Results 1 to 67 of 67
    Niner $4500 budget
    My buddy asked me to find the perfect bike for him to replace his daily 10 mile run, knock around the Florida trails, and tear up the Smoky Mountains 8-12 times a year. He is 6'1' 220 lbs militarily type of guy. We both believe in buying the best quality you can and have a $4500 budget. Bumped upwards twice
    Full suspension 29er is a must as is XT level kit. Being big boys we don't really buy into the weight weenie stuff too much. We want something that can take a beating. We both ride KTM 950 adventures and have bent 2 front wheels before building a bulletproof set.
    Looked at the usual suspects Al Tallboy, Bandit 29er, Stumpjumper FSR expert Evo, Rumblefish pro, HEi Hei to name a few.
    Pretty much settled on a R.I.P.9 and got my LBS to match the best internet deal.
    I just wanted to get some other opinions of the specs before we pull the trigger. Going with a triple ring crank because there is a 40 mile paved bike path out his back door for the morning cardio. The FOX Talas terralogic fork seems perfect for his set it and forget it mindset and is plenty stiff enough for his use.
    Product Type Description Quantity Unit Price Ext. Price
    Frame Niner R.I.P. 9 Licorice Anodized 20.00 24.50 Disc 1
    Fork Fox 32 Talas 29 FIT Terralogic Black 15mm 1 1/8-1.5 95-120mm Disc 185
    Brake Shimano XT M785 | Black | 160.00 1
    Shifter Shimano XT SL M780 i Spec | Silver / Black 1
    Cable Shimano Stainless | 1
    Housing Shimano Housing | Dark Grey 1
    Crank Shimano XT M785 | | 175.00 | 38-26 1
    BottomBracket Shimano Hollowtech II | | Silver 1
    FrontDerailleur Shimano XT M780 1
    Cassette Shimano XT CS M771 10 | Steel | 11-36 1
    RearDerailleur Shimano XT M780 | Black | L 1
    Chain Shimano XT HG94 1
    Wheelset Stans NoTUBES ZTR Flow 29er/DT 240s Disc Disc Aluminum Rim Black STD 1
    Tire WTB Nano 29" Comp | Black | Kevlar | STD | 2.10 1
    Tube Butyl Presta Mtn 1.90-2.70 | 48.00mm 1
    Pedal Crank Brothers Candy 1 | Black/Silver 1
    Stem Easton EA70 | Black | 90.00 | 6.00 1
    Handlebar Easton EC70 Riser | Carbon | | 27.00 1
    Grip Oury Soft Grip | Black 1
    Seatpost Thomson Elite | Black | 410.00 1
    Saddle WTB Pure V Race | Black 1
    Sub-Total $4,499.87
    T
    MTB B'dos
    Reputation: LyNx's Avatar
    Pretty nice spec there, would suggest thinking using those wheel to their fullest and of go tubeless, also put a knobbier tyre upfront - Nano rolls well outback, but not a lot of grip if you're on loose stuff upfront, try an Ignitor. You may think you're going with a triple, but the spec you listed is the 38-26 double crankset and I actually don't see a need for a triple once you're using a full 9/10spd cassette that goes to 11t. FYI, to do 25mph running 38-11 (100.2 gear inches) you'd only need to be turning 84 RPMs, which if you're trying to gain fitness is nothing, 30mph is 101 RPMs.
    Feb 2007
    Nice Build, I am similar weight and just got a rumblefish elite and a new wheelset upgrade. I might make some other suggestions.
    I recommend the thru axle option for both the front and rear (this is optional dropouts for the frame) as this will stiffen up everything and you are ordering wheels. For wheels I went with Stans Flow rims and Hadley hubs for a custom build, not much more than the Stans wheelset but I believe it is a better hub. I also went with the Candy 2 pedals to get bearings on both sides instead of a bushing. Also go tubeless, it is easy and worth it.
    Chet
    Feb 2012
    Very nice indeed...also good to be spending your mate's money (wisely of course).
