Results 1 to 69 of 69
    Powered by ice cream.
    Reputation: Enel's Avatar
    And Now for Something Completely Different
    It feels big, heavy and squishy.
    Schipperkes are cool.
    Reputation: banks's Avatar
    Pull the travel spacers in the fork to get 140mm!
    Quote Originally Posted by mikesee
    Better suited to non-aggressive 125# gals named Russell.
    I ride so slow, your Garmin will shut off.
    Reputation: MMcG's Avatar
    Jul 2003
    Bring back the ByStickel into the rotation!
    How about a pro review?
    Quote Originally Posted by MMcG View Post
    Highly unlikely.
    Quote Originally Posted by banks View Post
    I done did that 130 rear, 140 front.
    Missouri sucks...
    Looks flexy...
    On wuss patrol
    Reputation: Glide the Clyde's Avatar
    Quote Originally Posted by Enel View Post
    Like a diaper that's been on too long?
    Serious, I think I like. Imagined doing the same with my FSR.
    Sometimes, you need to go fast enough that the trail is a blur to find clarity. -- Wild Bill
    Reputation: jncarpenter's Avatar
    Your bike has a muffin top.
    A Surly Maverick
    Reputation: Dr Feelygood !'s Avatar
    A nod is as good as a wink to a blind horse. MP
    A Fatback'd Lefty for who life IS a Beach
    poser Administrator
    Reputation: rockcrusher's Avatar
    Aug 2003
    I'm confused...what is this?
    Try this: HTFU
    AZ
    AZ is offline
    Reputation: AZ's Avatar
    Quote Originally Posted by Dr Feelygood ! View Post
    Faces 3rd.
    Reputation: skitchy's Avatar
    Dec 2011
    Ha, Bontrager rubber on a Stumpy.
    maladroitus extraordinairus
    Ride observations:
    This is my first ever frame from the Great Satan, or "Them Who Shall Not Be Named."
    I kind of got it by accident. I was hunting around for something with decent geometry for a single speed full suspension bike, and sort of settled on Specialized or a Tall Boy. This old/new 2010 frame came up at a price I could not pass up, so here we are.
    I converted it with a Rohloff tensioner that only needed a little tweak to clear the largish 22 cog.
    Overall, the frame is very well thought out. Easy to build, but requires an immensely long rear brake cable due to under DT routing and all the excess required due to the monkey motion. I used a Reba 140 for the fork.
    On the trail, the bike feels big. Absolutely not as poppy as a Milk Money, but it has practically double the travel and weighs a couple pounds more (29 lbs). The freakiest thing to me is the way the rear suspension simply has no interaction with chain tension. I have never had a significant amount of time on an FSR type frame/bike set up for me. The rear truly is independent of the chain tension. The difference is subtle, but I do notice it. At times I was expecting a little rear traction loss on up type moves in ledgy terrain, the rear was just silent, dead and full of traction. I thought I could brake a little deeper with the rear in the loose stuff, but that was an even more subtle effect, could be my imagination.
    The Brain Shock: What a completely stupid idea. Especially on a bike with 130mm travel. I tried it on and off, and it became clear I preferred it all the way off almost immediately. Here you have a fantastic suspension design that honestly hardly bobs, even ridden as a single speed standing, and you trash its function with a stupid excessively spikey compression damper. I dislike it a lot. This is a fix for a non-issue, attached to a bike for I what I presume must be marketing reasons. Rant off.
    For the way I ride, I really like the feel of the suspension. I for the life of my can't see riding any bike where the rear stiffens up under power, especially in ledgy terrain or loose climbs. The pedal feedback would drive me nuts in ledges, and I want/need that traction when it is steep and loose.
    Most of my prior ride time has been spent on low linkage actived single pivot frames. The differences are minimal, but real.
    Personally, I prefer a really active suspension to one that resists bob. I just could care less about it and I don't really notice it.
    Anyhow, there is my FSR newby rant. It's a beautiful design burdened down by a stupid, unnecessary damping system.
    I did notice (and dislike) the extra 8-9mm of chainstay length on the Stumpjumper over the Lenz, but it is not a dealbreaker......so far. I seem to be able to get it to do what I want/need, but I haven't hit the real puckery stuff yet.
