Results 1 to 6 of 6
    Apr 2013
    Trek Superfly 100 Pro or Trek Rumblefish
    I'd like to get your thoughts, opinions and advice on the following two models:
    Trek Rumblefish
    Rumblefish - Trek Bicycle
    Oct 2007
    I would say it depends on what kind of riding you want to do. The rumblefish will be more plush and the superfly will be faster.
    long standing member
    Reputation: PCinSC's Avatar
    Totally depends on the terrain. If you've got lots of technical terrain and look for the bigger chunk and stunts then the extra travel and frame beef would be nice. But if most of your terrain is mild then the Superfly is probably the better option as IME it's more efficient and rolls over the small to moderate chunk just fine. You could always use the $400 you save to add a dropper post, if desired.
    Another consideration...I was not a fan of the DRCV suspension on the Rumblefish, but from what I've read I'm in a minority with that opinion. Demo both if you're really interested.
    stoked gnar shred
    Reputation: tylerw's Avatar
    Dec 2009
    are you in the NW W SW mid west South? terrain would be the determining factor here id think. not knowing what terrain you ride, i would choose the superfly; I am more for lighter and least amount of travel possible type of person (efficiency).
    Apr 2013
    Terrain is a mix of XC and some technical trail. There is DH but that's not my interest nor intent.
    A friend mentioned that the extra 20mm from the Rumblefish may not be that big an issue when compared to increasing skill level and ability with the Superfly and that the extra $$ saved can be used for upgrades should I choose. (i.e. dropper post upgrade suggested by PCinSC)
    The Specialized Enduro comes to mind but am supporting the LBS with Trek's and the Superfly and Rumblefish came to mind as good models within the Trek range.
    Apr 2013
    Thanks greatly for your help and advice.
  1. Trek Cobia, Giant XTC 2 or Trek Superfly?
    By trek7100 in forum 29er Bikes
    Last Post: 12-10-2012, 09:47 AM
  2. How much did you pay for your Trek Rumblefish?
    By Eyetattoo in forum 29er Bikes
    Last Post: 09-18-2012, 10:37 PM
  3. Trek Rumblefish or Trek Superfly AL 100
    By Over50rider in forum 29er Bikes
    Last Post: 07-02-2012, 05:06 AM
  4. 2011 Trek Hifi Plus or 2012 Trek Superfly 100 al
    By Wolf57 in forum Beginner's Corner
    Last Post: 10-20-2011, 07:54 PM
  5. Replies: 0
    Last Post: 07-19-2011, 06:12 AM
