Page 2 of 2 FirstFirst 12
Results 101 to 120 of 120
Thread: Pole Machine
  1. #101
    Out spokin'
    Dec 1999
    Hey Le Duke, we each have a right to express our opinion. Speaking of opinions...
    Quote Originally Posted by Le Duke View Post
    It’s relevant in that people at making statements that are inaccurate at best re: STA.
    I wonder if this is fact or opinion. May I ask what qualifications you have that make your statement regarding others' opinions ("inaccurate at best") fact rather than merely your own opinion? And if what you've said is merely your own opinion, please help the rest of us understand why your opinion is more credible than the opinions of others. I'm not being flip when I ask this. If you do understand the intimate nuances of frame design, I'd like to ask you some additional questions.
    Just like using the word “capable”. It means nothing unless you further clarify what it is more or less capable of. There are trade offs. There is no free lunch; one bike is not more “capable”; it just has a different range of conditions under which it is ideal.
    Read back. That's not what MTBguru71 said about capability. Here it is:
    Quote Originally Posted by MTBguru71 View Post
    I'm sure glad intelligent mountain bikers chase trends with their hard earned dollars. The results of this are more choices in bikes with greater capabilities.
    In this case (s)he clearly used the word "capabilities" as a comparative noun. "Greater capabilities" implies compared to bikes that came before. To say there's no free lunch is irrelevant. Outright gains have been made in bicycle frame design. I recall days when mountain bikes had top tubes that were parallel to the ground.
    =sParty
    disciplesofdirt.org
  2. #102
    Aug 2018
    Hey guys ive had my machine for about 3 months now and been riding it every chance i get... has anyone notice excessive amount of flexing? I know for it being a long geometry bike its known to have some flex. But when i was feeling around the top tube as I shake the bike left and right the seam underneath the top tube shifts side to side where its suppose to be glued, also under neath the bottom bracket where the seams come together has also play. Its not glued any more and by this causes the bike to have excessive play. Also i had a friend follow me and he sees excessive flexing left and right at every pedal strike load.. another time i notice when i hit a jump the landing is pretty rough from the excessive flexing. Ill try to post a video soon. Thanks
  3. #103
    May contain nuts
    Reputation: Haggis's Avatar
    Quote Originally Posted by gil machine View Post
    Ah, yikes??
  4. #104
    Oct 2015
    Glue together a bike they said, it'll be fun they said...
  5. #105
    Elitest thrill junkie
    Reputation: Jayem's Avatar
    Wait, they glued a metal bike together?
  6. #106
    Have you contacted Pole, they'd be interested to know.
    They did a lot of testing and DH riding on the prototypes. But that is not to say that you could get an unfortunate delamination. It happens with aircraft parts from time to time. Run your finger over the join area, it should be smooth, if there is an edge then there is some movement. Good luck
  7. #107
    Nov 2016
    It's an aerospace technique. If it is executed properly there shouldn't be an issue. Yes this guy is having an issue but it remains to be seen if it is isolated or not.
    Sent from my SM-N950U using Tapatalk
  8. #108
    damned rocks...
    Reputation: Aglo's Avatar
    Dec 2014
    The parts are held in place with bolts, the glue is added for extra rigidity, but yeah, I had the exact same reaction the first time I saw "aluminum frame" and "glued together" on the same sentence.
  9. #109
    Quote Originally Posted by tuckerjt07 View Post
    Yes, my reaction is not that it's impossible, it's that whenever tried in mtb it's often been an utter failure, like Crank Bro's "glued-together" crank-halves. I'm familiar with aerospace, but they don't often glue the engine-mount to the firewall or the wing-struts to the fuselage.
  10. #110
    Formerly of Kent
    Reputation: Le Duke's Avatar
    Aren’t a lot of aluminum crank arms machined in halves then glued together?
    Death from Below.
