Moots. It seems a Ti handlebar is hard to make. My LBS took care of the whole thing.
I was more bummed about the 20+ miles of single track that I bailed on than anything else.
Rider and Wrench
I have an old set of White Bros Ti risers, which are pretty neat, not too flexy but do offer a bit more damping than aluminum for sure.. but they are pretty darn heavy kinda overkill really. I also tried a set of 2nd hand Seven bars for my steel rigid bike to see if it might be a nice addition to the steel and squishy tires... ~15 deg bend 27" wide- 22.2 mm with a shim- they were so ridiculously flexy it was actually frightening. One of the reasons I like my rigid bike is how precise the steering feels, I was not looking for super flexy or suspension just a bit of damping. I went back to Carbon Easton's and now the Flat 685 Easton's They work great and were ~$99
The only thing I learned is IF I ever do decide to get bars or a frame made of ti... it will be custom, made for my size and ride style.
I Just wish I could ride more!
 Originally Posted by bdombrow
The only handle bar I have ever broken has been a carbon handlebar. I switched to titanium. On the plus side, the carbon bar had a uniform inside diameter and allowed me to put a stick inside to ride home (slowly).
I just don't trust carbon stuff on mountain bikes. I don't know about the rest of you, but I crash every couple of rides, and would have to replace carbon parts way too often.
Mark
 Originally Posted by netanimic
Damit they are hard enough to get without telling the whole world!
Indeed! Now it will take forever to get a second one.
Any new thoughts on Ti bars, and who is making good ones/
I think if I was going to full rigid like the black sheep/jones route I would consider it. But if you have a squishy fork or full squishy bike I would take the light weight of carbon or the low cost of alum. That's not to say they aren't good.
Carver makes a 710mm flat bar, that fits 31.8 stems without a shim. It's $99, which is pretty cheap compared to a Moots etc. I was tossing the idea of getting a Ti bar to match my Ti bike, but I ultimately went carbon because it's lighter. I was very close to pulling the trigger on the Carver bar though.
I bought their PryBar from bikeman a few weeks ago: 730mm flat bar, 9deg sweep, 31.8 stem, around 220g IIRC. So far so good, no noticeable flex to speak of.
Apologies for a picture of a 650b bike.
holymoly the syntace 12 degree is a wonderful improvement over the enve sweep bars from prior setup - your mileage may vary - as i learned how to ride how mileage with a Naked style bar which has 20+ degrees.
So does the bar feel better than an aluminum bar, or carbon? Is it comparable to carbon? It sure looks good, is certainly wide, and much cheaper than the Thomson offering.
- You may not post replies
- You may not edit your posts
Forum Rules
