Results 1 to 8 of 8
    Sun MTX 33's tubes or tubless?
    How hard to run tubeless or should I ? and what would be good tires for speed nothing to big on rear 45mm or smaller that will work welll for a 60% road 40% off road but road being more important.
    Thanks for any replies, tires are a tuff one and there are so many to chooose from as prices vary so much!
    Administrator Administrator
    Reputation: rockcrusher's Avatar
    Aug 2003
    I have been running them tubeless with a ghetto conversion based on electrical tape and an old valve with WTB Dissents. They aren't the easiest wheels i have converted but part of that could be the dissents which have a wire bead and very stiff casing.
    I like the electrical tape style as it is A) cheaper than Gorilla tape by a magnitude and B) easier to build up in small increments.
    Try this: HTFU
    Thankyou,do you really like the rims?
    I also run them tubeless with Dissents, use the stans yellow tape, and would echo everything that rockcrusher said. If you're looking for something seeing a lot of road duty, you might want to look at something lighter than the 33 though.
    Aug 2003
    they are stout and stand up to a lot of punishment so far. I ride a lot of very rocky technical terrain on a rigid hardtail with them and they have stood up to all that my 200lbs can give them so far. I don't jump much or anything however so I can't talk about that but look up the photo posts by MikeSee and you will notice that his bikes mostly use them as well and he definitely hits stuff big and hard.
    Try this: HTFU
    thanks you all
    trail rat
    Reputation: slocaus's Avatar
    Quote Originally Posted by Realslowww View Post
    I think it would be silly to put a 45c tire, that is about a 1.8 inch tire, on that rim. Just makes no sense whatsoever! Plus it will widen the 45c tires to the point where it would likely rub if you have clearance issues. Then you would have to drop to a 38 to 40c tire. Don't do it.
    "The physician heals, Nature makes well" - real fortune cookie
    CCCMB trail work for trail access - SLO, CA
    Reputation: schnee's Avatar
    These rims are for monster huge tires, in the 2.25+ range, for doing very demanding riding. You want a much, much narrower rim. More like a touring rim. Not these.
  1. Geax Tubless Therapy ok to use in tubes?
    By Pollution Warrior in forum General Discussion
    Last Post: 06-23-2010, 09:16 PM
  2. How do I get the best from HS 33's ?
    By bill in forum Brake Time
    Last Post: 09-02-2005, 06:07 AM
  3. Magura HS-33's In GTA
    By gtiseb in forum Eastern Canada
    Last Post: 07-05-2005, 07:34 PM
  4. X POST - Beginners corner .. Tubless tire w/ tubes?
    By WeekendShogunWarrior in forum Wheels and Tires
    Last Post: 07-29-2004, 08:32 AM
  5. anyone use tubes fulltime on a tubless rim/tire?
    By SDtrailblazer in forum Wheels and Tires
    Last Post: 04-04-2004, 11:25 PM