  11. #111
    Reputation: vikb's Avatar
    Quote Originally Posted by Aglo View Post
    The frame is bonded that's what's holding it together. The small bolts are just there so they don't need a fixture for the bonding process. This allows cheaper/faster production. If the adhesive fails those bolts will not hold the bike together under a rider.
    Safe riding,
    Vik
    www.vikapproved.com
  12. #112
    Um...no?
  13. #113
    Formerly of Kent
    Pole Machine
    Um...no?
    http://www.killasgarage.bike/uncateg...owtech-cranks/
    There are plenty of articles that talk about Shimano cranks being machined in halves then glued together.
    Death from Below.
  14. #114
    Musings on Shimano HollowTech Cranks – Killa’s Garage
    I wasn't aware that was how they were made, I'd be interesting to see the cross-section and see how they "fit" together, in other words how critical the glue is. Still, monocoque frames like Foes and San Andreas that were produced in halves were always welded together down the middle.
  15. #115
    damned rocks...
    Dec 2014
    Quote Originally Posted by vikb View Post
    You are right.
    I went to re-read the article where I originally read about the frame, and it is as you say.
    Still, past examples with aluminum tubes and lugs make me rise one or two eyebrows .
  16. #116
    damned rocks...
    Dec 2014
    Found this:
  17. #117
    Aug 2018
    Hello Everyone!
    I'm Leo Kokkonen, and I'm the founder of Pole bicycles and engineer behind Pole Machine. It's nice to see how much interest there is towards our product in this forum.
    Our frame is machined from 7075 T6 aluminium billets. Bonding the halves together we use mechanical and adhesive joints to create a tubular monocoque frame. We distribute the loads by external shape and wall thicknesses like in any other frame but we can also produce internal shapes that is impossible with conventional methods. The frame halves have mechanical connections and steel bolts. The bolts also share lateral loads and secure some areas for extreme situations.
    We are continually learning from the process, and we have updated already frames several times after we started the production. The updates are relatively small. For example, we added bolts near the bb and head- and top tube to strengthen the frame for extreme impacts and stress. The good thing about machining is that we can quickly change the design within weeks instead of year model batches.
    All our customers who have bought Machines have full warranty on the frames for liabilities and defects, and because we are doing something that no one has any experience, we have extra resources for warranty cases.
    I'm happy to answer any questions, and I'm at Crankworx Whistler next week if someone wants to meet me and see the product live and maybe swing his leg over the bike
  18. #118
    Oct 2015
    Quote Originally Posted by polebicycles.com View Post
    Hello Everyone!
    So you're replacing the OP's frame with the new updated version?
  19. #119
    Aug 2018
    Quote Originally Posted by GRPABT1 View Post
    All warranty replacements will be handled with the current revisions on Machines at the moment.
    Note that all sizes are individuals on construction and we can make small changes weekly without any notice. We mainly optimize machining time. In some cases we might change joints mainly because we can get better performance / weight etc. It's really cool working on this because as soon as we learn something we can implement it next week. This kind of changes are hardly seen outside the frame so from customer point of view it is not relevant until we make some big changes. So every time one purchases a Machine it is the latest design.
  20. #120
    Reputation: RS VR6's Avatar
    Cannondale's Hollowgram crank arms are also bonded from two halves.
  1. Replies: 6
    Last Post: 10-23-2013, 12:52 PM
  2. Superfatty goes to the South Pole
    By druidh in forum Fat bikes
    Last Post: 04-04-2012, 04:53 PM
  3. My DIY GoPro pole mount
    By rabidchicken in forum Videos and POV Cameras
    Last Post: 01-10-2012, 12:01 AM
  4. Biking to the South Pole
    By sjhiker in forum Passion
    Last Post: 01-08-2012, 08:45 PM
  5. Pole Hill
    By dutchman59 in forum Colorado - Front Range
    Last Post: 10-10-2011, 10:42 PM
Members who have read this thread: 397
