Results 1 to 37 of 37
    Apr 2013
    Question about making the switch to a 29er
    I currently have a trek fuel ex-8, looking at a Trek superfly elite 100 gary fisher collection carbon 29er. I have read all the advantages of the 29er however it seems a bit harder to pedal uphill. But this bike was build for xc and it weighs 7lbs less than the fuel. Should it be about the same then? Thanks!
    Climbs = necessary evil
    Reputation: rogerfromco's Avatar
    Re: Question about making the switch to a 29er
    I don't know these specific bikes but I made the switch last fall from a SC Nomad to a RIP9. The Nomad had a 3x10 gear set and the RIP9 has the 2x10, which was harder to pedal at first but within a few weeks I had adapted.
    Sent from my Android - because Carrier Pigeons are slow!
    Feb 2013
    we are 29ers. you must adapt. resistance is futile.
    Mar 2013
    Quote Originally Posted by BMSrider View Post
    It most likely is harder due to higher gearing.
    WillWorkForTrail
    Jun 2012
    I doubt being a 29er has anything to do with it being harder to pedal up hills. Like others said, I think it's just gearing. Although if the front and rear are the same number of teeth as you're used to and you're saying it's harder, then it IS because it's a 29er - you effectively have more gear inches because of the larger wheel.
    MTB B'dos
    Reputation: LyNx's Avatar
    I'd honestly like to know the weak little fvck who started this myth how many ever eons ago Yes 29ers are harder to accelerate up hills, that why when I made the switch from a 26er to 29er (26er having Nevegals, 29er coming with Nanos) after only a few months I upgraded my rings from the "standard 22/32/44 to 24/34//46 because I could climb the same hills in harder gears on lesser tyre When will this BS ever die
    Mar 2013
    roll on 29er
    I went from a 26er trance 2011 to a 29er Camber 2012.
    I used to be left behind on the uphills and now they eat my dust.
    But its not one thing, its a whole bunch of things. Noting that whole bunch of things all add up to suit my particular circumstances.
    But to pick one relevant BIG plus:
    I can cadence the 29er uphill. Its like I have a big flywheel on board. Once up to speed (yes it probably is a fraction slower to accelerate) then it just rolls right on (because it is much more reluctant to decellerate over the usual rocks and gutter obstacles along the way).
    As a result of this (plus those other things), I went from slowpoke to FAST
    (In case you are wondering, I am quicker downhill too - knocking 10% off my strava times - all because it pedals so much better)
    AZ
    AZ is offline
    Reputation: AZ's Avatar
    There ya go, 10% better and 29ers cure the herpe too.
    Mar 2013
    Quote Originally Posted by Dirty $anchez View Post
    speak for yourself
    Reputation: Gasp4Air's Avatar
    With equivalent gears, a 29er will be a bit harder to climb and accelerate due to the larger wheel circumference. You move a little further with each crank rotation, so you're actually doing more work. Roughly speaking, you seem to "lose" a gear on a 29er. This can be overcome by using a 12-36T cassette or replacing your 22T ring with a 20T. The cassette option is easiest, the 20T ring takes some fiddling. For really "weak" climbers, like me, who love low gearing, you can combine both options and get a great granny. Plus, it really pisses off lyNx, but don't do it just for that alone.
    Use it, use it, use it while you still have it.
    Apr 2013
    Thanks for all the replies ! I picked up the 29er bike looks and rides brand new, 2011 Trek elite 100 Gary fisher collection carbon 29er.... Time to go ride...
    Apr 2013
    I got the 2013 Trek Superfly Elite (non 100) a few weeks ago, and love it. Head to toe. So as a hardtail i cant speak to your 100. I have not gotten into any excessively steep climbing but I haven't noticed a big change on the hills I've been on vs my 26. What I have noticed is: a/ the Superfly Elite is an amazing bike. And b/ that this 29er flies when you open it up. Get one and don't look back.
    Binned
    Nov 2008
    I've been a 29er rider for a bit over a year now. What I can say that is different in a negative way is:
    1) a little bit harder to get started from a stop
    2) wider turning radius
    3) wanders comparatively
    4) eats brake pads faster
    But all of those things are overcome/accepted/adapted to rather quickly and the pros of being a 29er rider far out weight the cons.
    Apr 2013
    Ok here it is, I have a water tower hill by my house on my 26 it pretty much takes everything I've got to get up it, most friends have to walk it, the new 29er went right up no problem even after a 10 hour day in 90deg weather I'm stoked!!!!!
