oooh, finally a good one of the Pegasus I had on the Nevi stand out at Eurobike.
Pic thanks to singlestoph, full build list here. 16lbs of fun :-)
Currently have an excess M Pegasus with ebb and cable guides available, if anyone's keen drop me a line. Otherwise the next run will be happening in mid-October for late November delivery.
Getting the correct colour match for the carbon fork is tricky as I really want to continue to use a powder coat for the frame, and obviously you can't powder coat carbon
accepting suggestions? what about a clearcoat "tint" over carbon weave?
if for example, the frame is a metallic blue, a blue clear over the carbon will make the fork play with the frame.
kind of the same way brushed ti and polished ti play off each other
If steel is real then aluminium is supercallafragiliniun!
Homebrewed components for chain ring and cog (29 * 18) with RS7 Middelburn, and full half-link chain. Special thanks to Simon from Singular and Jelle from Singlepseed.nl.
Yes, options, decisions. Red, black, silver? Can't really decide about red kings, silver kings or the silver Hügi is the right hub for the frame. So please help and keep in mind, if it fits it will change frame material soon. So here's another poor mans Pegasus from germany.
a sample of the bikes I had at Gnome Fest for demo rides. At one point, all the bikes were out. It was awesome! Next stop for the rolling Singular Demo fleet is the Brown County Breakdown near Bloomington IN. on Oct. 8/9.
Required Disclaimer: I'm the US Singular Guy - Bike Seller
Wanted: 180mm Isis Race Face Turbines. Got some?
That silver KILLS! Do that!
Oh man... you make me wanna go home and EZ-Off and polish my Titec H-Bar back to silver.
are the steel Singular's pretty rigid laterally? I am riding a VooDoo right now and it flexes a heap. How about the paint quality on Singular's? Do they hold up pretty well?
Looking to capitalize on Marty's sale right now and I need an answer
paint/finish has held up well with the 2 k of miles i've put on my gryphon... seems to have a great feel.... flexy but not to much... a great steel ride.... i'm about 200lbs
... but I have not noticed any lateral flex, or axial flex (unlike some other 29er steel bikes I have ridden) but the ride is nice and buttery. Then again, all I have to realistically compare it to is my MC29er... the only other steel mountain bike I have owned in the last 20 years.
Compared to my Haro Mary the Singular Swift is quite a bit stiffer. I set up both the Mary and the Swift with the same 1x9 drivetrain. The Mary would drop the chain or phatom shift when peddeling hard out of corners or going from unweighted to weighted. I couldn't ride that bike with out a chain guide. Not an issue with the Swift. Now I wish I had a rear hub that engaged faster. I think everyone that rides with me would also agree that I am faster on my Swift then I was on Mary.
Another Swift (this is the former Single Speed version)
Yes, it is versatile
Geared 3 x 9 (I bought it this way and rode a few months of local trails and one longer enduro event this way)
Fully rigid Single Speed
I also had it as a suspended single speed - very good. Just couldn't find a pic now (will post later if I found one).
This summer I rode a lot of AM 26" FS again and got a bit spoiled (too comfortable), and now I wanted to try this set-up with the Singular. Fully rigid, fixed gear, alt bars and 45mm Panaracer Firecross tires. This is going to be my winter commuter and/or "monster cross" type bike! Lovin' it already. Not sure if I am ever going to hit the technical trails with the direct drive though..heh. But it flies on the gravel roads and smooth trails.
100mm Reba works great for me! I had it set to 80mm and stretched it out. No real loss in nimbleness. I tried this on my Monocog29er and it was not happy. Front end got all floppy in the turns. It tracked weird. No such issues here.
I just scored another set of 180mm XTRs with a 5 arm compact spider. Once I sell a few more parts from the bin, I'm going to put together a gear and brake set I can just slap on and have a sweet geared hardtial as needed. Winter is coming up soon, and I don't really wanna take out the RacerX29er in the slop.
Has anybody tried using a front derailleur on this frame? There is a cable stop on the bottom of the BB shell, but it seems to be tucked too far under to keep the cable from sawing into the shell. It's also awfully hard to find a derailleur clamp shim for 30.0mm, but I can figure something out.
since my last post quite early in this thread, i have been getting in a few rides on my swift ...
what i found with mine is that i seemed to be sitting too far back and the front end was very light and it would understeer in anything loose especially at speed ... lining it up with my el mariachi i see the seat tube is a bit more relaxed in comparison, so i moved the seat forward about 1cm [no setback seatpost] and replaced the test 110mm stem with a 120mm one, and dropped it by 5mm ... stem is inverted and with the wide flat bars it rides really nice now, much more stable ...
currently it is setup with small block 8 tyres, 1x9 [32x36-12] and it seems to go much faster than the other two 29ers i have ... even the guys i go out biking with are grumbling now ...
