    R.I.P 9 with 34 Talas 150mm???
    Hi everyone!
    I read this on Niner's website: "The R.I.P. 9 is intended for 120 to 140mm forks, allowing riders to further fine tune the ride".
    Niner is offering a custom build on their website, and one of the fork options is a Fox Talas 34 150mm travel. I couldn't find this fork anywhere on the web, not even on Fox website where the most aggressive 29 fork offered is the 34 Talas 29 with 110-140mm travel.
    Do you know if this Fox Talas 34 150mm is made by Fox especially for Niner, or maybe there's a mistake on Niner's website and that Fox Talas 34 150mm is actually the 110-140 Talas, since "The R.I.P. 9 is intended for 120 to 140mm forks".
    If it's really a 34 Talas 150mm, do yo know if it's 120-150mm travel?
    Thanks, Mo.
    Carbon & Ti rule
    Reputation: muzzanic's Avatar
    I know the latest Fox 34 Float could be adjusted out to 150, I didn't know if they had made the Talas so it could be done .
    Quote Originally Posted by mo6500 View Post
    Hi everyone!
    Thanks, Mo.
    I have a 6 Berth & 2 Berth Motorhomes that I rent out . They are based in Tauranga, New Zealand
    Only 2 Fox 34 29 forks both up to 140
    34 FLOAT 29 140 FIT CTD w/Trail Adjust
    Weight
    15QR (includes axle)
    4.49 lb / 2.04 kg (1.5" taper steerer)
    Travel
    5.5 inches / 140 mm
    Steerer
    1.5" taper aluminum
    Adjustments
    Climb/Trail/Descend (3 positions)
    Trail adjust tuning range (1, 2, 3)
    Rebound
    Air spring pressure
    Full product details
    Technology
    FIT (FOX Isolated Technology)
    Kashima Coat
    15QR
    34 TALAS 29 140 FIT CTD w/Trail Adjust
    Weight
    4.68 lb / 2.12 kg (1.5" taper steerer)
    Travel
    4.3 inches / 110 mm
    5.5 inches / 140 mm
    Steerer
    1.5" taper aluminum
    Adjustments
    Rebound
    Air spring pressure
    TALAS 2 position travel adjust
    Technology
    Kashima Coat
    15QR
    ... and if we just ... FOX does make a 34 Talas 150MM...and it is the sh$t
    I believe they are only making as an OEM fork and it goes to bike companies only.
    I have see images of it on a 2014 spec. ENDURO 29er and if you look on the Intense FB site you can fine an image of a T29 with the special order option of a 150mm 34 talas.
    I hope that helps. It does and exists and it does complete a long travel 29er very well...
    Obie
