Results 1 to 16 of 16
    Tire / rim combination UST/ Tubeless with no tire sealant?
    Hi folks,
    are there any tire / rim combinations available in the market, where you do not need to mess with any of the liquid tire sealant 8like from notubes.com, etc.), so basically "true UST"?
    Or is this simply not possible/ available?
    I am looking for a "install and forget" setup (besides the fact that I need to check on the air pressure and add some air after a couple of days/ weeks), but i don't want to mass around with any of the liquid tire sealant (liquid rubber, gum elastic, etc.) and the fact that you need to refill a bit every few weeks/ month.
    Another reason is to put in on my wife's bike and, well, it need to be easy in handling ;-)
    So, input/ feedback and tire / rim combinations with as much as possible hassle are welcome ;-)
    Always Learning
    Reputation: BruceBrown's Avatar
    Quote Originally Posted by omega1848
    Hi folks,
    I'm using NoTubes Flow rims with the yellow tape and valves, Maxxis LUST Ardent 2.25 and Maxxis LUST Crossmark tires with no sealant. Been running these since June with that set up. Tires should be for sale from Maxxis distributors starting next week or so. Related thread.
    <a href="http://www.flickr.com/photos/7166535@N05/4954319886/" title="Crossmark UST by singingsingletracker, on Flickr"><img src="http://farm5.static.flickr.com/4124/4954319886_97362e8e18_z.jpg" width="640" height="480" alt="Crossmark UST" /></a>
    BB
    Did I catch a niner+?
    You don't actually need the sealant. It of course is very helpful if your tire is very pourous or there are a lot of flat inducing objects on your trails. The tire should air tight seal to the rim, my rear tire a Captain 2Bliss has no sealant in it and is on a flow.
    Anyone experiences with the NoTubes ZTR Flow 29?
    Possible to keep them air tight only with the Stans yellow tape and the right set of tires, without tire sealant...?
    I'm just messing with you
    Reputation: wv_bob's Avatar
    Tubeless without sealant confuses me. If you run over a thorn and flat on the trail, you have to install a tube to get home, and then you either have to leave the tube in, patch the tire, or start using sealant. Seems to me if one is hell-bent on running tubeless, the sealant is a benefit because it seals the tire in case of a flat (usually anyway). Or, am I missing something?
    Chasing bears through the woods drunk with a dull hatchet is strongly not advised
    Its got what plants crave
    Reputation: Jim311's Avatar
    Feb 2006
    There are plenty of UST wheelsets (Easton Haven, Shimano, Crossmax, etc) but very few UST tires. There are several "tubeless ready" tires but you still need to run sealant in them.
    Ocala Mountain Bike Association - www.omba.org
    Reputation: Ronnie's Avatar
    For a long time, while still on 26" bikes and using true UST tires and rims, I was reluctant to use sealant in my tires. However I got tired of having to check tire pressure on a daily basis. There is always a small bit of leakage between the rim and bead. I eventually decided to try a cup of sealant in my UST setup and found it solved the problem as well as provide protection against small punctures.
    I believe my initial reluctance to use a sealant was due to a misconception that the sealant, being latex was sticky. I have only used Stans no-tubes. It is absolutely not sticky and is water based. It is very easily flushed away with plain water. It is also very easy to use. I usually mount the tire normally without the sealant and inflate it. I then pop a few inches of the tire off the rim, put a scoop of sealant in, replace the bead, inflate and done. If you use a valve stem with a removable valve, you can add the sealant through the stem without removing the tire.
    When I changed to a 29" this January, I was going through the same quandary. I really wanted a UST rim but there aren't any. (There are a few wheel sets but more for racing.) There are a few UST tires but not many. There are however quite a few TLR (tubeless ready) tires. They have a thinner sidewall than a UST and most of them require a sealant to retain air. A TLR tire has the same locking bead as a UST tire.
    I decided after much deliberation to get a set of Flow rims with No-tubes yellow tape and TLR tires. They inflate as easily as UST setups, with only a floor pump.
    Ronnie.
