Results 1 to 5 of 5
    Dec 2012
    Niner Carbon Fork stem torque
    So I recently put a set of Crank Bros bars onto my Niner Fork. Whenever I'm pulling hard on the bars, going up a climb or just accelerating hard, I hear a creaking type noise coming from what sounds like the fork. The stem is clamped to the steerer with 8 Nm. Spec is 9 Nm, but I'm worried about going tighter, because, well, carbon. Am i safe tightening that a little more? Could the sound be from the bar/stem interface instead? Any thoughts at all?
    REDIRECT!
    If you had a pet monkey that knew karate, what would you name it?
    Dont over torque it, pull everything apart clean and re grease and re torque. use carbon paste on stem to fork contact point.
    Reputation: RS VR6's Avatar
    The torque numbers are typically for the hardware not the fork itself. The bolts will probably break before you crush the fork.
    Check the torque specs on the stem. Your 8-9nm seem really high.
    Typically stem bolts are rated from 4 to 6nm.
    I have my bolts at 5nm for my road and mtb.
    Check your headset for play. Maybe reinstall it. Loose headsets will creak too.
    Category Winner
    Reputation: teamdicky's Avatar
    [QUOTE=NedsDead715;10521508]So I recently put a set of Crank Bros bars onto my Niner Fork. QUOTE]
    Did you mean Crank Bros stem (not bar)?
    If so, which stem?
    Niner says not to use stems with expanding wedges, like used on the higher end Crank Bros stems and older Thomsons.
    Attached Thumbnails Attached Thumbnails Niner Carbon Fork stem torque-stem.jpg
    WWW.TEAMDICKY.COM
    I get paid 3 every time I post on MTBR.
    Dec 2012
    If so, which stem?
    I used the stem and bars. The pictured stem is the one I used. Looks like I need to look for a new stem....
  1. Niner carbon fork - spacer above the stem?
    By trumpus in forum Niner Bikes
    Last Post: 03-01-2013, 07:43 PM
  2. Stem change- torque for the fork cap?
    By Sickmak90 in forum Beginner's Corner
    Last Post: 07-07-2012, 05:47 PM
  3. Replies: 19
    Last Post: 04-20-2012, 01:58 PM
  4. Maximum torque of stem on Niner carbon fork
    By Ryder1 in forum Niner Bikes
    Last Post: 09-30-2011, 07:25 PM
  5. Maximum torque of stem on Niner carbon fork
    Last Post: 09-30-2011, 03:02 PM
