007, 02:28 PM
