Results 1 to 7 of 7
    Reputation: Nocando10's Avatar
    Stans Notubes kit for Sun EQ25 Rims
    Could some one tell me what Stans kit needs to be used for Sun EQ25 Rims?
    Thanks,
    John
    Former Bike Wrench
    the EQ23 uses the 29er strip that is 26mm wide, I'm sure the EQ25 would use the same.
    Stans has 2
    29er Rim Strip
    Plus Four Rim Strip
    I cannot tell which one needs to be used.
    Thanks,
    John
    Reputation: Minimalist's Avatar
    After using Gorilla tape for about a year or so, I wouldn't bother using anything else. It's cheap, easy to install and works well. At least for me.
    Short-Change-Hero
    Reputation: gregnash's Avatar
    So here is a question regarding the gorilla tape tubeless.... do you find that it works with Wire Bead tires? Also, do you use cut out valves or do you buy the removable core valves?
    I'm using the removable core type of valves. The rims are WTB LaserDisc Lite (filled the channel with weather stripping) and tires are Maxxis Crossmark and the Geax Saguaro. All that with homebrewed sealant. Never had any issue that were set-up related.
    Former Bike Wrench
    Quote Originally Posted by gregnash
    Worked fine with IRC Mythos II 29er wire beads on WTB SpeedDisc AM tires. Can use tubeless valve stems or can cut out from tubes (often cheaper, q-tubes are $4 a piece and have removable cores).
    OP...the 29er strip, not the Plus 4 is what they recommend on the EQ23, it's only a 2mm difference to the EQ25 so it should be the one to use.