    I am just in the process of building my Air 9 now: = 4k build
    Air 9 2012 Black (M)
    32 TALAS 29 120 FIT Terralogic (95/120 Travel)
    Crank Brothers Cobalt 3 (Red) wheels
    Raching Ralph - 2.35 Front and 2.2 back
    XT 10 speed group set
    XTR 10 spd RD
    XTR Pedals
    Thomson 90mm Stem (90mm)
    Thomson Seatpost (straight)
    Fzik Gobi XM saddle
    Niner Carbon Bar
    Feel free to comment or make suggestions.
    Always Learning
    Reputation: BruceBrown's Avatar
    RIP 9 and a triple XT crankset? Be careful. Be very careful there with clearance and chainstuck issues due to chain bounce as the CVA is activated. I use a triple on my RIP with 23/30/40 rings because of it.
    Quote Originally Posted by jaydee1445 View Post
    Sub-Total $4,499.87
    Dump the tubes and go tubeless if you are taking the trouble to get Flow rims.
    Are you totally set on that particular fork? You could save money and dump some of the features that may not be needed with the model you have listed for your buddy. Make sure you read all the reviews of the complicated Terralogic function and how it does or doesn't couple well with the rear suspension. I think it would be great for a HT and XC racer, not so sure with a bike like the RIP and the tricky few settings that fork provides that it is ideal for a RIP. The RIP is one bike that I hardly ever lock the fork out (I do on all other bikes). So a more plain Jane fork from FOX may be a better golden ticket and save some $$.
    Abby Normal
    Reputation: Holmes's Avatar
    Quote Originally Posted by BruceBrown View Post
    +1 definitely worth it to go tubeless
    that isn't the estimate from the LBS but one of the online retailers, will definatly go tubeless. We are still futzing with cockpit cranks ect. I have seen the warnings from Niner about crank-sets, one online company offered dual chain ring another the triple. Going to be built by the LBS and they weren't sure as to whether get complete build from niner or source the components. He said it was weird sometimes was cheaper either way.
    I originally was looking at the Float 32 FIT The Talas was about $175 more. If it was for me I'd seriously consider skipping the terralogic as i'm always playing with the the rebound and compression on the KTM but i set up his 950 and It hasn't been touched since.
    I've read the naysayers on the terralogic and full suspension but others say they like it
    Jan 2009
    good work OP....when I was reading your post, the RIP came to mind right a way! Always start with a great FRAME!
    The terralogic is better (they say), but really any of the FOX stuff is really good!
    enjoy
    MTB B'dos
    I think I'd have to tend to agree with Bruce on the Terralogic also, just got my new F34 with FIT and lockout, like to have the control to choose when it's locked out and when it's not. Most of the time I've been riding with it full open and the low speed dialed 3/4 way in to stop brake dive and on anything but out of the saddle efforts it sits up nicely in the travel, but uses it's travel quite well.
    U sayin' Bolt ?
    Reputation: knutso's Avatar
    Nice build !
    I would second chet3 and say for sure go with a TA, at least up front.
    If y'all are generating the force to bust front wheels, the added stiffness will be appreciated.
    I would go with flat bars over risers, because with a big ol fork and wheels and a custom build you are gonna have plenty of leeway to raise the cockpit but not so much to lower it.
    Dec 2009
    For a rider of 220 lbs ...
    I would make the following suggestions ...
    - float fork over the talas (25-30% sag + 95mm travel = basically 0 travel left)
    - hadley over dtswiss 240 (the engagement is as good and you can shift the funds over to dh racing spokes)
    - definitely go tubeless if using Stans rims (unless you ride in an area with lots of rock)
    29er wheels (regardess of the rim) are going to be more flexie over their 26er cousins and with a rider 220+ its definitely will be an issue. While the Stan's Flow is a good, stiff rim you still need good, stiff spokes to back it up.
    After getting tired of constantly repairing a SunRingle Pro charger wheelset, I have been using a custom built Hadley Hub + Velocity P-35 + DT Swiss Alpine spokes with good success.
    The quiver: 2010 Santa Cruz Nomad, 2011 Specialized Demo II, 2011 Canfield Brothers Yelli Screamy.
