Results 1 to 34 of 34
    Titus vs. Leviathan vs Fisher
    I own two of these bikes and borrowed the third from Mike Curiak to do the first full suspension review of all three bikes on a relatively controlled course. Quantitative info is reported first, qualitative is second
    Bikes – Fisher 293 with Fox Float R shock and BW 1.0 fork (run in the 4.1” travel setting)
    Titus Racer X with Fox Pro Pedal shock and BW 1.0 fork
    Leviathan with DT shock and BW 1.0 fork with 20mm thru-axle
    All shocks were set to specification for my weight of 158 lbs.
    All tires inflated to 40 psi and Kenda Klaws were used for all bikes to keep it consistent.
    Test loop was the Grand Loop (Mary’s, Steve’s, Lions, Troy’s, frontage road) at the Kokopelli trailhead in Loma, CO, ridden on three separate days so that fatigue was not an issue.
    Temps each day were 95+ degrees Fahrenheit.
    Heart rate range 145-170 (high and low settings on my monitor), each loop was completed without incident and loop times were:
    2:05 Fisher
    1:53 Leviathan
    1:45 Titus
    I neglected to set my calorie counter with the Leviathan so that comparison is not valid however the difference between the Titus and Fisher was 155 calories with fewer being burned on the Titus.
    Quick ratings for general overall ride impression: Titus, Leviathan, and then Fisher.
    Comfort rating (subjective feel): Fisher, Leviathan, and Titus
    Handling: Titus, Leviathan, and Fisher
    Weight: all within 2 lbs. of each other (that’s less than two water bottles)
    Value rating is difficult to do since each bike was not stock – even the Fisher had many parts switched out. Shifters are irrelevant, as are posts, cranks, BB, brakes… All bikes were measured and adjusted so that I had the same distance from center of saddle rails to bar center and center of BB spindle to top of saddle. Saddles were all centered to the seat tube so there was no issue with seatpost layback. Please don’t ask me for all the quirky measurements like front-center, rear-center, wheelbase, trail, bb height, chainstay length, head angle, seat tube angle. Even though all of these measurements do matter they are all available from the manufacturer and I was only concerned with rider cockpit setup to find out which bike rode best for me, in a normal setup, without being too anal.
    Of note, the wheel system on the Leviathan, technically, should have been much stiffer than the other two bikes. The Leviathan had a 36-hole front with 20mm thru axle, and the rear was a Zipp. Both other bikes made use of the same wheel set, Bontrager Race Lites. However, I did not notice an overwhelming difference. Stiffer? Yes. Earth shattering? No. I may not weigh enough to truly take advantage of this. That being said, since the front wheel was 200g heavier than the Bontrager, and the fork is 90 grams heavier with the 20mm thru axle, some performance issues would change from the weight difference. I will be testing this more over the next few months, along with 20mm axles on shorter travel.
    The most active feeling bike is the Fisher. The overall feel is like you are sitting into the bike and suspension due to the high front end. It is important to note that the Fisher, set in the 4” mode, was the most balanced with the 4” travel fork. It was the only bike to not feel choppered out with the BW 1.0. However, when you first start to ride the Fisher the bike feels very flexi. It does not ride flexible it just feels springy. Point the bike where you wish and it goes. The bike climbs well on the trail and there is not excessive motion when on the trail. Overall the bike feels good once you are used to the rider position, but it always feels flexible even though it is not.
    The next most active bike is the Leviathan. However, this bike feels right from the start. It was the first 29” bike I threw a leg over that felt like a 26” wheeled bike set-up. The bike felt custom from the start. The only complaint is that the 4” fork chopped the front end out a little bit giving a slight tiller effect for the first 20 minutes of riding until rider compensation set in. Mike C. has commented before on how the bike handles, and I would echo his feelings. The Leviathan has a point and ride characteristic superior to that of the Fisher without a soft feel.
