Results 1 to 13 of 13
    Saddle to Bar Drop 29er XC Hardtail
    Just curious what other people are running in terms of saddle to bar drop on their xc hardtails. I just flipped my stem (- 6 degrees) so I now have a little less than 1" of drop from the top of my saddle to the top of my bar (when I flipped my stem I inserted a 5mm spacer below the stem). Had to move to a 10mm shorter stem to compensate for the additonal reach triggered by flipping the stem. Will give it a whirl tomorrow to see whether the 1" of drop works for me. Felt good just spiinning around in my back yard.
    How much drop are you running and what advantages do you think you gain by setting your bar height below your saddle height (or parallel / higher as the case may be)?
    Reputation: Noclutch's Avatar
    Jun 2010
    Some good fitment stuff should come from this thread. subscribed
    mvi
    mvi is offline
    I recently lowered my bars 60 mm and now have a drop over 120mm. I expected back-neck pain and gor dramatically better handling. Can ride for >2 hours before the back acts up. Worth it for XC racing. 6:5" rider/
    Jun 2010
    Quote Originally Posted by mvi View Post
    stretch more. work on flexibility.
    mvi
    mvi is offline
    stretch
    Quote Originally Posted by motorbacon View Post
    I am already too flexible in the low back. core strengthening might help more , but at 53 y/o bodies are starting to fail as you one day might find out.
    I was just surprised by the better front end loading and improved handling with the low bars.
    dru
    dru is offline
    I've got my bars around 2" lower than my seat on my 29er. I too am 6' 5" and am not flexible at all, but can touch my toes. I run my 26er bars at the same height which is a super comfortable position for me. On both sizes I've got just enough weight on the front to make the tire stick and no more. I'd never consider running the bars anywhere even with the seat.
    Drew
    occasional cyclist
    Let the Sun Shine In
    Reputation: canyonrat's Avatar
    0 drop is happy land lately for me. Fit is very personal and changes over time, fitness level, age, riding style, and preferred terrain... All good if it feels good to you.
    thecentralscrutinizer
    Reputation: mopartodd's Avatar
    I have right around 1.25" on my 29er which is a little less than what I have on my 26.
    2012 Niner Air9
    2011 MB Le Champion CF
    2009 SE Racing SoCal Flyer
    2003 TiSport Gman
    Abby Normal
    Reputation: Holmes's Avatar
    I generally run the bars with zero drop or a skosh above the saddle. On a rode bike I have no issues with neck / back pain running lower, but off-road where I am up out of the saddle a lot my lower back gets pretty hammered after awhile.
    Did I catch a niner?
    I'm almost even maybe a little lower bar but I have tried going lower and the bike seems sluggish when it turns. I have gotten too comfortable at this position.
    I was under the impression that if you get back pain you should try lowering as you may be trying to support yourself upright too much and not getting the proper flat back.
    https://www.dollarshaveclub.com/ref/...A0CC/s/tx/cx/1
    Reputation: Mojo Troll's Avatar
    Quote Originally Posted by Mr Pink57 View Post
    Do you happen to ride with a hydration pack most of the time?
    Rocks&Drops
    Oct 2011
    I tried at least 6 different length/ rise/ bar combo's on my new 29er. My LBS has great service; if you don't suff it up you can try different combo's until you find what you like. I took a lot of time to swap out stems every two laps on three different courses before I found what worked best; the time was well worth it. Nailing the right fit makes a huge difference in how the bike handles. 580 to 620 length bars were far more stable in technical terrain than wide bars, but 680 bars we're more comfortable. The narrow bars were better for trails with narrow passing between tree's, and we have our fair share of those here.
    I demo'd on cheaper alloy bars but ordered Easton EC70 with a 40mm rise, which is what I need to get my hand contact height to the best position, which is within mm of saddle height. I'll cut them down to 630mm and ride that for a while, but from what I've learned so far, I'll most likely cut them down to 600-620mm in the end.
    For technical riding with rocks and drops, each time I increased the height of the bars I got faster and more stable handling on the rocks/ drops/ roots/ logs. Bars are now even with saddle. I'm 6'2" with long legs/ arms. For less technical single track around a .5 to 1" saddle- bar drop seems to work well, but not that much better than bars even with saddle.
    I was pretty diligent with my trials, noting feel of stability deep into berms, control on turn in and exit, climbing/ descending switchbacks, and climbing descending steep rocky stuff.
    bar drop
    I am around zero drop- might actually be something like 5mm rise.
    When I got my 1st 29er I was convinced that I needed to match position from my 26 inch bike. (I was about 4cm drop on 26 inch). Mainly I thought the front end would squirm on steep climbs if my bars were higher.
    Tried that and 29er rode like poo. Worked my way up- now I am riding a -6 degree stem with low rise bars- Syntace Vector- 1cm or less rise. No spacers under stem.
    Bike works perfect- very easy on my body. I may bend my elbows slightly more than I used to but position is powerful and handles great.
    I think many people tend to overthink this.
  1. Replies: 3
    Last Post: 10-20-2011, 05:33 PM
  2. 6'1" top tube length and saddle to bar drop?....
    By dirtrider7 in forum XC Racing and Training
    Last Post: 04-27-2010, 04:17 PM
  3. Saddle to bar drop issues on Scalpel...
    By nathanbal in forum Cannondale
    Last Post: 06-28-2009, 08:30 PM
  4. What is your saddle to handlebar drop?
    By Sk1nnyGuy in forum General Discussion
    Last Post: 11-28-2006, 05:23 PM
  5. Saddle-to-bar drop?
    By Dave in Driggs in forum XC Racing and Training
    Last Post: 04-25-2006, 12:50 PM
Hot Deals
Contests
Latest Mountain Bike Articles
