Results 1 to 3 of 3
    Stout 2.3 29er clearance with Karate Monkey fork
    Hi Guys
    Just found out my cheap suspension forks graze the top of my Stout 2.3 29er.
    Anyone know height and side clearance with a 29er Stout 2.3 and Karate Monkey rigid steel 29er fork.
    Need to know before trawling ebay.
    Thanks for any advice.
    Should be sufficient. Height is obviously enough as it is suspension corrected. I haven't seen a tire not fit that fork and the Stout isn't the biggest, but one of the biggest.
    Expert Crasher
    Reputation: GreenLightGo's Avatar
    My KM is in the middle of the row of 3 29ers. WeirWolf mounted on a Gordo - PLENTY of room. Dimensions are pretty similar on the Stout. Best pick I had which showed clearance.....
    Happiness depends more on the inward disposition of mind than on outward circumstances. Benjamin Franklin