    The chassis is absolutely overkill for a pure rock bike. I realized that this A.M. It is just too much travel for slow tech. It is a lot of bike and even with the wuss 32X22 gearing it hard to push up steep inclines, and hard to sprint to gain momentum when I need it most. I found myself stalling a lot on ups I usually clean. The low BB can suck or be good depending on situation.
    The rear travel is very linear and sort of blows through travel, but I don't detect bottom out. My pedal strike issues and blow through improves somewhat as I added air. This frame seems to like sag somewhere between 20-25%. That is higher than I am used to with a 130mm rear travel bike. Air pressures also seem high, around 200-210 psi. I am used to setting 30-35% sag and about 160psi on the Lenz and letting the linkage deal with the bottom out. Maybe I'm just getting fat.
    It's a pretty amazing ride when pointed down though. I think it gives a Moth/Box a very strong run for their money in the trail bike category. It handles wonderfully on single track. It is a frame that will keep you out of trouble. Or get you in to it depending on your perspective.
    At this point I would absolutely recommend the Specialized to anyone in the market for an all trail type 29" FS bike. Just buy one without a Brain.
    May 2005
    Quote Originally Posted by skitchy View Post
    - 5 points
    WNC Native
    Reputation: nitrousjunky's Avatar
    Looks way too complicated to me, to be a SS.
    "I ride to clear my head, my head is clearer when I'm riding SS. Therefore, I choose to ride SS."~ Fullrange Drew
    I thought you had a Milk Money?
    Quote Originally Posted by jncarpenter View Post
    Zee Milk Money, she ees dead. Thus the placeholder.
    Reputation: Mojo Troll's Avatar
    moving backwards
    Gave up a ByStickel for this?
    It;ll be like your Niner RIP, up for sale shortly.
    Quote Originally Posted by RandyBoy View Post
    Possibly. I would take this bike 10 out of 10 times over that first gen RIP though.
    Reputation: TwoNin9r's Avatar
    Jan 2011
    lol it's like an identity crisis on wheels, i like!
    On wuss patrol
    Quote Originally Posted by 4x4runner View Post
    My thinking too. It's like the wrong tool for every job
    A Surly Maverick
    What happened to the Milk Money please ?
    Quote Originally Posted by dr feelygood ! View Post
    what happened to the milk money please ?
    ^ this
    Reputation: fixgeardan's Avatar
    That boy just aint right!
    Yes, what happened to the milkmoney?
    ^ this
    I broke the Milk Money in half just behind the downtube weld. I heard it creaking during a ride and saw it 1/2 broken. I tried to get it back to the trailhead, and tried a "move" about a minute from the trailhead which finished the main frame off.
    The frame was just over four years old and lived a hard life for an XC racing weight frame. I certainly did things on it regularly that should not have been done on a frame that light. Anyway, I got my money out of it and have zero regrets. I had plenty of warning before complete failure.
    I owned it 3.5 years and that is the longest I have ever owned any frame. I have discussed with Devin having him build up a new front triangle with a heavy duty downtube, 30.9 seat tube, and tapered head tube. I will probably proceed in this direction eventually, but as with most one man show type frame builders, these things take time.
    In the mean time I wanted to explore the "Moth Money" 5 inch travel single speed concept, thus this bike.
    My current feeling after only a very short time is that the Camber at 110mm travel or Tallboy would be better candidates for SS conversion, at least in the rocks. I can't wait to get the Stumpy on to some higher speed trail tomorrow am because I think it is going to rip it up.
    I think this move was the final straw as it was the ride just before I noticed the crack:
    <iframe src="http://player.vimeo.com/video/33842711?title=0&byline=0&portrait=0" webkitallowfullscreen="" mozallowfullscreen="" allowfullscreen="" frameborder="0" height="853" width="640"></iframe>
    STIL.
    A moment of silence for a beloved frame and one of my favorite ever bikes She was Milk Money serial number 01. The first of her kind.
    She may be born anew and improved like the Six Million Dollar Man, but until then I will 'speriment.
    E
    I saw a guy around my parts with a tallboy converted to single speed. I don't remember what tensioner was on it though, or when I saw it.
    I think that's a pretty good setup there, although a Cane Creek double barrel would really light up your life in terms of traction and shock performance.
    30 second review:
    On open trail this thing is simply amazing. I believe it is the best handling bike I have ever ridden at higher speeds.
    Eating Crow about big brand bikes right now.....cough, cough...
    THE CAPTAIN
    Reputation: FormulaRX's Avatar
    Nice!
