Results 1 to 11 of 11
    Road drop bar on 29er...
    I know this is a niche question..but for the those that have gone there, can you post your set ups?
    I am not speaking of mtb specific dirt drops, but rather prefer the ergos of a road drop bar with road levers on a 29er. Not interested in a cross bike btw.
    I ride my 29er mostly on paved roads...and limited amount on groomed dirt. Speed is the reason for my inquiry.
    Can you speak to using road drop bar levers that will shift Sram or Shimano driveline that are compatible with Avid BB7 disk brakes?
    Many thanks.
    Jan 2009
    Check out the Salsa Fargo and search this site for Monstercross
    Thanks. What I like about the Salsa Fargo is the substantial stack height which is greater than a typical flat bar 29er to compensate for the lower drop bar position.
    I bought one size smaller frame to reduce the reach. I also have a set of skinny wheels with cross tires for rail trails etc.
    Thanks for the pic. Looks like the woodchipper bar or similar. The ergos of a dirt drop just don't suit me. I am a roadie but own a flat bar 29er. Gotta love the versatility of the Fargo. Kudos to Salsa...great company...I have that rigid fork on my Ti 29er and a Salsa flatbar...for releasing a bike that can be ridden everywhere.
    PS: general issue with mounting a dropbar on a typical 29er is...the geo isn't as suitable as a dedicated drop bar bike. Top tube is generally too long on a flat bar bike and head tube too short. Believe if I were to adapt a drop bar even with short stem on my 29er, I would be too stretched out. The Fargo of course is designed for a drop bar and more conducive.
    Jul 2013
    AZ
    AZ is offline
    Reputation: AZ's Avatar
    Quote Originally Posted by dirtrider7 View Post
    Many thanks.
    BB7 road calipers work with road levers, I believe that 10 speed SRAM stuff works together. 9 speed Shimano parts play well. that's the setup I use with a Voodoo stem and Short and Shallow drop bars.
    Big Damn Hero
    Reputation: CBRsteve's Avatar
    I'm strongly considering doing this to me Orbea Alma but the whole reach issue you guys are referring to is making me a little hesitant. I have a 90mm stem on the bike now and if I was to put something like the woodchipper bars on, could I mitigate the problem by putting on a shorter stem? Maybe something like a 40mm stem?
    Life is like riding a bicycle. To keep your balance you must keep moving. ~ Albert Einstein
    Reputation: Nakedbabytoes's Avatar
    I put on on my Pugsley, Woodchippers with Tektro levers(not intergrated).
    Woodchippers work better if above saddle height as they are designed to be ridden more in the curl area and not tops or hoods. They are **okay** as far is getting more aero but I didn't think they gave me more hand positions than my Jones Loops and the angle wasn't as good, so I went back. Not road curls necessarily but other than the angle flaring out, pretty similar to my ProMoto2s on my Colossal, which are.
    I realize fat isn't 29 necessarily but once you measure in the tire outer circ, it is close to my 29er Karate Monkey, which is why I responded. Dunno if I helped though.
    2014 Big Dummy
    2015 Salsa Beargrease Carbon 1
    2015 Ice Cream Truck
    Big Damn Hero
    Dude that bike looks straight out of Mad Max.... ^^^
    Awesome!
    1*14*29*2.1 & 1*1*29*2.4
    something I did was use a shorter AC fork which steepens the angles and lowers centre of gravity and BB height which made the frame a lot more road bike like. I also used a frame one size smaller, with 50mm stem. If you use a road bar I'd personally go wide and shallow drop. I am using road bb7s with shimano levers, and it works OK. I do find it a bit spongy and the lever goes nearly to the bar before grabbing. There aren't too many other options though.
  1. Bored? Post your Drop-Bar 29er!
    By CLONG in forum 29er Bikes
    Last Post: 07-19-2017, 06:09 PM
  2. Drop Bar 29er SS?
    By jddjirikian in forum Colorado - Front Range
    Last Post: 12-03-2011, 09:49 AM
  3. Problem w/shifting rear axel on an old drop-out-mount derailleur road bike.
    By Metamorphic in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 05-22-2011, 02:35 PM
  4. BB Drop on custom 29er
    By bootsie_cat in forum 29er Bikes
    Last Post: 05-18-2011, 05:32 AM
  5. Shedfire's New Off Road Drop Bar
    By Guitar Ted in forum 29er Bikes
    Last Post: 04-12-2011, 06:26 AM