    With all that I have written so far I am lead to the Titus in the end. It is, without a doubt, the most efficient and best feeling 29” bike I have ridden. Some of the feel may be attributed to the rear shock, but this bike accelerates like a ridged bike and tracks like a sports car descending. The rear end is stiffer laterally than any other FS bike I have ridden (maybe a normal characteristic of the Racer X design). That being said, when riding the bike it gives a sports car type ride meaning that the rear suspension does not “feel” as compliant as the other bikes. However, I did not finish riding my test loop feeling more fatigued as I would expect from such a firm feel. Climbing was very efficient – hard tail feel with FS traction. I truly found certain climbs surprisingly easy having thought they would be difficult in my mind from my previous ride.
    Conclusion is this. For a do everything race/trail bike the Titus is my choice hands down. Faster ride with less energy burned sums it all up. The Leviathan is a close second but did not feel quite as responsive climbing and handling was a touch slower than the Titus (I like “traditional” race type feel). As mentioned the wheel/fork combo had an effect on this. The Fisher, although third in my test, may still find a place in my stable, as it is a great all around bike and I need to ride it in short travel mode to see if that changes my opinion. Also, if on a smaller budget (although still large) the Fisher is a fine choice as it comes stock with very useable parts and is ready to go, the geometry takes a little bit to get used to (I have owned this bike for 10 months and it still requires a get to know it break in each ride).
    Ask me any questions that you may have, I’ll answer honestly. I only ask that we don’t get too lost in the technical theory of this and that (see earlier note). The bottom line results are truly gleaned from the brief quantitative info up top.
    Reputation: miles e's Avatar
    Excellent review, very thorough and I'm sure time consuming. Even given that some of the time difference could be attributed to other varialbes, it's pretty amazing that the Titus was that much quicker. A couple questions:
    -You seem to indicate that the Titus still has a quick feel to it with the BW 1.0; would this discourage you from running a BW .8 on it?
    -The Fisher will no doubt be ultimately plusher than the Titus with the extra inch of travel, but how close do you think the two would come if a non-propedal shock set up for plushness was used for both?
    Moderator Moderator
    Reputation: Walt's Avatar
    Wow...
    A 20 minute differential? So the Titus was ~15% faster?!? I have to say I'm shocked that ANY bike (assuming relatively similar weight/suspension/setup as these bikes had) would make that much of a difference...especially on a loop that has a mix of pretty much every kind of terrain and of that length.
    I've briefly (and not at all scientifically) compared times of my own on various bikes and found that the difference was less than 1% with vaguely comparable rigs. Heck, I can ride my downhill bike within 15 percent of my fully rigid most places (as long as it's not too flat for too long - and yes, the DH rig has a triple on it).
    I'm not trying to be snide, but I just don't think any bike without a motor can be that much faster or slower over the same course with the same rider on board, calorie counter or no. The valuable part of your review is in fact NOT the quantitative part, but the qualitative report on ride qualities. Which is great, IMO.
    -Walt
    Reputation: Bigwheel's Avatar
    Thanks for doing the, uh, leg work on that Jason.
    My only question is if you notice more pedal strikes with the Fisher? I know that is the most annoying feature of mine, although I am back to running the stock fork at only 80mm and 4.1 in the back I know the Lenz is a higher bb but what is the Titus riding at there?
    I guess now you have to get ahold of the Airborne at some point to add it to the equation? And also I would be interested to know how the SlingShot performs in comparison?
    A bike by any other name is still a bike.
    Witty McWitterson
    Reputation: ~martini~'s Avatar
    No real questions here, just a thanks for the 'effort' of doing this. 'tis good to see a nice comparo done in writing.
    Just a regular guy.
    This place needs an enema
    Reputation: mikesee's Avatar
    Aug 2003
    Excellent!
    Jason-
    Great writeup. I think it's well thought out and I agree with most of your assessments. I like the fact that you controlled as many factors as possible, and they were, in my opinion, the essential things to control.
    The Titus seems to make the most sense for the racer crowd, the Lenz will probably work well for some racers and most trailriders, and the Fisher? Gosh, I just didn't like the way that bike climbed at all, and on descents the suspension felt great but the bb height just killed it for me. I guess that means the Fisher would work well for the non-technical trail crowd that doesn't mind a bit of extra weight and movement on the climbs. Wherever they live...