    Interesting, that was at the time, their all time best seller... I rode mine for 2 years, never a peep, a creak, nothing, out of it, then sold it, (the frame) on Craigslist for $700 shipped to a triathelete in Indiana. I seem to recall you pieced yours out for components and made money on it too? Sounds more like an investment to me.
    My observation riding around the San Gabes is that round tubed aluminum in frames and rear triangles flexes like the dickens on granite spines locally, causing a lot of over correction at the handlebars. I also noticed the same thing on the rear end of a Santa Cruz Tallboy in carbon too.
    Glad the speshy is working out for you, but have to admit, a brain sounds retarded, for a shock.
    1st drop. No trouble getting front up at all.
    <iframe src="http://player.vimeo.com/video/34757360?title=0&amp;byline=0&amp;portrait=0" width="640" height="472" frameborder="0" webkitAllowFullScreen mozallowfullscreen allowFullScreen></iframe>
    I have a few more rides on the Stumpjumper and have to say I like it. I basically have zero nits to pick. It rides great and does everything I ask of it.
    I am still banging pedals a bit, but it is more an issue of my unfamiliarity with the frame.
    The 5"X5" SS deal has grown on me, and I hardly notice all the squish any more. I do notice that my feet and elbows don't hurt as bad the day after a ride. The squish is dangerously addictive and makes any down move pretty easy. There is nothing I can't ride on this bike that I couldn't ride on any of my others, so it is not limiting me in any way.
    The best thing I can say about any bike is that is does not irritate me in some way while I am riding it. The best bikes fade invisibly into the background so my OCD can concentrate on something else. The Stumpy does just that.
    One big positive in my eyes is my ability to track stand/trial correction hop this frame pretty much indefinitely. I don't lose my balance so much as I run out of endurance. There is zero pedal kick back as I am hopping and balancing, trying to get up a ledge or something and I really like that.
    <iframe src="http://player.vimeo.com/video/35254331?title=0&amp;byline=0&amp;portrait=0" width="640" height="480" frameborder="0" webkitAllowFullScreen mozallowfullscreen allowFullScreen></iframe>
    <iframe src="http://player.vimeo.com/video/35254613?title=0&amp;byline=0&amp;portrait=0" width="640" height="480" frameborder="0" webkitAllowFullScreen mozallowfullscreen allowFullScreen></iframe>
    Anyway, I am impressed by this mass produced frame. I fear it is Taiwan for me from now on.
    Ride observations:
    Is there a model that doesn't have one? It sucks that this frame you seem so happy with is burdened with the extra weight of the unnecessary "brain"...
    On wuss patrol
    Quote Originally Posted by Wish I Were Riding View Post
    I think the RP23 from the 26" FSRs may be available as a service replacement but I don't know if the travel specs for the 29" v. 26" match up. The 29" Comp has the Triad II but many say it's not the best shock as it is not as tune-able or reliable as the 23.
    If I were going to do away with my Brain, I'd look into the older RP23 from the 26". It has the proprietary linkage yoke and is only a matter of travel compatibility. The 2012 Expert Evo FSR 29 also has a 23. It might bolt right on but it has the new Auto-Sag and would likely be a lot more $$.
    That being said, the Brain doesn't have lock out but full-on keeps the back quite calm on longer, smooth surface climbs and about 4 clicks from full-on give me a feel comparable to a pro pedal setting. I typically leave it about 4-5 clicks from full-on for about 90% of my riding.
    Uncle
    Reputation: Entrenador's Avatar
    [QUOTE=Enel;8891754]1st drop. No trouble getting front up at all.
    Every rose has it's thorn.
    enjoy the ear worm
    Trail Junkie
    Reputation: dubdryver's Avatar
    Mar 2006
    I agree with Enel's assessment about the Brain, thats because after years of trying to perfect it, it still isn't a 100% intuitive system..and often down right glitchy.
    I built up a 2010 SJ Comp for my friend about a year ago. He scrapped the whole kit and went with XX and XO 1x10. Both the Brain and Triad are plagued with high maintenance. Brain warranties are continual (spend a lot of time in a Spesh shop because I ride with the Store Manager) and my friend's Triad that came on his comp.
    Although he has dumped quite a lot of money into his bike, he does love it. It does handle well, and has great confidence on the downs. It really does allow a lesser rider to ride more (not implying anything Enel), and thats a good thing...
