Results 1 to 6 of 6
    two wheel whore
    Reputation: Shmoo's Avatar
    Sun Ringle / Stans adapters
    Does any one know if these are compatible, using their in-house hubs? I have a set of Flows and Charger Experts, each using their respective in house hubs. The Sun Ringles came with an adapter set, and I was wondering if I could use the front adapter on the Flows.
    While we're at it, which set is stronger? Not like I'll be holding back on either set, just curious.
    Sep 2014
    Did you ever figure out if they are compatible? I've read one or two people in forums state that they are but not enough to feel confident enough to purchase. I have Sun Ringle Charger Pro wheels and want to use my DT Swiss RWS 10mm Thru Axle, hoping that the Stans 10x135 end caps would work (Type II with only drive side threaded, just like the Sun Ringle hubs). My only concern is the width of each end cap, the Sun Ringle rear QR end caps are about the same width (within 1-2mm) but on the Stans the non-drive side looks wider than the drive side. Anyone have Stans end caps for the 3.30 QR able to measure the width (from where it touches the hub to where the dropout touches)?
    Jan 2009
    wrong sub-forum. there is nothing 29er-specific about this question. try the wheels and tires forum.
    Thorn in your Sidewall
    Vassago Jabberwocky
    squish, squish in da fish
    Reputation: fishwrinkle's Avatar
    lol, i'm sure he figured it out 3 years ago
    Jan 2009
    I was responding to the used who asked a question 6 hours ago, not the OP.
    Vassago Jabberwocky
    yeah me too
  1. Stans Arch EX, Flow, or Sun-Ringle Black Flag Pro?
    By PoisonDartFrog in forum 29er Components
    Last Post: 04-25-2013, 02:23 PM
  2. Stans 3.30 hubs with adapters
    By pcbliss in forum Wheels and Tires
    Last Post: 02-11-2013, 11:20 AM
  3. Replies: 10
    Last Post: 01-17-2013, 06:14 AM
  4. Sun Ringle vs Stans
    By jcmtbfreak in forum Wheels and Tires
    Last Post: 05-09-2012, 12:55 PM
  5. Replies: 1
    Last Post: 01-27-2012, 04:24 PM