    The trouble with having an open mind is that people will insist on trying to put things in it.
    Reputation: shiggy's Avatar
    Dec 1998
    Hi folks,
    Bonty TLR rims (Duster/Rhythm, Race Lite), Easton Haven, Shimano XT wheels, are UST compatible.
    Some Bonty TLR tires do not need sealant. I use Mud X, 29-3 (rear) and FR3 dry. May be able to do the same with Geax TnT tires. Maxxis has new full UST models.
    The Bonty rims and tires seat and inflate with a floor pump. The Duster/Rhythm rims are very easy to tires off and on.
    mtbtires.com
    Always Learning
    Quote Originally Posted by wv_bob
    I'm with you on that and no, you're not missing something. In fact, with the Maxxis LUST prototypes I'm running on my Flows I mounted them up without sealant expecting to hit a thorn (like I do on all my non-tubeless tires that I have converted) that would give me a flat and I was then going to add sealant. That's what I said back in June when I mounted them up on my Flows. Well, here it is nearly November and I've maybe topped the air off 3 or 4 times since June (maybe not even that often).
    Trust me - I've tried to get a flat. I'm bashing through serious thorn territory where I usually get flats on my other tires, but all to no avail. I have not been able to flat the Maxxis LUST tires. I'm guessing the weight penalty of tires that are 835 - 900g have enough rubber in the right areas to prevent me from taking a thorn. Until I do - I remain sealant free with these tires. Pretty actually...
    Dec 1998
    I have never had a dry UST/TLR tire go flat on the trail because of a thorn or similar puncture. I have had the tire go down several days later and found thorns in the casing. Leave the thorn in during the ride (as if you would even know it is there) and it holds pressure.
    mtbtires.com
    Feb 2006
    I've flatted a few UST tires. Several due to snake bites from big hits on rocks due to poor line choice. Only one due to thorns/glass, but it probably would have torn the piss out of a standard tiire with a thinner casing.
    Any other combinations you can recommend?
    Dragging up an old thread....but the questions still remains: Are there any tubeless, NO SEALENT 29er tires out there? I ran UST tubeless with great success for years on my 26er. Had good luck with Stans fluid on my 1st 29er with Stans rims. Current 29er with WTB rims (two different sets) has been unreliable, impossible and dangerous (want to see the scar?) So....I want my UST tubeless back!
    I have only found Maxxis Ardent LUST, Crossmax LUST and Hutchinson Cougar. Any other options? Anyone have good luck with these without sealant?
    Quote Originally Posted by bradoemba View Post
    I know this doesn't answer your question, but I've never ever had a problem losing a bead on Stan's Arch or ArchEX rims. I'm 200-250 depending on condition and ride some pretty significant technical trails. My tire of choice has been a Maxxis Ignitor and I am trying out a set of Schwalbe RRs soon.
    As someone above pointed out, you can run this system without sealant, but...why? I ride distances long enough where your tire could go flat if it got even a small puncture, and there are plenty of opportunities here in the desert. The Stans is cheap and easy insurance.
    My recommendation - go back to the Stan's rims. They were on sale for $60 or so at Treefort for a while, but I think that's over now. I bought and built up four rims at that price!
    Jan 2009
    you should be able to use any UST rim with a UST tire without sealant and the bead and tire will stay sealed ... until you run over anything that could puncture the tire and succeeds in doing so. then you have to fix it. so what is the point of that? if you're not going to use sealant, just run a tube.
    regarding your experience with Stan's, you're in the minority. I have been running Stan's rims with various tires at low pressure without zero problems for a few years and I don't hear very many complaints of tires slipping off the rim except for extreme accidents or the use of tires that have beads that fit too loose.
    Thorn in your Sidewall
    Vassago Jabberwocky
    transmitter~receiver
    Reputation: meltingfeather's Avatar
    Specialized makes a UST 29er tire.
    Geax TNT tires work well without sealant.
    Which WTB rims are you using?
    Quote Originally Posted by pvd
    Time to stop believing the hype and start doing some science.
    29er Tire Weight Database
