Results 1 to 3 of 3
    May 2005
    Sun Equalizer 27 Rim?
    Anyone have an experience with this rim? According to Suns website, this rim is available in 29er.
    Specs from Sun Website
    • TECH SPECS
    USE:
    CROSS COUNTRY/ ALL MOUNTAIN
    WIDTH:
    27mm
    BEAD WIDTH:
    25mm
    INNER BEAD WIDTH:
    19.5mm
    SECTION HEIGHT:
    18mm
    WEIGHT:
    482g
    Looks good, low weight, only .5mm narrower that the Rhynolite which is an awfully good rim.
    But, I'd be more attracted to the Equalizer 29 or 31 because of the increased width, 29.5 and 31.5 respectively, even though they are heavier but not excessively so.
    I run a 1.9 Karma on a Rynolite rim. I've had no problems running such a light tire and I weigh 200. Others who have used this tire have had problems and I'm sure the difference between their experience and mine is the width of the rim. What else could it be?
    More wider, more better. Enables the use of lighter tire which saves far more rotating weight than the difference in the weights of the rims.
    May 2005
    I have run other sun rims in the past, and have had no problems, but I was thinking of switching out my DT TK 7.1s for a wider rim. Thanks
