Results 1 to 8 of 8
    May 2013
    Tektro HDC 300 hydraulic brake levers
    How do you adjust the "point of contact" on the Tektro brake levers? One lever closes in further than the other, I like for my levers to close the same.
    Reputation: Clicker1's Avatar
    May 2012
    You might want to try posting this question in the "Brake Time" forum.
    Reputation: Cenzobear's Avatar
    Oct 2012
    ^tis true.
    But to answer your question. You can't. The HDC300 is a very(and I emphasize VERY) low end brake. The only thing you can (just barely) do is bleed them. You won't get an adjustable point of contact until you get into high end SRAM/Shimano hydros. My HDC300s lasted 150 miles before the seals blew. I'd consider an upgrade if you're not satisfied with them.
    2013 Rockhopper 29- The hot rod fun bike
    2013 Stumpy HT Comp 29- The racin' machine
    May 2013
    Wow... Thanks, any recommendations? Slightly affordable recommendations?
    Oct 2012
    If the hydraulic aspect doesn't matter to you, then a set of BB7's will last a lifetime, are easy as cake to set up, and require almost zero maintenance and no special tools. Bout $120 for the set. You'll need new levers though.
    As for hydraulics, almost anything SRAM or shimano will be better. I have the Deores and love em. Those can be found for about $115 for the set, I believe Elixir 1's can be had for about $110 a set, but I'm not a huge fan of low end elixirs...
    Oct 2012
    Quote Originally Posted by eb1888 View Post
    Never mind my advice, get these and beset for years.
    May 2013
    Thanks, once I get a few more dollars, I'll pick up a pair. Awesome.
  1. Replies: 1
    Last Post: 12-02-2012, 03:55 PM
  2. problem with Tektro Draco hydraulic discs
    By bhc3223 in forum Brake Time
    Last Post: 11-02-2012, 08:25 AM
  3. Tektro Brake Levers??
    By Specialized-Nutta in forum Specialized
    Last Post: 01-12-2012, 11:09 AM
  4. Replies: 6
    Last Post: 01-06-2012, 09:34 AM
  5. Rebuild Avid hydraulic brake levers?
    By granpa in forum Brake Time
    Last Post: 04-08-2011, 01:18 PM
