• 11-30-2012
    JP...
    Took the frame down to the LBS. It took them a while but they found a lower headset cup that fit, not like the one I had that was a smidgen too small.
  • 11-30-2012
    intheways
    Double post
  • 11-30-2012
    intheways
    The tolerances must be a little off from normal.
  • 12-01-2012
    thechez
    Originally Posted by JonnyBig View Post
    Thanks Sandwich
    I hope the ride is as good as the looks, but since I'm coming from a 100mm travel (RS Tora!) hardtail I don't think I'll be complaining.
    Not going to get out on it for another two weeks though which is a bit painful and she wont get a proper test till the end of Sept in Wales, lets hope she holds together...
    How do you like it Jonny? I personally love the Monarch RT3. I have an RP23 on my Yeti and would swap it in a heartbeat if I could afford it. I love being able to flick the switch to the right for steep stuff, keep it in the middle for most things and turn it left and open it up for downhills. I wonder though if the shock would work the same on a different suspension design. But I do love it on the Canzo. I feel they hit a homerun on that one.
  • 12-06-2012
    agu
    Headset required is an FSA #57. Tried a "typical" tapered unit and indeed the lower bearing wasn't a perfect fit.
    Also, the frame required a 30.0 seatpost. Easy enough to find a shim to upsize a more common 27.2 post.
    Built up a size 18 with the following components:
    White brothers loop 100
    Shimano PRO cockpit and saddle
    Deore 1x9 drivetrain with MRP 1x guide
    Shimano M629 hubs laced to Velocity Blunt rims
    Maxxis Ignitor front, Ikon rear
    Hygia SLP brakes
    Weighs close to 29lbs.
    Photos when it gets dirty!
  • 12-06-2012
    thomllama
    Before, during and after is best ;)
  • 12-06-2012
    agu
    Before:
    Not the most flattering angle.
    Tires have since been swapped to the Maxxis Ignitor/Ikon Combo. And the masking tape on the headbadge has since been removed.
    Build turned out having a black/grey/silver/white theme.
  • 12-07-2012
    agu
    Inaugural Ride
    The bike feels quite composed on the trail - the rear end doesn't seem to be as active as I expect it to be. Personally I prefer more progressive rear travel, and with the monarch shock it seems the 2013 Canzo has just that.
    The Loop feels like a good match too, and was pretty much set and forget.
    Will take this rig to other trails and see how it behaves.
    If you guys have any questions, feel free to ask.
  • 12-07-2012
    thechez
    Have you tried the Floodgate switch to fully open? I've found the suspension to be VERY active on the Monarch RT3 when it's all the way open. I really do like the settings on it. Seems much more real than a Fox air can. Fox seems to be open and kinda closed. The Monarch is open, somewhat soft and 99% closed.
  • 12-07-2012
    agu
    I run the RT3 open most of the time. The shock may get more supple as it wears in.
    Which means I gotta ride it more!
  • 12-29-2012
    vlad_au
    Freshly built Canzo '13 from scratch, weight 14.2 kg
    ht tp://velodom.com.ua/full/71871.jpg
    very happy camper :)
    Fork: RST First 29" - cheap but works well
    Wheelset: Easton Heaven
    Headset: Cane Creek ZS 44/28,6 | ZS 56/30
    Handle Bar: Easton Monkey bar EA70
    Stem: Kore
    Brakes: Hayes Stroker Ryde
    Shifters: LX (old stock '03)
    Cables: Goodridge
    Bottom Bracket: Hope (steel bearings)
    Crankset: Deore 22-32-44
    Cassette: HG81 11-28
    Tyres: WTB Wolverine 2.2 foldable
  • 02-04-2013
    riderjtt
    If you still have your small Canzo, can I ask what the seattube length is center to top to the seat collar? I have emailed Voodoo with this question with no response. The TT length for the small will work for me but the seattube length on the website is ctr-ctr and seems really strange. Thanks for any help.
  • 02-04-2013
    riderjtt
    Can anyone post a picture of a Small frame built up? I have searched all 23 pages of this thread and cannot find one posted. Preferably a later, 2011-2012 model with the straight TT. Thanks!
  • 02-04-2013
    thomllama
    mine's a small... I'll find the pic's a link back... It's a 2009 or 2010 model (the black frame... the green frame is a 2006 I think)
    I ride a med size frame normally (26 or 650B) but honestly they felt small to me, this "small" frame" feels bigger than the med 26'ers thou.. the older frame was longer
    just go to "trailtireTV.blogspot.com" images thru out there
  • 02-04-2013
    Duzitall
    Re: Voodoo Canzo 29er: So what do you get for $750
    Im late for work but if you find my photos in this thread my green one is medium and my black one is a small.
  • 08-07-2013
    29buzz
    Anyone have a standover figure for a 2013 small frame at either 100mm or 120mm? Thanks in advance!
  • 08-07-2013
    barneyhanway
    Voodoo's website has it at 29.25"/743mm with 100mm fork.
  • 11-19-2013
    soulospeeder
    2011, Size Large.
