Results 1 to 28 of 28
    Origin 8 sub compact crankset...
    Sorry if I missed information on this in the forums:
    http://www.origin-8.com/?page_id=91&...+ARMS+%26+SETS
    Does anybody have these? Does anybody have any opinion on them as far as weight and durability? If there are threads, please direct me because I didn't see much using the search. thanks
    Reputation: shiggy's Avatar
    Dec 1998
    Quote Originally Posted by bluestatevirgin
    It is a new product. Shown at interbike. Weight is listed in your link. It is an external bearing BB with a separate spindle.
    mtbtires.com
    ballbuster
    Reputation: pimpbot's Avatar
    Spot on!
    ... almost.
    That 44t big ring is super tall. I would have dropped that down to a 42t or even a 40t. If they were 180mm and silver, I would sell my own children to the carpet weavers in India for a set.
    I was hoping somebody would come out with an external BB compact mountain triple. Sweet!
    Quote Originally Posted by shiggy
    Thanks Shiggy. I guess my newbishness is asking about the weight and opinions about the heft as in: is 800 grams reasonable/good for a triple crank? If memory of other cranksets serves, the Origin8 weight is pretty good, around XT level, right? So then now I wonder about durability and clydeworthiness, but since the cranks are so new, maybe nobody is using them yet.
    Pimpbot, I was thinking 40T would be better myself. Or just pulling the 44 and running a bash.
    ballbuster
    That is pretty dang light
    IIRC, LX cranks, M585s are around 910 grams complete. XTs of the same era (2006 or so) were 860g or therebouts. A big chunk of the difference in weight was the steel vs alu granny gear. The current XTRs are 795 grams, IIRC.
    A pic, so folks know what the crud we are talking about
    Reputation: DAVP's Avatar
    Quote Originally Posted by pimpbot
    Here's another one... No weight info, but if my Phil Wood square taper ever fails me, I'd upgrade to these Middleburns.
    5 Arm 94BCD spider, single, daul ring options as well! NICE!
    http://www.mtbtandems.com/Middleburn.html
    Attached Thumbnails Attached Thumbnails Origin 8 sub compact crankset...-rs8_external_1.jpg
    Origin8's parts usually aren't the lightest, but they're an excellent value and I will happily pick one up when they're available so I can change my 32x20 to a 29x18 with a White Industries Trials freewheel.
    Quick FYI: There's a set of these on FleaBay right now (12/15/10) for the buy it now price of $169.00. I don't know what MSRP will be, but if somebody wants to get the jump on a set...
    I haven't decided what cranks I want on my new build or I might already have purchased them.
    Edit: They sold off Fleabay, but nobody thanked me for the tip. Purchaser, you owe us a report as soon as you get them!
    So are these going to be HT2 compatible or are they going to use some separate BB system. I'm fine with the separate spindle (ala Mr. Whirly cranks) but don't want to get involved in Powerspline, Howitzer, etc.
    don't believe the weight, origin 8 says 800 grams,more like 2.6 pounds including bottom bracket.that's what mine weighs...lying bastards
    Reputation: mlk3454's Avatar
    Bringing this back from the dead since a search doesn't reveal much on this crank.
    Any one else use these? Would middleburn rings fit on this crankset? The description on the Origin8 site is confusing...does it come with a bottom bracket? Any ride reports?
    Double bump. I started this thread. Can't believe nobody is riding these. Would also like to see/hear if anybody put these on a scale to see if the 800gram claims are true.
    Dec 1998
    I am hoping to get a set soon. Been looking around for a smaller outer ring, too.
    mtbtires.com
    After I do my taxes I am picking hopefully picking one up and putting 20/30/40 rings on. I will weigh it then. Would be nice to hear use reports though!