    I just wish it was made by someone else,
    but I don't worry too much about that, I love my Tallboy for what it does.
    Ibis Ripley LS
    Intense Spider 29 C
    Cervelo S2
    Trek Boone 5 Disc
    Spech Tricross Expert
    Raleigh RX 1.0
    What about the chainstay length? You originally said you could notice them being longer and didn't like it. Has your opinion on that changed? The Camber does have slightly shorter CS than the SJ.
    Now that's how you mount hot granite.
    Attachment 667524
    Buttery schmoove
    Quote Originally Posted by LncNuvue View Post
    Attachment 667524
    Buttery schmoove
    Nice!
    Quote Originally Posted by 12snap View Post
    I don't seem to notice it any more, and it doesn't seem to hold me back. I don't know if it is how the FSR sags into its travel as I lean back or what, but I have not nose darted badly yet.
    What I need to do is ride the Stumpy and the LunchBox back to back. Then I can compare the Loop 140 to the Reba as well.
    I agree though that a Camber is a better SS conversion. Less travel, no brain, and cheaper to boot, but I don't think it comes frame only.
    Are you still on the Jet 9 and/or Milk Money?
    The Jet has been gone for a long time now. I got a Milk Money 4.0 late this past summer and it's even better than the 3.0 version. The extra travel feels a little less efficient but it's so much more plush. Definitely a worthwhile trade off. I currently have a new Spider 29 as my geared bike. I've only got a few rides in on it right now but I'm having doubts about me keeping it for very long. It feels long and I'm not used to that. I need to give it some more time next spring on my local trails, though. I want to try out a Camber myself as I think that might be a good alternative. But you're right, it doesn't seem to be available frame only.
    How much time do you have on the Loop fork? What do you think of it? I'm considering getting one next summer.
    Too little time to intelligently comment, but it seems decent so far.
    This place needs an enema
    Reputation: mikesee's Avatar
    Aug 2003
    WTF? Rip those cheaters out of there and do it proper.
    Quote Originally Posted by mikesee View Post
    <iframe src="http://player.vimeo.com/video/28135776?title=0&amp;byline=0&amp;portrait=0" width="640" height="480" frameborder="0" webkitAllowFullScreen mozallowfullscreen allowFullScreen></iframe>
    Actually, this comment reminds me of this fab-tastistic move (also on a Speshy):
    (sequence by Mikesee, rider unknown to me)
    If you look carefully, you can see how close the BB comes to the rock as it compresses. Moves sort of like this (only a lot smaller) are where I am noticing the detrimental effects of the low BB the most. Many times I end up scraping the bottom of my pedal on top of the rock. I seem to recall the rider above doing that on another attempt, but can't find the pic.
    Aug 2003
    BB's and basketball players:
    You can't teach height.
    A few thoughts, Behemoth/WB Loop 140 vs SStumpy/140 Reba
    I had a fun chance to ride the above frame/fork combos back to back today and here are a few thoughts:
    I rode them both on a very familiar to me, reasonably techy/chunky loop. Predominantly slow speed over chunk and granite with occasional bursts on to rocks and occasional "oh crap" steep, fast, short chutes & rollers mixed with a couple small drops to pretty much flat.
    The Loop fork is a loaner to me and I only have a few hours on it. I think it is not quite tweaked to the correct air pressure for me.
    Comparing back to back with the Reba, the Loop is stiffer for sure. The difference minor, but it is there. I prefer the Reba damper, especially the low speed compression tunability. I don't think the Reba dives as much under braking.
    The Loop is very linear. I was really blowing through its travel for the first part of the ride. I had been pretty happy with the air pressure I had in it for trail riding, but in the chunk it was just too divey. I upped the air spring pressure to 80 PSI and was happier. I think I could go higher, but am afraid of losing the small hit suppleness on the trail. Like I say, I am still getting it dialed in. It is not quite as linear as my old Manitou, but it is close.
    I would say the Loop is a viable competitor to a Reba for someone who likes a more linear fork. I may swap it to the SStumpjumper because the rear on that bike also tends to blow linearly through travel and it would match nicely.
    It was interesting riding SStumpy and Moth back to back. I would give the edge overall to the SStumpy, but it is very close and they both have their super powers. The minor differences, might even become less so with a differently tuned and/or maintained damper on the Moth (it is three years old and could use some love). The current one is a Fox RP23 with a highish compression tune, and it feels spikey at speed in rough stuff.
