Results 1 to 13 of 13
    single speed conversion kit for dtswiss240 hub?
    does anyone know what the best single speed conversion kit is for a dtswiss 240 hub? Any help would be great, thank you!
    Warrior's Society
    Reputation: mtnbikej's Avatar
    Sep 2001
    More info needed......kinda vague question.
    I resolve to constantly assert my honest opinion on anything and everything - whether it is requested or not.
    Bucky the Cat
    well I have a set of wheels with dtswiss 240 hubs and stans arch rims but the rear hub is for a geared bike and im putting these on my redline monocog which is a single speed. all the kits online that i have found are brand specific i.e. will only work with shimano hubs or origin 8 hubs, so im asking if anyone knows of a universal high quality kit or a kit specific for dt swiss hubs?
    transmitter~receiver
    Reputation: meltingfeather's Avatar
    any kit that is shimano compatible will work on your DT hub. All it is is a spacer set, a cog (shimano splined), a lock ring, and usually a tensioner.
    i'd recommend that you get a cog with a wider base than the typical cheapo steel ones that come with kits... they won't gouge your freehub body. chris king & niner are two examples.
    Quote Originally Posted by pvd
    Time to stop believing the hype and start doing some science.
    29er Tire Weight Database
    davidcarson48
    Guest
    Surly's kit works well and their cogs are wide, too.
    Might as well go with the best.....
    Gearclamp
    http://gearclamp.com/
    HBC
    http://www.homebrewedcomponents.com/...ategories/cogs
    Chris King COG
    FTW!!!
    Mar 2005
    wow, that gearclamp looks awful.
    Quote Originally Posted by Cleve Lansteamer
    why? do you think its not quality?
    +1
    I use the Spot Brand spacer kit with a Homebrewed Components cog on my 240s.
    You know what looks awful? A damaged rear hub due to COG gouging because of cheap POS COG spacers.
    Get a steel cog like King or Surly and use any spacers... you can even use ones from old cassettes.
    Reputation: ianick's Avatar
    I'm currently using a Surly cog and generic ebay spacer kit on my DT240 rear hub. Works just fine. No need to get fancy with the spacers unless you want to. I would however opt for the wide based cog. ISAR's cogs are nice and have a nice wide base.
    Reputation: dblvanos's Avatar
    Dt swiss 240 hub, surly spacer kit, HBC cog, it's like butta