    I'd like to see another test this summer with a .8 on the Titus and the Lenz. I think putting the lighter fork and significantly lighter front wheel on the Lenz would close the very narrow gap between the two, even though the Lenz will always be a more active bike with a non-platform shock on it. That was the point of the Lenz after all--to have an active bike for techy riding, but one that could still climb anywhere, anytime.
    Maybe when I get back from the GDR and it's only 200 degrees here in the valley we can give it a whirl.
    Peace,
    MC
    Replies
    Miles – No, in fact I’m switching my BW 1.0 over to a .8 (I have the internals to do so) and think that will be the optimal setup. My experience with the 80mm air is that it ramps up very progressively and I have yet to ever bottom it out resulting in a harsh feel. As Mike C has hinted at we want to re-test all the bikes with shorter travel forks anyway, both the Lenz and Titus were designed with 80mm forks in mind.
    Based on my previous experience with FSR link frames, and ridged pivot TREK/Fisher frames, I think the vertical feel of the Titus would be plusher with a non-platform shock. As long as the travels were similar…
    Walt – I agree that I was very surprised by those numbers. That’s why I recorded them and posted them. It is what it is. The only explanation I have, which makes sense, is that I rode the Fisher almost three weeks before the other two, one week after my final move to GJ from almost sea level. Although the altitude here is still only 4500 feet anything over 4000 feet does require acclimating. Based on past years of very serious training I do know that this could account for such a drastic change. It would be fair to say that the Fisher time could have been a few minutes faster. When I have time I will redo that ride.
    Bob – I’ve been riding the Fisher long enough to intuitively time my pedal strokes to avoid that. My original Kelly was much lower, and good training. I have never ridden the Fisher with a 80mm fork; that will most likely change my timing. Also, knowing the trail really helps me in avoiding the pedal strikes – I only need to catch my toes once on a trail to make me remember not to do it again.
    I will do a Slingshot review at some point, I just prefer to ride a few similar category bikes together to create a good comparison that readers can relate to. If I can say it rides similar to a Super Cal or different from they know what I mean. I will say this, however, my Slingshot is still the fastest bike I have ever owned!
    Mike C – As you and I have discussed I would really like to redo the test with BW .8 forks as well (good thing we have them). I felt that I was missing something with the Lenz and really want to find what that is. The bike is great, I just want more time on it – but that means less time on the Titus…
    Quote Originally Posted by rossixc
    I will do a Slingshot review at some point, I just prefer to ride a few similar category bikes together to create a good comparison that readers can relate to.…
    As the SlingShot is a "suspension" frame I just thought it would be a good control to the equation. I guess it would be better compared to a soft tail bike in all fairness. If you ever get a chance it would be good to see how it compares to the full FS bikes.
    I can relate to the way you have to be more intuitive riding the Fisher over a taller bb bike. My problem is that when I switch to my hardtail with the taller bb I end up tip toeing for the first half of the ride as if I was on the FS until I get comfortable with the extra amount of clearance and the need to have to read the trail differently. I know for sure it was better with the 100mm fork though, way better balance.
    Moderator Moderator
    Reputation: 2melow's Avatar
    Great Reviews
    Very nice.
    As an every day Front Range and Northern CO trail bike style frame...I still think the plushness of the Lenz Leviathan is for me (if I had the coin.)
    The Duuude, man...
    Reputation: ncj01's Avatar
    $.02
    I too find those times very difficult to swallow.
    In clinical research settings folks would attribute findings that extreme to "expiramentor bias." This doesn't mean the expiramentor is a devious fellow, or that he/she purposely changes things to acheive certain results...just that whatever that person "brings to the table" will have an effect on the outcome.
    Take for instance your comments on the fisher, in terms of having weird geometry and riding position that "takes time each ride to get used to" and that "you've been riding for 10 months, still different" (paraphrasing of course).
    Also, we all intutitively "know" that in terms of pure XC racing the RX is the fastest, the Leviathan 2nd, and the Fisher last. It's the design, purpose, geometry, cost, etc...so you knew those things too...heck, I dare say you expected those things....
    ...so no, you didn't go out there consciously saying "OK, I'm going to ride like the wind on the RX, pretty fast on the Leviathan, and like a tank on the Fisher" but I dare suggest you wound up riding like you expected the bike to ride. This type of thing has been demonstrated time and again in clinical settings, ranging from athletic performance, to Kindergarden children's performance in the classroom.