    This ride only has about 200 yards where I can get any speed, and at speed in the chunky stuff, the SStumpy is superior. There are only a couple medium speed smooth corners, but it was clear the SStumpy corners better also. The Moth is stiffer frame, and overall a little more nimble in the slow stuff. The SStumpy feels better on scary steep chutes and rollers. The Moth is a touch better for chunky climbs.
    I want to emphasize that all these differences are minor and I only notice them relative to each other, riding them back to back. If I rode either for a couple days I would adapt to the bike. My ability to clean any particular obstacle or not was more a matter of line choice, how I felt at the moment, and luck than it was affected by the frame/fork combo.
    Overall, I would be hard pressed to pick a winner. In the current config, I enjoyed riding the SStumpy more. It just felt better to me, a bit more comfortable and a bit more confidence inspiring. I think I will swap the Loop onto the SStumpy for a bit and see how that goes.
    Really I am that slow
    Reputation: SlowerThenSnot's Avatar
    always enjoy your reviews E!
    Read my BLOG!
    just a guy who loves bikes and exploring
    and a brainless stumpy
    Specialized Bicycle Components : Stumpjumper FSR EVO 29 Frame
    i kinna dig that blue and black look....
    Read my BLOG!
    I have the 2012 SJ EVO FSR Frame built up with some really nice parts and the Fox F34 and it is by far my favorite bike that I've owned so far! I bet the thru-axle rear end really stiffens up the frame in the rear versus the older versions.
    Okay, I sold off my other suspension bike and was left with this one, so that means it needed gears. I mostly ride the rigid SS, but there are those days with nasty steep climbing where I'd rather not hike.
    The SStumpjumper was fun, but that is a lot of travel for a suspension single speed.
    I ordered up 29-20 chainrings mated to a 11-36 cassette for some super granny action.
    Assembly went easily. I am pretty impressed with all the detail touches on this 2010 frame. The frame comes with a direct mount front derailleur (and pre-cut cables!). The derailleur mounts directly on the the swing arm right over the main pivot, and moves a bit with the swing arm. Setting it up was stupid easy, I just had to dial in the high limit...done. The seat tube actually jogs left a bit to accommodates a big tire, swing arm, seat tube, and itty bitty crank gears. There is a lot going on in this area and it appears Specialized thought of everything.
    I rode it today up a nasty fall line junk trail that kills me every time I climb it.
    Wow, I like these gears.
    I have never had a 20X36 super granny. I have been running 22X34 on a Hammerschmidt for the last couple years.
    Turns out 15% lower gearing will get you places. I tractored up a climb that I only have made twice out of 20 or more tries, both times seeing stars and falling to the ground once past the crux. It's not super techy, just loose fall line moto crap and STEEP. Anyway, today, I was breathing hard, but was able to shift up and continue the ride without a pause after I crested. It's not that I couldn't ride this stuff before, but I needed a really good day and really good fitness. This lower gearing lets me ride it on a less than perfect day.
    I have not had a fresh geared drivetrain in literally years. Even with old shifters and old rear derailleur, it is so nice to snick, snick, snick with no issues, just quick precise shifts.
    The Specialized feels like it was made for me. I would love to hate on it, based on their lawsuit heavy corporate policies and proprietary shock, but there is zero to nit with the ride. This frame climbs really, really well, no drama, just loads of traction and a little body english to keep it on track. Descending, it makes great use of its travel and just blasts through stuff confidently.
    If caught unexpectedly by a rise in the trail, standing climbing is not an issue at all, just stand and go.
    I have kept the "Brain" off since my first 5 minutes on the bike.
    Recommended.
    Got seat post? The dang thing came up an inch when I swapped to bitty gears.
    Better.
    Reputation: bonesetter2004's Avatar
    Brillinat bike, been lovin' mine for the last 2 years. Attention to detail is spot on, even down to the sag-o-meter
    since of direction????
    Sold an awesome HT, built by a reputable small frame builder. Build a FS SS from a large corparation. Which it sounds like your not a fan of supporting large companies. Turned the fancy brain/computer whatever the hell it is, off apon purchasing. Now you have a cassette on the rear. The size of a wedding cake.
    You should have kept the Stick and rode more.