    Maybe the Talas 140 FIT would be the better choice. It would fall between the 100mm fork the y used in 09 and the 120- 140 they use now. 100mm gave a headtube angle of 71.5 deg 120mm=70.5 and 140= 69.5 so I'd guess 110mm would give 71 degrees. whereas 95mm would be like 72 degrees. i know there is a calculator around somewhere but I'd bet these # are close.
    IMHO this is the ticket for the R.I.P.
    34 TALAS 29 140 FIT RLC
    Specifications
    Weight
    15QR (includes axle)
    4.54 lb / 2.06 kg
    (1.5" taper steerer)
    Weight taken at 165mm steerer length with star fangled nut and disc brake guide installed.
    Travel
    4.3 inches / 110 mm
    5.5 inches / 140 mm
    Steerer
    1.5" taper aluminum
    Riding Style
    Trail, All-mountain
    Adjustments
    Rebound
    Low-speed compression
    Lever actuated lockout
    Lockout force adjust
    Air spring pressure
    TALAS 2 position travel adjust
    Lower leg
    15QR thru axle system, post style disc brake mounting
    Spring Air
    Fork color Black Diamond
    I can't believe anyone needs a $4500 full suspension bike for a state that has less hills than my driveway! Rigid single speed would help get his trails on their feet.
    MTB B'dos
    Who NEEDS anything, we're human beings, we WANT I sure as hell don't need my nice, new Banshee Prime with 130mm in the back and 140 upfront, but man is it fun and does it smooth out the trails and bumps nicely, if I want to feel more I have a nice HT and Rigid.
    Quote Originally Posted by SS Hack View Post
    Reputation: eurospek's Avatar
    As others have mentioned, for his weight and size, I would definitely be rocking a Fox 34 up front. Especially since you have a nice budget. The Talas 32 will feel flexy.
    konahonzo
    Feb 2007
    The roots on some of the Florida trails are horrible, full suspension is for small bumps and big drops.
    Chet
    Some people venture farther than the end of their driveway
    Plenty of hills within a overnight drive we do it with the motos all the time.
    Always Learning
    That's like living on Mac' and Cheese when there is so, so, so much else out there to dine on and enjoy...
    rider
    Jan 2005
    Transition Bandit Two9 frame w/build kit. Get a whole lot better bike & save a pile of $$$.
    Link: Transition Bikes
    Abandoned the 26" wheel in May '03
    Quote Originally Posted by 29erchico View Post
    Better is such a subjective word specifics please...........
    $1599 for the Bandit frame $1539 for the raw RIP9.
    errr...
    Reputation: chase1963's Avatar
    I think he meant the complete bike.
    Of course we all need more than one bike! But it seems over kill and since this guy is a super tough army guy, then a cadillac type ride may not suit him.
    rider
    Jan 2005
    Ok,
    $3549 for frame & Transition's build kit. Comes with a Fox 34. Pedals not included. Dropper post optional. Check the parts on the build kit list.
    The Bandit Two9 has way better geo: 68.5 HTA, 17.6" CS length for example. Makes it fun, playful, flickable and yet surprisingly stable and confidence inspiring on the downs. Rear squish is very plush with no wallow. It is very stiff & loves to stuffed/tossed hard into turns w/o any wiggle. A few riders are really praising it's composure in the air with video to prove it. I have not hit any bigger jumps yet.
    Some reviewers are calling it a game changer in the 29er trail bike world. I know for sure that it is a huge leap forward in fun on the trail.
    Most important is that it comes from a company that is known for getting things right. Build quality of my frame was the best I have ever seen.
    Niner's QA has been spotty for a while now. The WFO9 frame I bought a few months back was built so wrong that it was dangerous. I have the serial # and my dimensional analysis numbers right in front of me on the ovalized and mis-machined head tube if Niner is daft enough to challenge me on this statement.
    Quote Originally Posted by chet3 View Post
    Please don't tell the rigid SS guys out west ...
    offroader
    Dec 2008
    $4500 for a bike is stupid. I've never paid more than $1500 for mine. Bikes are disposable. They're meant to be ridden and thrown away not shined up and hung on a wall.
    Quote Originally Posted by CupOfJava View Post
    Try putting $4500 in an investment calculator and see what you'll have at age 65 ...
