Results 1 to 22 of 22
    locked - time out
    Reputation: hygieneboy's Avatar
    Single Speed 29er choices, Rockhopper vs Stumpjumper vs RIG
    http://www.specialized.com/us/en/bc/...cname=Mountain ($2600) MY2011
    VS.
    http://www.specialized.com/zz/en/bc/...8&menuItemId=0
    ($1100) MY 2010
    Why $1500 more? I see a few upgrades on the fork/brakes/wheels/M4vs.M5 frame ect. Why so much more for such a similar bike? What's the weight difference? SJ-2 lbs lighter maybe?
    I was also looking at the new Trek/GF RIG coming out in November that looks like a nice compromise in the middle.
    http://www.trekbikes.com/us/en/bikes...hardtails/rig/
    ($1500) MY 2011
    I had an older Rockhopper SS 29er that I regret selling and I am looking for another SS 29er. Are there any other good front suspension light single speed 29ers I should consider? I bought a Motobecane SS ( Dart-3 fork/sliding dropouts) 29er a few months ago. It works well on pavement but feels like a tank off road.
    Dirty South Underdog
    Reputation: Andrea138's Avatar
    Niner One9! I loooooooove mine!
    Brickhouse Blog (most known unknown)
    Just Riding Along- best internet radio show on Mountain Bike Radio
    4 Niners
    Dec 2008
    One9 if you want a racing bike. Sir9 if you want a comfortable bike. I have 2 Sirs, one is single speed with Niner Carbon Fork and the other is geared with Fox RL29 fork. I can swap the forks by removing the front brake lever, loosening the stem bolts and taking the top cap off each bike. (remove 3 bolts and loosen 2 bolts per bike) In order to do this, I had to use the same brakes on both bikes (Juicy 7) and the same headset on each bike (Cane Creek Orbit X). I move the wheels and all since the big cushy Weirwolf goes better with the rigid fork.
    Anyway, having ridden all four combinations; for all but the worst courses, the SS sir with the rigid fork is the bomb. That combo with not particularly light parts weighs 22 lbs. and the geared hardtail combo weights 26 also with not particularly light parts. Also, I highly recommend the Syntace P6 400 mm seatpost to go with the other parts.
    I have read several other threads on this forum regarding the difference between the Air9/Sir9/Air9Carbon. Basically the carbon and aluminum bikes are razor sharp but also ride accordingly (U can search to find various other threads). The Specialized bikes are similar to the Carbon and Scandium Niner offerings. if you race then you need to look at the stiff bikes, but if you are like the majority of cyclists you will find joy in riding a plush steel frame and you will actually ride more too.
    Powered by ice cream.
    Reputation: Enel's Avatar
    Seems like you get a lot for your money with the Rig.
    I just picked up a VERY gently used '10 RockHopper SS (like the one you linked) from a guy who wanted out of it after buying it too big. In fact, it still had the tag on the front skewer. Originally I wanted a geared 29er to try out the big wheels, and was also looking at a BikesDirect purchase of some sort. When this guy offered to sell it to me for $500, I couldn't say No.
    Turns out, I dig the 29er and the SS. Even am considering selling my FS26 inch and getting a geared 9er also. The RHSS being the cheapest of the three you linked, I would definately say to go with what you know. You had one before that you liked, right? The Rig IMO, is a similar choice, and probably $400 more due to the Fox Fork. Worth it? You decide.
    I guess it really comes down to what kind of riding you will be doing or how much you WANT to spend.
    Good luck with your decision.
    aka "SirLurkAlot"
    If possible, test ride them even if it's in the parking lot. You may find that one works better than the other.
    I think that the Rig is a great value but.... you may or may not care for the geometry. I owned a first generation and did not like it. Most love it. The way it handled bothered me the most but we also couldn't stop the EBB from creaking. I have owned other EBB equipped bikes with zero issues. I ended up selling my frame and using the parts which are a great value for the price point.
    I'm not knocking the Rig. Just keep in mind that everyone rides a little different, has different dimensions, etc and not all bikes fit as well as others.