    2012 Manitou Tower Pro 120mm (tuned)
    9 speed LX drivetrain & shifters, XT rear DR
    BB7's & Speed Dial SL levers
    Blag Flag Pro's with 2 scoops of Stan's
    2.55 (2.3??) Weirwolf LT upfront
    2.3 Slant Six outback
    EC70 seatpost
    EC90 25.4 Handlebar
    ~20 year old 747 SPD's
    Comes in just under 28.5 lbs. My first 29'er, first FS, was riding SS and rigid SS prior to this bike. As far as some other posters concerns about the 120mm, I find it works for me. Extra confidence on big rocky AZ drops, and I can lock the front down for any big climbing action. Very fun bike for riding everything from Sedona rocks to Flagstaff flowy-singletrack. I am currently training for some endurance series and will probably drop down to 2.1 Small Blocks or Nano's.
  • 11-19-2013
    thomllama
    looks sweet :)
  • 11-19-2013
    soulospeeder
    Originally Posted by thomllama View Post
    looks sweet :)
    Thanks TL, I had an LBS get everything fitted to me as far as stem length & height, seat height & position, handlebar angle & SPD cleats adjusted. Needless to say I feel very comfy on this ride in just about any terrain & conditions.
  • 11-19-2013
    thechez
    Yeah. These newer frames look much more compact than the older frames.
  • 06-01-2014
    Roh1
    I am thinking about grabbing a 2013 frame for my first FS 29er build. After reading this thread my main concern is the 18.25" chainstays. My current hard tail 29er has much shorter CS length. I guess I am worried the Canzo will feel like a tank on the trails I ride compared to my old bike.
    Opinions greatly appreciated!
  • 06-01-2014
    sandwich
    It does/did for me. Shorter chainstays completely changed the way my bikes since then have handled. I'm now on an enduro 29er, but I had a scott scale as well. Both were much better handlers than the canzo.
  • 06-01-2014
    bamwa
    i have a 2012 med. canzo. It is awesome and nimble as can be in my opinion. I'd get it again. However Voodoo's usa website has been down for months and other links are broken so I'm not really confident they know whats up. This is a bummer. I would contact
    their uk offices and see what the deal is but there are some red flags for sure. Also not a fan of the green rocker arms. I'd paint them black or something to match your build.
  • 06-01-2014
    TwoNin9r
    For $750, if you're looking for a 29er that will put more smiles on your face than you know what to do with, I strongly suggest taking a peek at the switchback site, they're selling some closeout frames (the one I have) for unexplainable prices. Mine is set up revelation xx, arch ex, and is under 29 lbs with dropper. I don't even look twice at my 21lb carbon hardtail any more. Your be doing yourself a favor at least looking into it.
  • 06-01-2014
    Roh1
    Thanks for the replies fellas.TwoNin9r I will definitely check out the switchback site.
    Considering the Canzo frame can be purchased where I live for $650 delivered, I realy cant find anything that competes , at least price wise anyway.
  • 06-02-2014
    gregnash
    One thing you had to remember is the Canzo is a great bike but a bit dated. With that said the longer chainstays will make the bike feel longer and it will corner much differently. My HT has shortish chainstays and I just picked up a Hammerhead Thumper like TwoNin9r did to build. I am stoked about the bike because it has similar geometry specs to my HT and is a great steal at $750 for the frame and Fox Float CTD. Looks at the Kona Satori or Salsa Horsetheif as a comparison to what the Thumper will do.
  • 06-02-2014
    FastBanana
    The Hammerhead Thumper has 17.5" stays, and its a similar suspension layout.
  • 06-02-2014
    Roh1
    Thanks again for the advice,especially to TwoNin9r for pointing me in the direction of the hammerhead . After reading all the posts on the bike, One Hammerhead thumper , grey XL has been ordered ! Can't wait !
  • 06-02-2014
    TwoNin9r
    Oh man you're gonna love it!
    Posted via mobile
  • 06-02-2014
    gregnash
    Awesome!! You can't beat the price and I am stoked to build mine.
  • 06-02-2014
    TwoNin9r
    I'll take some nice shots and PM you one day this week
    Posted via mobile
  • 06-02-2014
    Roh1
    That would be great. Thanks!
  • 06-03-2014
    noosa2
    Good call on the Thumper. I've been riding mine for about 4 months now and just love it.
  • 06-03-2014
    bamwa
    Now you have to come to Austin and ride it on Thumper the most ass kickinest trail in Texas!
  • 06-03-2014
    TwoNin9r
    Am I invited?!
    Posted via mobile
  • 06-03-2014
    FastBanana
    Getting the first ride on my Unveil today!
    Sent from my LG-LS995 using Tapatalk
  • 06-03-2014
    TwoNin9r
    We should do a post your hammerhead / switchback thread. There are enough of us...
    Posted via mobile
  • 06-03-2014
    FastBanana
    Posted via mobile
    Like 10 maybe. Swutchback needs a subforum
  • 06-03-2014
    TwoNin9r
    Aye
    Posted via mobile
  • 06-04-2014
    Roh1
    +1 for the switchback forum!
  • 06-04-2014
    slopok
    Well my 2007 Voodoo has been a great bike. I've enjoyed riding it but it's time to retire it. The head tube is ovalized and the creaking is getting old. I am trying to decide on the SC Superlight 29 or the HH Thumper as a replacement.
  • 06-07-2014
    Switchback Bikes
    Just came across this....thanks @rohl for purchasing your Thumper! And big thanks to all the Thumper owners chiming in....awesome to see happy peeps rocking the Thumper!
  • 06-08-2014
    Roh1
    No worries Scott, what a helpful bunch of thumper owners! Thanks again guys, will be sure to post pics when the build is finished.