    Think of it as a race...do you think that if you could carbon copy yourself, and it was a 3-man race, that you'd really put that kind of time on yourself...20 minutes...heck, in a race that the winner finishes in 1:45, 20 minutes is an eternity....heck, 5 minutes is a slap down...
    Last comment: I think you should borrow MC's Mooto-X as well for the next test...
    Oh, here's an article that discusses expiramentor bias much more effectively than I can...talks about ways to get around it, such as the common "double blind" procedure...which would be near impossible in this situation, as you'd have to not know which bike you were riding for each trial...
    FS: Everything
    The Duuude, man...
    another thing to think about:
    2 years ago, a buddy of mine and I were duking it out in the Arkasnsas state series (14 races)
    Start of season:
    Me: Fully custom Ibis Softtail, fully loaded, 23lbs and change
    Him: Mid/late 1990's Diamondback full suspension, 8speed parts, beat to hell, 30-something pounds.
    Results:
    I won most of the time, by a margin or about 30 sec to 1 minute
    Then, mid season:
    He buys a full custom, made for him Sofa King, fully loaded, 23 and change pounds.
    Me, no change:
    Results: He won most of the time, by about a 30 sec to 1 minute margin.
    I dare (dare is the word of the day for me) say that the difference between his old and new bike was WAAAAY more substantial than the difference between a 29er fisher and RX. The total time variences where from 1-2 minutes.
    Anacdotal, perhaps. Certainly no expiramentor bias though...
    FS: Everything
    Now if it was a fork comparison I might wonder though.....
    It is not like RossiXC works for Titus, or Lenz or Fisher. He is just an enthusiast like the rest of us and if he says that is what the clock says, then I am not going to try and label him any fancy names to say its wrong or not applicable to his test. He is one person, and it doesn't take a degree in rocket science to figure that anothers times and conclusions would vary.
    It is funny that I didn't even pay attention to the times when I read the article, but went right to the part about how the bikes felt underneath.
    Thanks again for taking the time to get this on the board Jason!!
    Bored
    Reputation: bigwheelboy_490's Avatar
    Jan 2003
    I'd have to agree with NCJ01 on this one. I cannot believe the difference between the ride times as being atributed only to the bike. It is subjective to physical factors like air density and temperature, fatigue, hydration, ect.
    Also, you mentioned feel as being you criteria for selecting your favourite bike. I guess it is subjective to how you want the bike to feel.
    Good review though!
    MTBR is serious stuff.
    You never get better until you get out of your comfort zone.
    Moderator Moderator
    Mike - Do you think you would have had a faster time if you were riding Chads bike in the Kokopelli Race?
    Chad - Do you feel you would have suffered on Mikes Ti hardtail?
    If the Titus design is even just 1% faster, than a hardtail...that would mean a 9 minute faster finish on a 15 hour race. That's pretty substantial.
    Reply 2
    Ncj01 – Sorry to squash your theory, but I considered each bike to be a race bike, trail bike, and all around fun riding bike. I really don’t have any preconceived notion of how the bike is designed to ride when I do these reviews. I just know how I want it to ride based on what I do and how I set them up. Names really don’t play a part in my assessment. If I called the RX the Asylum instead should I expect it have an insane ride and be crazy on the climbs and descents?
    As for my times, please see my reply to Walt regarding altitude; it’s the only explanation I can think of. If I cloned myself on the loop I did, and had each clone take a different bike on different days I would expect the same results I had. Now if I do this test again say in August or October three days in a row, using heart rate (level 2-3) as my benchmark I will expect to be closer in times as my fitness levels out. I admit that early season fitness and/or altitude played a part in the results.
    Of those three bikes the only one I have raced is the Fisher – that’s what I bought it for. Even though I regularly have a stable of 6 bikes or more, I set each one up to suit the style of riding I am doing, I don’t ever compare different purpose bikes; it’s not fair. Each of these bikes is built relatively light with comparable travel and marketed handling traits. They each claim to be 24-hour race worthy (they are) and great all day trail bikes (they are). My comment on the Fisher is just that, my comment (see original disclaimer that this is one riders opinion). It does take noticeable adjustment on my part every time I ride it because it is different in feel from my other bikes.