    YMMV
    Expert Crasher
    Reputation: GreenLightGo's Avatar
    Quote Originally Posted by hygieneboy
    The SJ has better components all around, not to mention the higher grade frame alloy.
    It would probably cost that much ($1500) to drop a good 2-3 pounds from the Rockhopper anyway.
    Happiness depends more on the inward disposition of mind than on outward circumstances. Benjamin Franklin
    Lurker
    Rockhopper SS Frame only (MSRP showing $440) & build it to suit you. BB7's, eBay Reba Race, Hope / Stan's wheelset, etc & you can be under $1500.
    --0--
    Reputation: BikerDude001's Avatar
    Jun 2010
    An interesting thig most people overlook on the Rig is that I comes equipped with cable stops for front and rear derailleur in case you want to go 1X9 or fully geared in the future. I just think it adds to the flexibility of the Rig design. If I were to buy one of the three I'd go with the Stump 29er SS. I think with the component spec you won't want for anythig and you can get them for $2100.
    Aug 2010
    the 2011 rig gets rid of the ebb so that is no longer a issue.
    At Work
    Reputation: sxr-racer's Avatar
    Quote Originally Posted by hsakkire
    YMMV
    2011 Rig's use a standard Bottom Bracket now and sliding dropouts.
    TREK EX9 27.5
    NINER MCR 9 (Moondust)
    2009 Gary Fisher Rig
    locked - time out
    Does anyone have first hand experience with the split shell EBB's on the Specialized bikes? How easy to adjust when you change cogs/chain stretch ect. Any slipping/creaking issues?
    I don't huck.
    Jun 2005
    My friend and I likely have around 50 hours or so on two different split shell Specialized frames with no slipping, creaking, etc. It is dead simple to adjust. Just need an allen wrench.
    Blog Ramblings
    West Coast writer for twentynineinches.com
    Here...maybe this will help with your decision.
    http://twentynineinches.com/2010/04/...-final-review/
    At Work
    how the heck do you navigate that site. Looking for a GF RIG Review?
    TREK EX9 27.5
    I don't huck.
    Jun 2005
    Quote Originally Posted by HalFliP
    I will mention that the 2011 Rocky SS frame we are riding now steers much better/less flex with my own wheelset and the Recon fork.
    Quite a difference.
    Blog Ramblings
    Yah....That site is not the easiest to get around. I found that link somewhere and it took me right to that page. Guess I was lucky.
    Rigid in Evergreen
    Reputation: topmounter's Avatar
    Jul 2003
    After having my large Air9 for almost a month now, I'm still surprised when I see people describing the Scandium Niner frames as "harsh".
    Did I catch a niner+?
    Rig is always a good choice to start on a SS you get a lot for the price. Only thing is G2 geo so if you plan on swapping the fork later on you might not like the new angle. I saw the Bonti Switchblade this weekend on a Superfly (gnomefest) which is setup G2 and looked nice.
    locked - time out
    Wink
    Well after checking availablity at my local dealers. The GF/Trek Rig will not be available until late November/December......maybe??
    The Rockhopper SS is not available anymore as a complete bike(frame only). They had limited size availability for the 2010 (gray anodized) Stumpy SS ($2400)
    and they had lots of availablity for the 2011 (bronze anodized) Stumpy SS ($2600)
    I haggled and haggled with my LBS and decided to order a gray 2010 Stumpy. The specs list looks identical between years only with the color and model year difference being $200. I got it for $2100 Now I'll just have to wait 2-3 weeks ;(
    At Work
    where are you located, what size you looking for. Bike shop I bought my 09 Rig from has some 2010's
    TREK EX9 27.5
    locked - time out
    Large (19") Central Florida
    The 2010 RIGs had notoriously problematic slipping/creaking EBB's and a horrid paint scheme.
    I had my eye on 2011's with a better but still interesting paint scheme (sliding dropouts)
    But I already gave up the credit card numbers to order my Stumpy so it is done!
