Results 1 to 26 of 26
    29er
    Niner MCR...bullseye
    First I would like to thank MTBR. I did a lot of research on parts and set up on here. You guys helped make this possible.
    This is my first "custom" bike. It feels great to get the set up perfect on the first try. There is nothing more that I could ask for.
    Specs:
    Niner MCR
    Rockshox Reba RL 100mm
    Chris King headest
    Thomson 80mm stem
    Easton EC70 685mm wide bars
    Titec pork rind grips
    Kent Eriksen sweetpost 27.2 x 400
    WTB Rocket V
    Truvativ AKA cranks
    MRP bling ring
    Sram Ceramic GXP bottom bracket
    Sram PG-1070 11-36 cassette
    Sram x9 short cage rear derailleur
    KMC X10SL-TI chain
    Sram x9 shifter
    Gore ride on shift cable
    ngear jump stop
    Shimano 520 pedals
    Shimano XT m785 brakes
    Icetech 160mm rotors front and rear
    Hadley thru bolt hubs
    Arch EX 32h, 3 cross front rim
    Flow 36h, 4 cross rear rim
    DT comp spokes
    Nobby Nic 2.25 EVO front tire
    Racing Ralph 2.25 EVO rear tire
    Stans sealant
    some pics
    247 is offline
    Nice Build!
    There is nothing like building a bike (I did it with a Paragon I built 3 years ago--my first bike) I built that 'just to ride it'--not specifically components I waned at first.
    Then 2 years ago I bought all the compents I really wanted!! --Then 2 months ago it cracked (2005 Paragon)---but now built up a Superfly 2012 (with my compenents from Paragon Build)------But in a few months I now want to get some improvements (because the new frame is worth it!!)
    Reputation: Shalom's Avatar
    Nov 2008
    Awesome! Well done. That is a great looking build. And looking dirty already!
    Jan 2009
    Very nice build, steel frame and a Ti seatpost ,must be smooth. Have fun
    MTB B'dos
    Reputation: LyNx's Avatar
    Very nice, glad you're so stoked on your new bike Seriously glad you like it and think it's perfect, but if you can, give a wider bar a try (think 710mm>) since you already have the short stem on there I'm thinking you might find you like it even better than that 685mm bar
    Reputation: Mojo Troll's Avatar
    Very nicely done. Love my MCR.
    29er
    yeah, i may try a 710
    this is my first time riding with a wide "ish" bar and i like it
    Crank Life
    Mar 2011
    Very nice!!!
    Reputation: eurospek's Avatar
    Nicely done.
    konahonzo
    Trail Junkie
    Reputation: dubdryver's Avatar
    Mar 2006
    Quote Originally Posted by Dan GSR View Post
    Specs:
    Niner MCR
    Chris King headest
    Thomson 80mm stem
    WTB Rocket V
    Truvativ AKA cranks
    MRP bling ring
    KMC X10SL-TI chain
    Sram x9 shifter
    ngear jump stop
    Shimano 520 pedals
    DT comp spokes
    Stans sealant
    Nice bike! I don't see any specs on that bell!
    Ibis Ripley LS
    Intense Spider 29 C
    Cervelo S2
    Trek Boone 5 Disc
    Spech Tricross Expert
    Raleigh RX 1.0
    29er
    i wish i knew who made it
    i got it for free, was in a buddies trunk. He had no idea how it got there, and doesn't ride at all
    Trail Junkie
    Mar 2006
    I was just adding some humor to go with the compliment!
    Ibis Ripley LS
    Intense Spider 29 C
    Cervelo S2
    Trek Boone 5 Disc
    Raleigh RX 1.0
    29er
    after having a bell, i can't see riding without one
    so much nicer to hear a bell versus just screaming out
    Mar 2012
    Have you experienced any issues with the chain jumping off the outside of the crank?
    29er
    so far only 1 time
    Quote Originally Posted by Ben_Im View Post
    I was going to ask the same thing. With a non "clutch" rear derailleur I think in super rough terrain there might be. An e13 or mrp 1x might work better long term.
    BTW, that's a VERY solid looking build. Well done sir!
    Mar 2012
    Reason why I asked, I am only running the N-gear guide as well. Went out for a ride today and almost destroyed my rear wheel. Chain slipped off on the outside and got tangled up in the rear wheel. Was able to stop in time before it snapped any spokes. Close call, decided to run a bash guard after all.
    Hope you don't experience the same issue.
    29er
    what rear derailleur you running? short cage?
    Mar 2012
    x9 long cage. Unfortunately, decided to go 1x9 shortly after buying everything for a 3x9. Go figure.
    29er
    yeah, a short cage will hold the chain better
    Mar 2012
    Good to know for future reference. Your bike rocks
    29er
    Also what chain ring are you using?
    Mar 2012
    As of now, the standard middle ring from a triple crank. Swapping to truvativ AKA cranks, and running the stock ring.
    29er
    a single speed ring has longer teeth so it will be less likely to jump
    Mar 2012
    Thanks for the info. Did not know that.
    I'll try running without the bash guard and see how that goes. I'll update the thread if anyone else is interested.
    Reputation: schneidw's Avatar
    Mar 2005
    Congrats on a fine build... you spec'd the bike spot-on.. right down to the paint... enjoy the ride!!
