Page 2 of 2 FirstFirst 1 2
Results 26 to 49 of 49
Thread: weight
  1. #26
    Formerly of Kent
    Reputation: Le Duke's Avatar
    Quote Originally Posted by GnarBrahWyo View Post
    I have seen sub 20 lbs all rigid carbon bikes. I wouldn't ride a toothpick like those on my trails.
    Facepalm.
  2. #27
    Reputation: GnarBrahWyo's Avatar
    Jun 2012
    Quote Originally Posted by Le Duke View Post
    Facepalm.
    Why would I ride a $10,000 fully rigid carbon bike on my technical singletrack when these things are designed for fire roads and soft/tame singletrack?. Would be nice for bling or if I were a sponsored rider but I will take my 30 lb $2800 Stumpjumper over that any day. So would 99.7% of other riders as well.
  3. #28
    Formerly of Kent
    Well, my $4k 19.9lb hardtail has been on "your trails". And the people who ride "your trails" the fastest are on HTs or light weight, 100mm FS bikes.
    Point is, a sub-20lbs rigid bike is not delicate. Nothing on my bike is, either.
  4. #29
    Jun 2012
    News flash: Not everyone rides my local trails to be fastest. A heavier bike with more travel will handle certain more technical sections better than an XC superlight bike. I am glad you have a super lightweight and nice bike though. lol.
  5. #30
    Dec 2012
    robtre,
    Thanks for posting. Trail ninjas rock regardless of weight and size. You have my respect all the way! Also, thanks for mentioning about your preference in bikes and what works best for you. I'll certainly wait 1 year before I settle on what I'm going to buy next. I won't get a bonus paycheck until February 2014, so by then I'll know I I want in a bike.
    Also, to all those I offended by me mentioning that I can bench press 185 pounds 10 times. I just want to say this: I can bench press 185 pounds 10 times!!! LOL
    I thought for sure my bike was light, but after this thread, I find its only a middle of the road weight range for a hardtail. It's only my first mountain bike, so it's still all good. I like how the Marin rides, and besides, you all make me proud that I have a 29er bike. Especially those Olympic guys riding 29ers.
  6. #31
    Rogue Exterminator
    Reputation: kjlued's Avatar
    Quote Originally Posted by william_s View Post
    You guys probably get this question a lot, but is 27 and 1/2 pounds 29er bike considered a reasonably light weight bike for a guy like me? It has an aluminum frame and I weigh about 150 pound. I bench press 185 pounds 10 times, so I can't tell what is considered "light." This is my first mountain bike that I just bought.
    That's cool, but how many times can you bench press your bike?
    As far as the bike goes, I would bet that if you strapped 5 lbs to it, you wouldn't know the difference.
  7. #32
    Reputation: vizsladog's Avatar
    My las full suspension aluminum 29er was 25.9 with Stan's wheel set ,1x10 and racing ralphs.
    So 27 is fine. Just ride it. My new 650b set up 2x10 is 28 flat and feels lighter.....go figure. But it could be 26 with lighter tires and 1x10
  8. #33
    Always Learning
    Reputation: BruceBrown's Avatar
    Quote Originally Posted by skiahh View Post
    Not misconstruing it... just pointing out that without specifying, someone - especially a new rider - might think a sub 20 pound FS 29er is feasible.
    I mean, I suppose it is, but certainly not with a mere mortal's bank account!
    Or at least one with a nice emergency fund balance. I've seen a 20 pound Cannondale FS 29"er, but I can't remember the cost. I think it was around $11K.
    The OP could easily peruse the Bike Rumor site. They just take their meat hook (Digital Alpine Scale, of course) and go right down a company's new product line and weigh all of the bikes so there is no guessing involved.
    Here's an example as they weigh the entire 2013 line from Specialized.
    They routinely do this - so if you are looking for Cannondale Scalpel 29"ers at 21 pounds, or Fairwheel Bikes New Ultimate 17.59 pound 29"er, or Rocky Mountain's 26 pound Element, etc.... - check in at Bike Rumor.
  9. #34
    Dec 2009
    less weight, more costs.. Funny equation save the weight from 12kg bike is easy&cheap until 11kg.... To low few 100g is hard and expensive.. When you get a 10kg bike the costs is from thousand dollars to reach 9kg
    Send from Tapatalk via GalaxyTab
  10. #35
    Jun 2012
    Quote Originally Posted by BruceBrown View Post
    I got my Stumpy Comp FSR 29er in the 27lb neighborhood by swapping wheels, cassette and going tubeless. I got a relatively light trail bike with 130 mm of travel by making those changes. Their weight postings are pretty accurate.
  11. #36
    Nov 2012
    getting back to the op's original question. An entry level hard tail 29er can easily be over 30lbs and perform just fine and will cost about $6 or $700. Your bike is at 27 lbs and $1300 which is about right . The costs go up as you shed weight with cycling. it doesn't necessarily mean that your bike is BETTER, just means that it's lighter. for some people, spending a couple thousand on losing 3-4 lbs off the bike is worth it. For someone that weighs what you weigh, you are potentially in that category. You will have a blast on your new bike but the first time you ever test ride a higher end bike that is a few lbs lighter, you will feel a difference, even if it is more in perception than tangible results.
  12. #37
    RideDirt
    Reputation: aedubber's Avatar
    OP take no offense but being a beginner and your first MTB , it wouldnt matter if you had a 5lb bike , those guys still will smoke you. I used to be a gym rat , 185lbs ? lol .
