On One Scandal 29er ?
Printable View
  • 03-17-2011
    skilikeme
    Hey Guys-
    I have bought all my components to build up a Tomac Flint 29er, but have been waiting for far too long for the frame to show up.
    Would everything I bought to fit the Flint be a straight swap over to the Scandal?
    Thanks in advance!
    Jon
  • 03-17-2011
    rick@onone
    Hi Jon,
    Most components will switch over fine, the only problem will be the seat post at the flint has 30.9mm whereas the scandal requires 27.2mm. Other than that you should be fine.
    Rick
  • 03-17-2011
    skilikeme
    Thanks Rick!
    So no problems with the SRAM S1400 crankset?
  • 03-17-2011
    shiggy
    Originally Posted by skilikeme
    Thanks Rick!
    Should not be a problem. Nothing different about the Scandal BB/chain stays.
    You should also check the FD clamp size. 34.9 and top pull for the On-One.
