Results 1 to 5 of 5
    Niner Air 9 RDO Brake Mount Question
    Hi, I am trying to mount a 160 mm SRAM XX Avid HSX rear brake rotor to this 2012 frame and can't tell if I need a post mount/bracket for this to work properly. Any thoughts or suggestions?
    Nov 2008
    I don't you think you do. My jet9 rdo accepts a 160mm rear rotor with no adapters or brackets, and would think yours is the same. Have you looked at the niner encyclopedia? A lot of good info there. You might also want to post this in the niner section for more confirmation.
    Reputation: Ronnie's Avatar
    I had a look at the Niner site and didn't have to go further than the home page to see this image so it would appear that a bracket is not needed.
    The trouble with having an open mind is that people will insist on trying to put things in it.
    Carbon & Ti rule
    Reputation: muzzanic's Avatar
    With XX world cup brakes the caliper bolts stright to the frame,
    With the older XX the caliper needs the little gray ball type washes between the frame & caliper 1 male & female each end under the caliper & 1 of each on top as well.
    I have a 6 Berth & 2 Berth Motorhomes that I rent out . They are based in Tauranga, New Zealand
    Good job!
    Thank you muzzanic. Exactly what I was looking for. Works perfectly.
    Quote Originally Posted by muzzanic View Post
