Results 1 to 40 of 40
    Sep 2012
    Tallboy 2 C build , need some advise.
    Hey,
    I just got a 2014 tallboy 2 C and have a few ideas on how to build it but I would like some recomendations.
    Here is my list so far:
    Wheels : Flow ex with hope pro 2 evo
    Saddle: WTB silverado
    Fork: 2014 SID RCT3 120mm
    Drivetrain: X01
    Brakes: SLX
    Grips: ESI chunky
    Havent decided on seatpost and handlebar yet.
    Should I get a Dropper ?, 90% of my riding is XC with semi agresive XC downs.
    Is SID a good choice?
    Which BB is good and cheap?
    Thanks.
    Reputation: d365's Avatar
    The Sid or the Flows... seem out of place. IMHO
    Do you intend to race? How much do you weigh?
    Sep 2012
    Im 240lbs , I dont intend to race. I use Flows to keep the wheels stiff enough to hold my weight. Im 6 4". Do you think the SID will be too flexy?
    Clueless Bastard
    Reputation: WA-CO's Avatar
    Nov 2013
    It's OK to go an inexpensive route, but I think that frame deserves a touch higher component level...
    Post and bars are inconsequential, but I like nice stuff, so Thomson in both instances, dropper or not. I've had a WTB Silverado and thought it was a cheap saddle, mediocre at best. Step up to XT brakes. Damn near XTR and really really good. I guess the SID is fine, but it's purely an XC fork? I've one on my Niner, it's a touch springy.
    Cheap BB? Nah...That area (and that specific component) gets a huge amount of use and abuse. Put a King in it.
    See how easily I just dropped another 1K on your bike?
    What/where/how do you ride?
    Clueless Bastard
    Nov 2013
    Quote Originally Posted by cridom View Post
    Jesus Yes. My SID flexes under my Niner and I'm 165.
    A Manitou Marvel Comp is equal to a Tower Pro. It gives you more tuning options.
    An XT bb is fine as long as you clean and grease it periodically. I guess you would have to choose SLX triple crankset and a single n-w aftermarket ring.
    Yeah I would definitely go with a more robust fork. Something with 34mm> stantions. I'd go with a Xfusion Trace, or a Pike, depending on budget. They can be set to 120 or up. I'm 215 lbs and that's what I would do. 2
    Sep 2012
    I would love a 120mm pike but I dont know If it can be done by someone here (I live in Chile). I have a 100mm Tower pro and love it but It started creaking not long ago and I really hate the creaky stuff. So if SID is too flexy how about a revelation?
    Thanks.
    The Tower Pro may need to be serviced.
    Manitou Tune Spring Install - YouTube
    http://www.manitoumtb.com/assets/Ser...e%20Manual.pdf
    CRC has a 160mm travel Pike and will ship it to you for $16.
    You could get a couple parts and change the travel to 120. 51mm offset would be good too. It doesn't show on the CRC site.
    Has anyone reduced a 2014 Pike 29er down to 120mm yet?
    Shows the part number 11.4018.02--$38.
    RockShox Pike Air Shaft Solo Air 150mm Travel 26 / 120mm tTravel 29 A1
    So a little work to get things figured out but if it's in your budget a Pike would be my first choice.
    I would drop the Flows and build up a set of Chinese carbon 30mm inside hookless wheels. The width is better for sidewall support and grip in turns and climbing.
    Bead hook-less rims carbon 29er light bike rim tubeless compatible, outer width AM 35.00/30.00mm & XC 27.00mm - carbon rim (beadless) - Carbon Bicycle, Carbon Frame, Carbon Rims, Carbon Wheels, Carbon Wheelsets, Carbon Mountain Bike, Carbon Road Bike
    I just ordered from here. It was about 358 with shipping for two rims.
    EMBA Member
    Reputation: Ladmo's Avatar
    Jan 2013
    I'm very happy with the Revelation on my Tallboy, but I run 200 lbs geared up. Not sure what difference the extra 40+ lbs would make.
    Fat Skis/Fat Tires
    Reputation: rangerbait's Avatar
    Quote Originally Posted by eb1888 View Post
    +10 on the 120mm Pike. I converted one for my Czar build and couldn't be happier. It's a +/- 300 gram weight penalty over the Sid, but sooooo much stiffer and worlds better in the ride quality. Conversion took me maybe an hour, and that was being very methodical and meticulous because I didn't want to F anything up. Well worth the effort!
    I'm 6'4" and about 215...very happy to have the Pike under my fat ass!
    240?
    Pike or Float 34 FTW!
    Revelation probably marginally OK.
    Float 32 (but only the 120 chassis) probably also marginally OK.
    SID should be eliminated from consideration.
    Whining is not a strategy.
    Cactus Cuddler
    Reputation: tehllama's Avatar
    Jul 2013
    You weigh what I do - Float34 at minimum, but I'd way run the Pike even if it means you're running the alloy version of the frame. Seriously. Get the pike in 140mm, and use their modular "bottomless" plug set to reduce the travel IF you feel you need it.
