Results 1 to 10 of 10
    Jan 2018
    Specialized rockhopper vs trek xcaliber 8 vs scott scale 980
    Best for XC?
    Mar 2015
    All fine. Get the one you like the way it looks or...
    1. Scott - Strength 1x11
    2. Trek
    3. Specialized - weakness - The specialized wheels and hubs on that model are garbage if you are bigger or ride on some rough terrain. I have had nothing but problems over time with those wheels and hubs. .
    Jan 2018
    1x11 vs 2x10 whats the main difference?
    Again, all of these bikes are essentially the same. You will only get I like trek blah blah blah, I like spec blah blah blah, I hate trek blah blah blah. Pick the bike that you find the coolest looking and go for it. But with you adding the scott in there. I agree I would go 1x11 vs the 2x10. Those are the gears. 1(front) x 11 (rear) vs 2 (front) x 10 (rear).
    And in looking at the bikes again I would go with the Spec. It has a threaded bottom bracket.
    Jan 2018
    I always rode 3x8 and now I wanted a XC race bike but I even sometimes go riding ad cruising on the streets. So which would be the best gear? And why?
    That depends on you, your strengths, you weaknesses, where you ride, how you ride and alot of other things. If you go by the current meta that 1x11 is the way to go. Less complicated with a similar gear spread. and I would have to agree with them. I ride single speed and 1x10.
    Jan 2018
    I used to play football so I have strong legs and a lot of stamina. I ride ever type of terrain
    Mar 2015
    Quote Originally Posted by Mtbmalta View Post
    While racing, you can get pretty messed up in your thought process. Simplifying that thought process and running the 1x11 so you only shift up and down can be paramount in a race when you get surprised by a climb and need to dump gears. I also prefer the way sram shifts and that you cant accidentally up shift too much and be in too big of a gear.
    Future upgrades would be lighter wheels, a 32mm fork and you are good to go for your race rig.
    Football as in Soccer?
    Jan 2018
    Yes soccer
    Mar 2015
    That will certainly help. There is a learning curve, but Having the fitness to play midfield is helpful for XC racing. Just have to get those hours in on the bike. I recommend following the XC racing and training section.
  1. Specialized rockhopper vs trek xcaliber 8
    By Mtbmalta in forum 29er Bikes
    Last Post: 01-10-2018, 01:24 PM
  2. Trek XCaliber or Scott Scale?
    By CaioB in forum 29er Bikes
    Last Post: 09-28-2017, 05:40 PM
  3. 2015 Trek Xcaliber 7 vs 2015 Specialized Rockhopper Comp
    By chewaz in forum Beginner's Corner
    Last Post: 12-23-2016, 07:31 PM
  4. **double post**
    By mike_yorkpa in forum Trek
    Last Post: 06-24-2015, 05:26 PM
  5. Replies: 1
    Last Post: 06-18-2013, 12:31 PM
Members who have read this thread: 9
