Results 1 to 14 of 14
    Knob scrubber
    Reputation: Finksta's Avatar
    Jan 2013
    Upgrade for stiffness, fork or wheels?
    I have a 2013 Stumpy expert 29 which I love, it's a fantastic bike. The only place it falls down is in front end stiffness. It has Roval control trail wheelset and fox 32 talas ctd 130/105 fork.
    I'm looking at upgrading either the wheels or the fork, depending on which one will make the most difference. The wheels I would get are the Roval control trail SL (carbon) and as for the fork, I like the look of the new RS Pike when it becomes available.
    Any opinions on which upgrade will make the most notable difference?
    Aug 2010
    wheels, of course. you already got excellent fork.
    Knob scrubber
    Jan 2013
    Re: Upgrade for stiffness, fork or wheels?
    I know it's a good fork, I'm not questioning that. It is flexy however, and I want to stiffen up my front end, and would like to know which upgrade would make more difference in terms of stiffness.
    Sent from my GT-I9100 using Tapatalk 2
    Reputation: OmaHaq's Avatar
    Jun 2010
    Wheels all the way. Unless you are ditching suspension, then buy a steel or good carbon fork.
    - The only thing that keeps me on a bike is happiness.
    I had a 12 SJ FSR. While I like what the Fox 34 140mm did for it, I will say the ONLY reason I bought it before wheels was that the owner of my LBS was selling his.
    I asked more as a joke than anything serious and he said make me an offer. I low balled because that's all I had and not expecting a yes and he said yes. So I had a new fork.
    If I had to pay retail it would have been wheels especially if those $1200 Rovals had been out.
    Tallboy 3
    OG Ripley v2
    Carver 420 TI
    Is your front hub 15mm? If not, then a new fork and a front wheel that accepts the larger axle size. If you already have the larger axle, then certainly the carbon hoops that you've mentioned, like the above responses have said.
    Good luck!
    $1200 Specialized Roval Control 29 carbon wheels . Put the savings over the SLs toward the fork.
    Knob scrubber
    Jan 2013
    Excellent, thanks for the responses, looks like it's definitely wheels then! A set of the carbon Rovals will probably shave a significant amount of weight too, double bonus.
    Reputation: EGF168's Avatar
    Stem.
    TR
    TR is offline
    Angry bunny
    Reputation: TR's Avatar
    Get a bike built out of H beam with a fork also made out of H beam.
    These discussions about stiffness are hilarious and ridiculous at the same time.
    Knob scrubber
    Jan 2013
    Thanks for the input mate, it must be awesome being as knowledgeable a you.
    Merendon Junkie
    Reputation: abelfonseca's Avatar
    Dec 2011
    I thought your stock setup was as good as you could go with regards to stiffnes, I dont think the carbon rovals are going to be that much stiffer, just lighter, but maybe im wrong. Are you some kind of redbull rampage level rider or a very stout clyde? 29er wheels will never be as stiff as the equivalent 26 inch wheelset although as that quality level the flex on your wheelset should be pretty hard to feel, that is if you are a human and not a lab machine.
    Knob scrubber
    Jan 2013
    There is considerable noticeable flex, and I notice it more in the front end. This is the reason I was questioning fork or wheels. This is the first 29er I've had, so coming from a bike with very stiff 26" wheels it can be off putting and detracts from my style of riding.
    The stumpy that I test rode was the s-works model, this had the carbon wheels and the difference it makes is not just noticeable, it is exceptional. I guess that probably answers my question, but I was just looking for more opinion from people that may have made these upgrades.
    TR
    TR is offline
    Angry bunny
    OK, some real options.
    Headset, stem, bars, wheelbuild/spoke tension/spoke count.
    Far more likely than your fork IMO.
  1. wheels with better stiffness than Stan's ZTR Arch 29er?
    By somebodyelse in forum Cannondale
    Last Post: 10-06-2012, 10:10 AM
  2. Objective measurements of fork stiffness?
    By outlierrn in forum Shocks and Suspension
    Last Post: 07-31-2012, 10:39 PM
  3. 2012 Rockhopper Upgrade Fork or Wheels?
    By Tig3rHawk in forum Specialized
    Last Post: 07-07-2012, 10:01 PM
  4. Replies: 22
    Last Post: 07-01-2011, 01:08 PM
  5. Fork-hub stiffness (std QR, 19mm vs OS 28mm)
    By whtdel in forum Wheels and Tires
    Last Post: 03-18-2011, 10:23 AM