    The SLX brakes are spot on, keep those. Might as well tack on the full SLX drivetrain, in 2x10 format, save for maybe splurging on an XT RD. That's what I run, and it is truly excellent.
    Dropper: YES. You want. Even the comparably cheap KS Lev is going to be great, the Reverb Stealth and Lev Integra are more in line with the overcall cost of a 2C. More importantly, you can run a nice commanding XC seat height for 90% of your right, and on those technical downs you can stow it out of the way and be able to place your mass over the bike properly.
    Fat Skis/Fat Tires
    Quote Originally Posted by tehllama View Post
    The bottomless tokens are just volume reducers that give you more ramp up at the bottom of the stroke; the travel reduction (and associated A2C reduction) is accomplished by swapping out air shafts.
    http://youtu.be/e69N6Pzt9HI
    Sep 2012
    So just the air shaft? how did you do it el castigador? 51 offset better?
    Fat Skis/Fat Tires
    Check out this link for the "how to" of it:
    http://blahblahbikeblog.blogspot.ca/...o-air.html?m=1
    Took me about an hour.
    Reputation: mint355's Avatar
    Mar 2012
    Have you thought about a carbon wheelset? Almost the same price as flow ex /hope. light bicycle rims 30mm wide with novatec hubs w/xd driver cost about $660 usd delivered also the SIDS will be fine for a 100mm xc bike I have pikes on my bronson and revelations on my TRc
    EDIT: didn't see the 240lbs bit go the lowered pikes just for more stiffness also carbon wheels will be a lot better than alloy flows for the extra $
    Trail Ninja
    Reputation: Varaxis's Avatar
    The Revelation has a beefier crown that definitely increases stiffness over SID. Their lowers also may come available with a 20mm Maxle. This may sound odd, but opt for the alloy crown steerer unit over carbon for increased stiffness if you go this route. The carbon CSU is less stiff according to SRAM.
    Not many choices for GXP BB to go with SRAM crankset and threaded bb. The stock BB that comes with the crank isn't bad.
    MTB B'dos
    Reputation: LyNx's Avatar
    At your weight, I'd definitely say make sure and get a 34mm stanchion fork, even at my paltry RTR weight of between 175-190lbs I used to notice quite a bit of for/aft flex on my Minute and steering precision was definitely no where as good as has been on the F34 and Trace I have used in the last 2 years.
    Sep 2012
    I decided to go for lowered pike, Im still not clear if I should get the 51mm offset one or the normal one. I think Ill stick with flows as I had them from another bike so I can save some cash. can you guys recomend a seat and handlebar not too expensive but good for long rides? where I ride normally the climb is about one a a half hours of 17 inclination and the rest then another 45 min or so of climbs and then all downhill from there . the trails are a bit rocky some small jumps and some techy parts nothing too gnarly. nevertheless its mainly riden by enduro riders. Ill post a video later today so you guys see what I mean.
    thanks
    Fat Skis/Fat Tires
    I decided to go for lowered pike, Im still not clear if I should get the 51mm offset one or the normal one. I think Ill stick with flows as I had them from another bike so I can save some cash. can you guys recomend a seat and handlebar not too expensive but good for long rides? where I ride normally the climb is about one a a half hours of 17° inclination and the rest then another 45 min or so of climbs and then all downhill from there . the trails are a bit rocky some small jumps and some techy parts nothing too gnarly. nevertheless its mainly riden by enduro riders. Ill post a video later today so you guys see what I mean.
    thanks
    Check out this thread for a discussion on offset and its impact on the "trail" number:
    Czar Fork
    I ran mt TBc with 36h Flow EX and a Fox 34 shimmed down to 120mm. I think people that haven't ridden a TBc don't give it much credit. It's a lot more capable than the 100mm rear travel suggests.
    I liked the Easton carbon riser that came stock on it at the time.
    I'd get the 51mm offset. If you're looking to save some cash, I'll be selling the 2012 Fox 34. Just haven't cleaned it up yet- just put a new 36 on my Lenz.
    OG Ripley v2
    Carver 420 TI
    Sep 2012
    Apparently no one dislikes the 51 offset so I may as well get it with offset. correct me if Im wrong but doesnt really matter if I get a 160 or 140 pike because Im switching the rod anyways to shorten it right? from what Ive read the only diference is the air rod and maybe less bottomless tokens on. By the way I wanna thank you all for the advise and steering away from the sid and directing me to the pike!. Its funny how things turn out, I was looking at the tallboy lt because of the option of using a pike but didnt want a long travel 29er , and now if I lower a pike (I didnt think it could be done) I will get all I wanted!!
    Fat Skis/Fat Tires
    Yep, same part numbers across all Pike platforms for a given wheel size, except for the air shaft...which means you can convert a 140 to a 160, a 120 to a 140, and all other sorts of unholy combinations.
    You will NOT be disappointed with the Pike.
    Here's my Czar with the Pike in 120 mode:
    Sep 2012
    Nice bike man!!! Ill post pics in a couple of weeks when all the stuff gets here.