    JB
    Reputation: Nevada 29er's Avatar
    Nov 2007
    Quote Originally Posted by Mojo Troll View Post
    Since of direction?? Sold an awesome HT, built by a reputable small frame builder. Build a FS SS from a large corparation. Which it sounds like your not a fan of supporting large companies. Turned the fancy brain/computer whatever the hell it is, off apon purchasing. Now you have a cassette on the rear. The size of a wedding cake.
    (Spell) check yourself.
    Dinner for wolves
    Reputation: buddhak's Avatar
    Enel...Bonesetter...why this while there is a brand f'in new Lenz frame in my basement? For fook's sake!
    Responds to gravity
    Reputation: eurospek's Avatar
    Nice riding videos, and I appreciate your honest review, especially coming from your custom background with the previous bikes and knowing that off the shelf frames can also be quite good without going custom.
    konahonzo
    Quote Originally Posted by eurospek View Post
    I guess that is my main point. Custom is probably not needed unless you want something way out there not available in the general market.
    And that is my curse
    Make him an offer on the Stick Im sure he would sell it to ya.
    Truly, you are "special needs"
    Seriously though, your bikes and the rare niches they fill are a great reason to go custom. I don't honestly have a good reason.
    Reputation: andrwplsn's Avatar
    i have thought of doing something similar as far as the full squish ss with the trek hifi not sure how it would work out.
    Working Man's Toilet
    Reputation: D3DO's Avatar
    Feb 2007
    Quote Originally Posted by buddhak View Post
    I just read this, been out of the MTBR loop for a bit, gratis to ENEL for pointing it out to me.
    I LAUGHED SO HARD I ALMOST PEED, for FOOK'S SAKE!
    Good job!
    Enel, thanks for this post I've been looking to convert my 2011 sj fsr comp 29 from 2x10 to ss and was starting to question myself if I was nuts. I will definitely do it for sure now! Thanks you're my hero!
    May 2012
    Good luck bro
  67. #67
    Quote Originally Posted by ojelijb View Post
    You are nuts but it is fun.
  68. #68
    Recovering Weight Weenie
    Reputation: Padre's Avatar
    Enel,
    Regarding your input on the BRAIN, I had an interesting story from last Saturday with it.
    Madre has been notorious in her bike history not being in tune with her equipment. Some examples:
    • Adding a 1.5" semi-slick to the rear and not tell her.
    • Swap from mechanicals to hydros and not tell her.
    • Increase fork pressure 20psi and not tell her.
    • Decrease fork pressure 20psi and not tell her.
    • Swap grips from ESI to Ergons and not tell her.
    In almost all circumstances, she doesn't notice and doesn't care.
    Her first ride on a 29er was a 40 mile race at Sea Otter unknowingly on 180mm cranks. All she knew was that her knees hurt after.
    Okay, last Saturday she had her first race since the 2nd kid was born last Thanksgiving. She's out on her new sled, probably the 5th ride on it. BRAIN fork.
    She commuted 10 miles to the race, raced, rode home.
    FIRST thing she says when she got home, "the Brain knob was set to 4 during the race, but the fork didn't seem to react like it should, so I dialed it all the way off and it was fine."
    WHO IS THIS AND WHERE IS MY WIFE?
    By the way, she won her category.
  69. #69
    sorry for reviving the thread with this late update:
    Enel, I've done the SS conversion... I am now officially nuts and it is fun!
    Thanks for leading the way... now if only I could learn that step up move....
    Ripping rocky downhills on this thing is a blast the only you hear is the rubber against the rocks braap braap braaaap no chainslap or metal sounds.
    Attached Thumbnails Attached Thumbnails And Now for Something Completely Different-stumpy-fsss-29.jpg
  1. And now for something completely different.
    By mikesee in forum 29er Bikes
    Last Post: 10-07-2010, 10:03 PM
  2. And now for something completely different!
    By Poikaa in forum Frame Building
    Last Post: 10-07-2010, 04:44 AM
  3. And now for something completely different...
    By flipnidaho in forum Idaho, Montana, Wyoming
    Last Post: 08-03-2006, 05:38 AM
  4. And Now For Something Completely Different!
    By terminaut in forum Turner
    Last Post: 11-02-2005, 01:57 PM
  5. Now for something completely different......
    By psycleridr in forum New York - New Jersey
    Last Post: 06-10-2005, 02:58 PM