    Hardcore Bike-Path Rider
    Reputation: Kyri's Avatar
    Quote Originally Posted by Wyrd View Post
    ^ this.
    Binned
    Nov 2008
    Glad to hear that! The weight reduction is a huge factor where climbing is concerned. Enjoy!!!
    Pics of the new bike please.
    Apr 2013
    It's that new purchase adrenaline! Congrats!
    Quote Originally Posted by Gasp4Air View Post
    I know what you're implying, but what you're saying doesn't make any sense.
    With the same gears, a 29er will have more gear inches than a 26" bike. With equivalent gearing, they would be the same.
    Binned
    Nov 2008
    Here we go again... Faster your seat belts and place your serving trays in their upright positions...
    Quote Originally Posted by OneBadWagon View Post
    Good point, my word choice was poor. By "equivalent gears", I meant "the same gears".
    That's what downshifting is for.
    MTB B'dos
    As I said, better traction, climbs easier/better and I'm betting you find you climb in the "same" gear i.e 2-3 as you did on your 26er, only difference is you actually make the climb now instead of having to bail and most likely in short time you'll be riding a harder gear, hence my argument that it's a none issue.
    stoked gnar shred
    Reputation: tylerw's Avatar
    Dec 2009
    you will have good grip.....yup. I always spun out with my 26er full sus leaving me un clipping. My 29er hardtails and rigids alway seem to leave me grip due to me now having the perfect amount of leverage to the back wheel. The 26er.,, i would pick my perfect so called gear and then the back wheel would just break loose leaving me in hike a bike mode. The 29er seemed to resolve that problem. Just and fyi for you and good luck.
    Rod
    Rod is offline
    Reputation: Rod's Avatar
    Oct 2007
    Quote Originally Posted by Hawg View Post
    well said... it's going down that road again
    There is not much choice between rotten apples.
    NedwannaB
    Reputation: JMac47's Avatar
    Why so bitter. I resemble that remark.....
    Wait whuuut, who did he tell you that!?!?....
    Mar 2013
    the magic pudding
    yep ...and geometry and bike fit and platform and... nearly forgot, 29
    any other factors i have missed?
    Feb 2013
    twenty or thirty different gears on that muther. downshift and use 'em.
    Reputation: shiggy's Avatar
    Dec 1998
    With equivalent gearing (which factors in wheel size), the bike moves the same distance per pedal stroke.
    mtbtires.com
    Quote Originally Posted by shiggy View Post
    Yes, someone already pointed this out, and I responded that my word choice was wrong. I should have said "same" gearing.
    Dec 1998
    Still not quite there.
    Yes, someone already pointed this out, and I responded that my word choice was wrong. I should have said "same" (chainring and cog sizes)...
    mtbtires.com
    Apr 2013
    It's not letting me post pics, do I need more posts?
    You should be good now. I think it's 10 post minimum for posting pictures.
    Apr 2013
    Nope still can't, took it on an actual ride today it's so much nicer to ride than a 26...
    Nov 2012
    Quote Originally Posted by Cotharyus View Post
    24x36 granny gear on a 29 is equivalent to a 26 in 26x33 position. modestly more difficult on a very steep climb.
    MTB B'dos
    OP, don't mind him, smokin some crap. 24-36 (granny-granny) on the 29er would be roughly equal to riding 22-30 (granny-2) on your old 26er - actually a very little bit harder, depending on the tyres you ran on your 26er and what's now on your 29er.
    Remind me again who makes a cassette with a 33 tooth cog? NO ONE!
    Quote Originally Posted by LB412 View Post
    Nov 2012
    I understand no brands make A 33... It's a mathematical fact based on the tire size. It's also the reason shimano is releasing a new 22/30/40 intended for 29ers and 650bs next year. There are several forums that discuss this in detail.
    Personally my climbing improved significantly on all but the steepest of steep routes when I changed to a 29er.
    Man, you're strict.
  1. Switch Question
    By pucked up in forum Lights DIY - Do It Yourself
    Last Post: 09-25-2012, 01:17 PM
  2. XC -> AM - making the switch step-by-step?
    By svalgis in forum All Mountain
    Last Post: 04-13-2012, 07:57 PM
  3. I am making the switch.
    By LazyRid3r in forum Shimano
    Last Post: 03-29-2012, 08:12 PM
  4. Another switch question....
    By Andy13 in forum Lights DIY - Do It Yourself
    Last Post: 02-15-2011, 03:29 PM
  5. Replies: 22
    Last Post: 02-02-2011, 11:49 PM