    Again, for those reading. I’m not trying to make a statement here. I just thought it might be helpful by giving the first opinion of these three segment leaders in a not so perfect side-by-side test. Get your hands on as many bikes as you can and make your own assessment. All three of these bikes are great, for me I have my results.
    Bob – I agree that the Slingshot could work well being compared to the soft tails. I had to chuckle at the vision of you “tip toeing” for the first mile – but I know what you mean.
    Moderator Moderator
    Word. You did a great job Jason.
    Maybe we should post this on the endurance board. How come so many of those guys are still riding the 26" wheels anyway? Did they not see the times of the Kokopelli race and the top three finishers?
    Front Range Forum Moderator
    rider
    Reputation: Swami Scott's Avatar
    Nice review!
    I agree with Big wheel - nice job on the review regardless of the time info!
    Harmonius Wrench
    Reputation: Guitar Ted's Avatar
    Smile Thanks! Interesting read!
    I picked up on the 1.0 vs .8 shock thing right away. I'm happy to hear that you will be checking the Titus and Lenz out with the .8 fork. My question is do we really need 4" of travel on 29ers? Many have extolled the ride quality of 29 inch bikes, saying it negates the need for long travel suspension. Perhaps 4" is necessary for 24hr/ marathon events? What is your opinion?
    Riden' an Smilin'
    Guitar Ted
    Blog
    RidingGravel.com
    Reputation: SoloWithOthers's Avatar
    Great information! Post of the year?
    Anyway... would love to see a Monkey thrown in just for reference. :-)
    Not a regular
    Quote Originally Posted by ncj01
    I have done similar tests - albeit, not comparing bigwheel bikes to bigwheel bikes - but comparing bigwheel bikes with 26ers. For the same course on similarly equipped bikes, I have seen times as much as 14.5% (not quite 15%) better on the 9er. I think sometimes when a bike just feels "right" you feel like you can do no wrong.
    Nice write up rossixc.
    Not a regular
    Quote Originally Posted by Guitar Ted
    I've been thinking about travel too. I've got 4" in the rear and 80mm in front and sometimes I lock out the rear and/or don't properly set the negative pressure in the fork making the bike act more like a rigid. By the time I've figured out that I've just been riding for an hour without suspension, I've had a great time riding and never realized I haven't been using my suspension - unlike on my 26" wheel bikes. A 29er does lend itself very well to a full rigid. I'm on my way to having a 4" front/rear travel geared 9er and a full rigid 29 ss.
    The Duuude, man...
    Quote Originally Posted by ssmike
    I think I was mis-understood. I don't doubt for a second that the REAL times are being recorded. I'm quite certain that those ARE the correct and accurately recorded times from each run.
    What I'm saying is that the riding experience wasn't the same from bike to bike....and NO not on purpose...I KNOW he didn't go out there and sandbag on 1 bike and go hardcore on the other....
    nevermind ya'll...
    FS: Everything
    My gloves stink
    Reputation: Appendage's Avatar
    Active? What's that?
    Thank you for the excellent comparison, and all the time and energy you put into it. Much more scientific than the usual subjective drivel one reads in the magazines. I remember about 25 years ago (when I was young...), Cycle World magazine had a "shootout" of the four Japanese 125 MX motorcycles. They had the same 5 riders turn out several lap times on each bike at several different tracks. The combination of many riders, many laps, and several venues lead to a conclusion about which bike was easiest to go fast on (as opposed to which bike was fastest, or trickest, or whatever). And of course, they got absolutely fragged about their conclusion by the rest of the motorcycle press.
    Anyway, I'm going to embarrass myself by asking you (and anyone else who has an answer) what is meant by "active". Are you referring to the suspension? If so, I have never understood what is meant by an "active" suspension, "semi-active", and so forth. From context it appears to mean how effectively the suspension system soaks up the bumps. That is, the more active the suspension is, the plusher the ride. It also appears that fast guys prefer less active suspension systems. Is this because fully active suspension is more susceptible to biopacing?
