    Reputation: JNR0790's Avatar
    Jun 2012
    Scott S cale 29 Team vs Cannondale Trail SL 29ER 2
    these are 2 bikes im thinking about buying. i just wanted to get some opinons on each bike.
    Scott Scale 29 Team:
    Frame: Scale 29 Alloy 6061, custom butted superlight tubing, forged race disc dropouts PM160, bridgeless seatstays, Integ. Headset, replaceable hanger
    Fork: Rock Shox XC 32 TK 29 Coil, Alloy Steerer, remote Lockout, rebound adjustable, 100mm travel
    Headset: Ritchey OE 1 1/8, semi integrated 44/50mm
    Rear Derailleur: Shimano SLX, RD-M663 SGS, Shadow Type, 30 Speed
    Front Derailleur: Shimano Deore, FC-M590-10, 34.9mm
    Shifters: Shimano Deore, SL-M591-10, Rapidfire Plus, 2 way release, w/gear indicator
    Brake Levers: Shimano BL-M445 Disc
    Brakes: Shimano BR-M446 Disc, 180/F and 160/R mm Rotor
    BB-Set: Shimano ES25 Octalink, 68-118mm
    Handlebar: Scott Hot Rod T OS 31.8mm, T shape Flat, 680mm, 9 bend
    Stem: Scott Comp, 4 Bolt, OS 31.8mm, 1 1/8, -6 angle
    Pedals: Wellgo C128
    Seatpost: Scott Comp zero offset, 31.6mm
    Seat: Scott Racing
    Front Hub: Scott Team Disc CL
    Rear Hub: Shimano FH-RM66 Disc CL
    Chain :Shimano CN-HG54
    Chainring: Shimano FC-M522, 42Ax32Ax24T
    Cassette
    Shimano CS-HG62-10, 11-36 T
    Spokes: Stainless Black 15G, 1.8mm
    Rims: Alex XC-49 Disc, 32H, Eyelets
    Tires: Schwalbe Rocket Ron, 29 x 2.25, 67EPI, Kevlar bead, Performance Serie
    Weight: 12.50 kg / 27.53 lbs
    Cannondale Trail SL 29ER 2:
    Frame: Trail SL 29'er, Optimized 6061 alloy, SAVE, 1.5" head tube
    Fork: RockShox Recon Silver TK 29, 80mm, Solo Air, lockout, rebound, 1.5"
    Crank: SRAM S800 3.1, 44/33/22, 175mm (M,L,X)
    Shifters: SRAM X5
    Front Derailleur: SRAM X5
    Rear Derailleur: SRAM X5, 10-speed
    Hubs: Formula CDH20 front, Formula CDH22 rear
    Tires: Kenda Small Block 8, 29x2.1"
    Pedals: FPD Platform
    Brake: Avid Elixir 1, 160/160mm
    Handlebar: Cannondale C3 riser, 680x20mm, 6061 alloy
    Stem: Cannondale C4, 1.5", 31.8, 7 degree
    Headset: Tange 1.5 Custom
    Brake Levers: Avid Elixir 1
    Spokes: Stainless Steel, black, 15g
    Grips: Cannondale alloy locking grips w/closed end
    Saddle: Cannondale Stage 2
    Seat Post: Cannondale C3, 31.6x350 (M), 400mm (L,X)
    Bassmaster
    They are both good bikes. I have the Trail Sl3 29er and love it but it may not be right for you. Ride them both and see. My LBS wanted to put me on the scale team but they are unavailable on backorder. So if you currently have a bike and want to wait for it then get the scale. IMHO you can't go wrong with either one.
    Jun 2012
    Quote Originally Posted by fat1 View Post
    well which ever i get i have to wait a couple of weeks...i guess the main difference for me is the fork idk which would be better
    Bassmaster
    the fork on the cannondale will be lighter and the scale has more travel so