    Im 5'9'' and was a solid built like a sh*t brick house 208lbs of muscle , flat bench i put up 315lbs 12 times , trap lift i did 540 lbs 8 times .. I used to warm up with 185lbs on incline .. Point being , that had NOTHING to do with me being on a bike , only good thing it served me was when i crashed it saved me a lot better then someone without any muscle lol .. I soon realized i was too big , gassed out too fast, and didnt have a key and important ingredient thats needed for this sport/hobby CARDIO and endurance ..Physically yes i was strong , i could throw my bike around as much as i wanted but that was it .
    Best thing for you to do is , hit a lot of core workouts , focus on working on legs , and lots of cardio .. Just ride what you can , stay loose , and control your breathing . Keep hitting some trails that you need to climb on over and over .. Work on proper body english , get familiar on how things work on your bike , read as much as you can ..
    I had an injury occur while i was doing some DH sessions during the summer and it all came to a halt and stop come July . I have 1 week left of rehab , just got back on a bike a few weeks ago , lost a lot of muscle and turned into fat . Started going back to the gym now , low weight and hi reps , and all the proper training i need for biking , dont worry about big numbers too much while working out
    " The bike doesnt make the rider , the rider makes the bike " ... Just sayin Enjoy your new bike
  13. #38
    Moderator Moderator
    Off topic, but...
    ...only on MTBR can you brag about bench pressing 185 pounds. Ah, cyclists. I know pros who are VERY strong looking and can't do a pullup (no, I'm not joking).
    -Walt
    Waltworks Custom Bicycles
    Park City, UT USA
    www.waltworks.com
    waltworks.blogspot.com
  14. #39
    Nov 2012
    Quote Originally Posted by Walt View Post
    -Walt
    Stop taking stuff out of context, he wasnt bragging, he was just trying to illustrate to a person new to cycling with a similar athletic background that cycling isna completely different animal. Whats wrong with that?
    Sent from my DROID RAZR using Tapatalk 2
  15. #40
    Dec 2012
    I wasn't wasn't bragging, just letting you guys know that I couldn't tell if the bike I bought was considered light or not. For example, a weak guy could lift a 27 pound bike and say that it's kind of heavy where as a weight lifter may lift the same bike and say that it was unbelievably light. Who would be correct? It's much easier to post here the question and get some very good answers because you all are experienced mountain bikers.
  16. #41
    Dec 2012
    aedubber, thanks for posting and sharing your experience.
  17. #42
    Jun 2012
    Make sure you drop a deuce before your ride and you will feel faster.
  18. #43
    Dec 2012
    Feeling faster and riding faster are two different things
  19. #44
    Jun 2012
    Sometimes, sometimes not. A good way to shed some weight on the fly though. lol.
  20. #45
    Dec 2010
    Hey, my $4000 Stumpjumper FSR Elite weighs 28 pounds...should I feel ripped off and demand a lighter bike?
    Oh, and if so I'm going to have to have all of you pay the difference. It's only fair.
  21. #46
    Jun 2012
    Quote Originally Posted by Ailuropoda View Post
    I would say no. The Stumpy is a "trail bike" which means it is built for tougher, more technical trails with really sweet suspension. A lightweight bike might be slightly better for climbing but in the rock gardens and downhill sections the Stumpy will shine. You will probably feel more less beat up after an epic 30 mile ride on the SJ than a hard tail lightweight rig.
    I got my aluminum StumpJumper down to the 28 lb neighborhood from 30.5 lbs by getting new wheels, cassette, going tubeless and upgrading to carbon handlebar. So there is probably room for you to get lighter if you want.
  22. #47
    get down!
    Reputation: appleSSeed's Avatar
    PUT MORE TIME IN ON THE BIKE!
    Simple. I think you're having an ego-check right now..around 10 years ago I had the same feeling. Why is that nerdy @ss dude killing me in races!? He doesn't play "sports" isn't athletic etc. I asked my friend, our team mechanic...he said, "he puts more time in the saddle than you" and that was it. I bought a road bike, trained, road, hours upon hours etc. until I was decent.
    Cycling can be a great equalizer of sports. Fat dudes will stomp you. Nerdy dudes will ace you. Just when you have it figured out a dude on a $300 fixie will come out of nowhere and pummel you. That's why I love it.
    Rudy Projects look ridiculous
    visit my blog, BEATS, BIKES & LIFE
  23. #48
    Nov 2012
    Quote Originally Posted by aedubber View Post
    WOW I got neg repped for defending this post. Thanks Walt, you'll have some neg rep coming right back at you. Why don't you reread the guys post. He wasn't bragging, just providing an example. If you knew anything about weight lifting you know that NOBODY would brag about benching 185, lol have a nice day.
    EDIT: WOW, WALT IS A MODERATOR TOO??? YOU'VE GOT TO BE KIDDING ME. COMPLETELY UNACCEPTABLE.
  24. #49
    Reputation: A1an's Avatar
    Quote Originally Posted by mavtek View Post
    We need a little more info, what you bench press is pretty irrelevant to me though.
    Reminds me of this:
    How much ya bench? on Vimeo
    Already been said but mid-upper 20s seems about mid weight. Really wouldn't worry about bike weight though. Focus more on riding and less on components. Just my .02
    Signature