    Here I am now- educate me!
    ~Appendage
    Wow great comparison - great comments back
    great stuff to read
    As a racer X rider and ex Sugar rider, I agree with the rear end stiffnss comments
    never been on a Lenz - can't wait to
    we all know changing just that one crucial item on your ride can make a difference. For me it was stiffness and tracking ability - that's why I went with the Titus, also why I will be buying a WB fork.
    Do I miss the longer travel of some of my other rides when I am on the Titus - not at all. It is a point and shot ride. Sure I am not going off anything over 2 - 3'
    Would I like it lighter - yes but at the sacrifice of lateral stiffness - no.
    I would love to see the aslyum in the mix (with a WB shock) Stiff like an X but lighter in the frame.
    Maybe Mike will let you use his wheels and a WB shock on all the rides and the would be apples to apples ( Ok grannysmith's to Royal gala's) But closer.
    Let me know if you need another tester - I'll be there!
    SS Pusher Man
    Reputation: mtnbikej's Avatar
    Sep 2001
    Quote Originally Posted by Bigwheel
    I don't find that the Fisher has a low bottom bracket.....at least not for the '04 model. I run 175mm XTR cranks and had hit the cranks only on a few select occasions. It is definately not a regular occurrance. I mean is 12.4" supposed to be low?
    mtnbikej
    Aug 2003
    Yep, it do
    Quote Originally Posted by mtnbikej
    mtnbikej
    The 12.4 inch BB on your fisher is higher than what Jason (rossixc) has on his '03, and for a 4 inch travel bike it is pretty low. The Lenz has a 13 inch BB height, and where Jason and I live (Grand Junction/Fruita, CO) it's just about perfect. Lots of ledges and rocks and step-ups on every trail, so if a bike has a low BB you notice it in the first five minutes.
    Perhaps you live somewhere that is a little more forgiving, or you're just really, really good at timing your pedal strokes to avoid rocks and such.
    MC
    Aug 2003
    I can't speak for Chad...
    Quote Originally Posted by 2melow
    ...but I don't think I would have been faster on his Titus. I was riding my Mooto-X YBB, not a hardtail, and my bike was 4lbs lighter than Chad's. For me that made all the difference as I was able to climb efficiently all day and spend as much or as little time out of the saddle as I wanted to. On the heavier, more active bike I would have had to spend more time in the saddle and I doubt I would have descended as fast as Chad even if I had rocket propulsion. I could be wrong, and it's just my opinion, but I think that if Chad had been riding my bike he would have been far, far ahead of me.
    Chad? Whaddya think?
    MC
    Aug 2003
    Less is more
    I'd never use a 4" travel bike for a longer race. ProPedal, SPV, call 'em whatever you want, they may pedal efficiently but there's still a lot of weight (primary drawback) and complexity (secondary drawback) involved. With 29" wheels, 2 inches of travel is optimum for any length xc race. My Moots gets a bit less than that, and my Lenz gets a bit more. For a race of any length I'd take the Moots every day of the week and twice on Sunday.
    YMMV.
    MC
    Tall Bird Legged Rider
    Comes down to comfort
    Quote Originally Posted by mikesee
    MC
    Yo, Mike, 2Melow,
    It is hard say if I would have been faster on Mike's moots. It was clear to me that on a climb, Mike could just ride away from me. But on the rougher stuff like descents and some of the flat areas I could make it up.
    I would not want to ride a hardtail/softtail for 14 hours. Maybe I am getting old or something but I really like long term comfort. Have done the Kokopelli 3 times in four days on a 29 hardtail and I got pummeled. To the point of not enjoying the ride as much. I might of been able to have an advantage early in the race on a bike like Mike's but as the hours wore on the fatigue would have slowed me down and taken some of the enjoyment away.
    To each their own, but you guys can have the softtails and hardtails, give me a FS.
    Chad
    Are those your legs? Or are you riding a chicken?
    Reply 3 and update
    First off, thank you all for the feedback and support. It truly was my pleasure to do this comparison I love to ride. In fairness I will be re-doing certain aspects of the comparison when time allows. From the outside looking in I can easily see how the comparison is flawed. When my fitness level has leveled out I will attempt a re-do as long as Mike C still has his Leviathan available – maybe we will do the rides together? Michael O, if you are around 6 ft. and live in the area we should ride together – I’m in Fruita.