    MTB B'dos
    Reputation: LyNx's Avatar
    Biggest thing going for these is that they're 5 bolt and not 4 like most other cranks these days. Not sure why in hell they'd do 20/30 and then throw a 44 on there, makes absolutely no sense what so ever
    MTB Barbados
    My Phantom pics
    Dec 1998
    Quote Originally Posted by LyNx
    The stock rings are actually 22/30/44, which does make sense for 26" wheels.
    Would be nice to have a 20/30/40 and 180mm option
    mtbtires.com
    Agreed - the best part about the 94BCD is the option to run smaller middle chainrings (<30T), but I need this crank in a 180mm format.
    180mm outboard bearing cranks with the option to run 29T middle ring:
    -Mr Whirly
    -XTR M985
    I'm not aware of any other cranks that come in 180mm that can do this.
    ballbuster
    2.6 pounds?!?
    Quote Originally Posted by love to pedal
    That's 1179 grams, according to Google metric conversion. Dayum.
    Quote Originally Posted by mlk3454
    Let us know what you end up with. Maybe adding the two new rings will save some weight.
    Trail Junkie
    Reputation: dubdryver's Avatar
    Mar 2006
    The idea behind it is that with the use of 11-36/12-36 cassettes, you will be able to spend more time in the middle ring. You may ask "why" would it matter. From the perspective of someone that rides a full suspension, riding in the middle ring creates more chain tension than riding granny. The suspension stiffens out and climbs better. You remove a lot of chain tension when using the granny gear. Of course if you are a stonger rider, and a more avid rider, this crank would not make any sense. You lose gear inches with the decrease in chainring size, and replacement ring availability and options are shrunk significantly when you move away from a 104/64 BCD.
    Ibis Ripley LS
    Intense Spider 29 C
    Cervelo S2
    Trek Boone 5 Disc
    Spech Tricross Expert
    Raleigh RX 1.0
    1060 grams, actual weight
    Quote Originally Posted by 2old2mtbike
    This is with bb or just crank/rings/bolts?
    Ride report?
    Includes bb, never rode it, sold it.
    ballbuster
    Fooey! I had high hopes
    Wow, I dont need something a half pound heavier than what I have! I wonder if anyone else has one close to the advertised weight?
    Disagree
    Quote Originally Posted by dubdryver
    MTB B'dos
    I'd have to agree, absolutely, undeniably, way too heavy
    MTB Barbados
    My Phantom pics
    ballbuster
    As somebody who....
    Quote Originally Posted by SKullman
    Disagree
    ... spends a lot of time chasing down chainrings for my compact 5 arm... yes, it's true. There seems to be exactly two 30t shifty chainrings in the world: Midleburn or Vuelta. Homebrew components will make one, but it has tall singlespeed teeth and no shift ramps. I have a Vuelta non-ramped and pinned, and it shifts fine, so maybe the HBC ring is fine for gearie use. Cannondale had a 29t inner ring on their double Coda cranks that came on the Scalpel, but I'm not sure how they work as a middle. Heh... I have a line on a Coda double crankset for $30 with 29/44t rings. I only really have use for the ring. Maybe sell the rest on Craigslist?
    Loads of rings out there for 4 arm 104mm bcd. Go to any swap meet, and there are plenty. I lived for years with 22/32/44t replacement chainrings bought cheap at swap meets, until I went 29er.
    Some 5 arm compact, but only if you want 22/32/44 (or 42). The point of running compact 5 arm is to get a 20t granny and 30t middle.
    Otherwise, just get an LX/XT crankset and live a happier life.
    Now, if somebody had a 4 arm 94mm bcd outboard bearing crankset with 20/30/42 (or 40t) ring set in 180mm, I would be all over it. I would be okay with that as long as rings were available in the future.
    Like Gillette razors.. its not the razor, its the blades. Replacing the wear out items is where its at.
    Man, maybe I should just switch my derailleur out for something that can take a 36t cassette, and get a regular XT kinda crankset.
    I was really hoping some good manufacturer would step up and make us a good crankset with small rings for 29er use.... kinda like how Shimano started making good road compact cranks recently.