    Unless there is a price reduction in getting the 160, I would get the 140. SC approves the use of a 140mm fork on the tallboy within warranty, if I remember correctly. Having the 140 airshaft as an option, could come in handy some day.
    Sep 2012
    You are right, I didnt think of that. any recomendation on where to get a Pike it needs to have international shipping.
    Rockshox Pike RCT3 29" Fork 2014 > Components > Forks > Suspension Forks | Jenson USA
    Apparently you can order the 120mm version from Jenson, but it's backordered.
    You could find out the wait time. I'm not necessarily recommending them, good or bad, but a quick search turned up the fact you can order it at 120.
    Reputation: borabora's Avatar
    Unless it has changed, I believe X0 uses carbon cranks. While I haven't heard complaints about them, at 240lbs I'd think about that. I don't know what you ride but how about a 1x10? Save a bit of weight and save yourself some money for shifter and front derailleur.
    Fat Skis/Fat Tires
    Quote Originally Posted by d365 View Post
    That's sound advice...I actually enjoyed the 140 on my Czar for the shakedown ride.
    Sep 2012
    Ok, Im ready to get the pike but I have a dilema. On one hand I can order it from Jenson as I have a coupon for a good discount and that way I can get the 51 offset one. on the other hand there is a store here who has one in stock but without a box and all the included stuff that comes in it. I dont know if this one is a 51 offset or not (is there a way to tell?) but the price is very similar, the only advantage is that its here is an easier purchase and dont have to wait. also El castigador did you put more bottomless tokens when reducing to 120mm from 140mm?
    thanks
    Fat Skis/Fat Tires
    Not sure how to measure the offset, and I added the recommended number of tokens per this chart as a baseline. It feels great the way it is, but you may want to remove one or two if you prefer a more linear air spring.
    Sep 2012
    Do you have the 51mm one or the standard one? I would like a 51mm from what I have read but is it a dealbreaker? if its not much diferent maybe I could just get the one here and save me the hassle of importing and duty payments etc.
    Fat Skis/Fat Tires
    I talked to Dave Turner about it, and he said the 46mm offset with the axle to crown of the Pike and the resulting headtube angle would make it too slow-steering. I don't know either way, but I do know of another guy on a Czar (CrashTheDog) with the 46mm offset Pike set to 120mm, and he loves it. Maybe drop him a line for more feedback.
    Sep 2012
    Thanks, is it safe to say the TB2c is similar to the Czar in handling right?
    Fat Skis/Fat Tires
    The TB2c wishes :-)
    Actually, I don't know too much about the TB2c, but for the sake of this discussion I think they could be considered similar.
    thanks
    Surely there's some fine print somewhere on the fork leg, stating if it's 51 offset?
    When I'm spending this much money on a singular item, I want everything to be just right. Like, I'd want all the items that come with the fork. I wouldn't take anything less than perfect, unless that other fork is significantly price reduced to make it worth it to settle for less. my opinion.
    Sep 2012
    Ok, after some thinking I went ahead and ordered the pike online, finally Jenson was selling the 120mm version solo air rct3 51mm offset!!!! so I wont be needing airshafts or anything. Now I need to decide on drivetrain, Is carbon gonna hold my weight fine? Im 240lbs and ride semi agressive XC type trails some enduro trails too. I like the idea of 1x11 for the simplicity and chain control. I was thinking all X01 and xx1 crank so I can get a 28T front ring. The climbing here is long and tough, some climbs are 25-30 % grades. If carbon is too breakable, can I get a light tough crank and use a 28T or something with 11 gears in the back?
    thanks
    here are some random thoughts from my research into 1x11.
    You can swap out the spider on the xo1 crank to hold a 28 ring too, using the xx1 spider. There are other choices such as RaceFace. Look to see if they list a weight limit, but in general, carbon is just as strong... just don't hit anything pointy.
    Pedaling the 28 ring will affect the TB suspension characteristics by chainline. Some will notice, others not. I think optimal is 32-34??? someone can correct me. So always riding the 28t may bother you, may not.
    If you look through the Sram forum on here, you will see people complaining about longevity of the 42 gear, and their chainrings. At 240 it's something to consider.
    As you can tell, I'm still on the fence about 1x11, because I would use the 42 a lot... I need me some granny gear sometimes, and they are really expensive cassettes. I would want to run a 30t, which would mean even more 42 gear usage.
  1. Nickle build... need advise!!!
    By saddle pimp in forum Santa Cruz
    Last Post: 12-10-2013, 05:15 PM
  2. Need Expert Advise For A Build
    By givati in forum 27.5
    Last Post: 03-09-2013, 10:39 PM
  3. Wheel build advise
    By thehotrodpig in forum Wheels and Tires
    Last Post: 01-19-2012, 05:08 AM
  4. Wheel build advise
    By KEITH21 in forum Wheels and Tires
    Last Post: 10-22-2011, 08:54 AM
  5. first build from scratch - advise, suggestions
    By sprocket47 in forum 29er Bikes
    Last Post: 03-22-2011, 08:08 AM