    Appendage – what I mean by active suspension is suspension that is moving all the time and has minimal forces working against it to lock it out, either on purpose (platform), mechanical lockouts, or chain tension/pedal induced limits. Some riders view active suspension as energy sapping, I’ve been riding FS since ’89 and have come to enjoy the feel on certain bikes. That being said the new “platform” designs on certain designs works really well.
    Guitar Ted – Your question is one I have answered a while ago but am more than happy to speak to again. For fear of being blasted for my statistics… I will say generally that mathematically the work done by a 29” wheeled fork to move vertically 1” isn’t nearly as much as a 26” wheeled fork. So the answer to your question is no, for general riding we most likely don’t need 4” of travel or more on a 29” wheeled bike. Now freeriders that are jumping may still need/want that much, but the rest of the 29” equipment needs to catch up to them first.
    Mike C has stated 2” is all that is needed; I might go so far as to say that I really like 3”. Two people, two opinions, I’m sure there are more. These measurements work well for us and our riding styles. As much as I have fun on rigid, I have more fun with front suspension, and even more fun on full-suspension.
    Update – So yesterday I switched my BW 1.0 (coil) over to a BW .8 (air), on the Titus lowering the axle to crown 19mm in the process that increases the angles about ˝ degree. Made all the difference with the Titus. Took it for a nice ride up the Tabaguaeche and dropped down to Andy’s finishing on lower Eagle Wing. Just over an hour, but enough to know that the bike, as stated by Titus, is designed for 80mm of travel. Back to Guitar Ted’s question, no I don’t need any more travel than the 3” up front and 3.76” of rear wheel travel in the back of the Titus. What I need now is to spend more time getting used to the faster speeds I’m riding. I will be making some more lightening changes and when complete will post a picture for all to see. Also, I will be re-building my Fisher to do further comparison rides on for those interested, and just for fun I will be riding an Intense Spyder in the near future too for some further reaffirmation to see how the best 29” FS bikes are stacking up to the best 26” FS bikes.
    featherweight clydesdale
    Reputation: Fattirewilly's Avatar
    Dec 2001
    I was under the impression the rear of the RX only has about 2.8" in 29er version??
    Regardless, I love the effort you've put forth to do a worth while comparison. Thanks.
    rider
    I believe, like the Asylum, the RX has 2.76" of rear travel.
    I'm hoping to soon put up a review of my Asylum w/ 5th Element and a Marz Marathon SL. The 5th is pretty plush. The 5th was a good choice becasue of the adjustabiIity compared to the Fox PP. I'll be able to review the Asylum with a WB CX-1 if NJC01 ever ships it to me.
    The Duuude, man...
    Quote Originally Posted by TeamSwami.com
    I'm also pretty sure the Titus has ~ 2.75" of rear wheel travel. In light of this, and the added simplicity of the Moots softtail is why I decided to go with 1" on the YBB, and 2" on the seatpost and buy the moots.
    Related: CX-1 for sale...anyone? anyone? Bueler?
    Just kidding TS...should be at my house by the time I get home tomorrow...should be in mail Saturday...
    FS: Everything
    Dec 2001
    I'm also pretty sure the Titus has ~ 2.75" of rear wheel travel. ...
    I was actually hoping I was wrong.....anyhow, I'm taking one anyway!
  1. Gary Fisher X-Caliber, is it still alive
    By willtsmith_nwi in forum 29er Bikes
    Last Post: 06-16-2004, 05:58 AM
  2. Replies: 16
    Last Post: 06-02-2004, 11:12 AM
  3. Cheers for Titus!
    By Locoman in forum General Discussion
    Last Post: 04-14-2004, 06:26 AM
  4. Spider XVP or Racer-X
    By MTBeer in forum Bike and Frame discussion
    Last Post: 02-27-2004, 02:29 PM
  5. Schwinn Mesa vs. Gary Fisher Wahoo
    By niceride22 in forum Bike and Frame discussion
    Last Post: 02-24-2004, 05:37 PM