    You're doing it wrong.
    konahonzo
    Rip is my fav bike and I agree with most of what the others have said.
    Terralogic is a waste on that bike. I would run a float 120 or a talas 140
    Beefier tires for sure at least up front. I know he will do a lot of cardio so maybe a second set.
    Tubeless for sure
    Ok,
    We have a transition dealer that's really cool Just can't get past the X7 kit.
    I love my XT 2way rapid fire and hate my sons X9 can't guess how bad X7 would seem.
    If we went with Bandit 29 frame and the same spec build kit we be at the same price point.
    Do you spend all your time trolling OP threads
    Some people already have the investment side covered and can afford the nicer things in life.
    Always Learning
    Being an owner and rider of both a 29"er rigid SS (with V brakes to boot) and the RIP, I can chuckle at any utopic thoughts of rigid SS. The OP and his buddy certainly seem to be on track with focusing on one of the better "do everything" 29"ers out there to take on their local trails and travel to the mountains the better part of a dozen times per year. The RIP is an excellent mid-travel "do everything" bike - no matter how disenfranchised you might want to be towards the OP and his buddy based on the price and amount of suspension.
    Thanks Bruce
    OK I've been trying to contain my self and keep things on a professional level but I missed the army guy comment.Now that this thread has gone to hell may as well take off the gloves. Are all the Bay Area riders asshats that get jealous of someone that wants and can afford the best or is it just this noob troll? Bet he would really freak if I showed how many assault rifles we have. Hack go back in the closet and shut up if you can't contribute anything positive.
    Try putting that same $4500 in the market 10 years ago and tell me how much you would have today?
    Bandit 29 FTW!!!
    Reputation: In-Yo-Grill's Avatar
    Thanks Bruce
    OK I've been trying to contain my self and keep things on a professional level but I missed the army guy comment.Now that this thread has gone to hell may as well take off the gloves. Are all the Bay Area riders asshats that get jealous of someone that wants and can afford the best or is it just this noob troll? Bet he would really freak if I showed how many assault rifles we have. Rigid go back in the closet and shut up if you can't contribute anything positive.
    Some people just don't get it...
    A Yugo will get me to most the same places that my Chevy 2500 HD will. The difference is in the technology and engineering that went into my truck is far superior and will last longer.
    When I bought my first bike 10 months ago I thought $500 was steep. Now I have five bikes hanging in my garage worth well over 10K. Since the family has gotten into riding I've spent more time with my wife and teenage kids than ever. They look forward to each ride. I couldn't put a price on that if I tried.
    Reputation: dirtdog's Avatar
    RIP for cheap
    Saw this deal at Hammmerhead Bikes...
    RIP9 XT Revelation RCT3 Closeout - Hammerheadbikes.com
    Looks like what you are looking for...
    The mantra I hear over and over is buy the best you can afford the 1st time. Cheaper in the long run than not being satisfied with the junk you bought and having to buy twice.
    Now that that is settled Which fork? 34 TALAS 29 140 FIT RLC or 34 FLOAT 29 140 FIT RLC
    pretty much decided against the terralogic because of issues stated with the FS frame. I asked Fox and their reply was less than encouraging
    "Although the Terralogic system was originally designed around a hard tail or full suspension frame with an inertia valve shock. Many more riders are starting to use them on their traditional full suspension frame with great success. "
    The 400grams weight penalty of the Talas is a small issue but the adjustable travel would be nice to set handling for conditions. I'm haven't totally wrapped my head around the angle - length - trail relationship but I think having the option of quicker steering or more stability to fit conditions would be a plus.
    On the other hand it has been pointed out the float is a better overall performing fork. The Float looks to be about $50 less.
    offroader
    Dec 2008
    Quote Originally Posted by In-Yo-Grill View Post
    When I bought my first bike 10 months ago I thought $500 was steep. Now I have five bikes hanging in my garage worth well over 10K. Since the family has gotten into riding I've spent more time with my wife and teenage kids than ever.hey look forward to each ride. I couldn't put a price on that if I tried.
    The technology is better on a $4500 bike? Man the marketers are doing a great job. They've been able to drive the price up from $1000 for a high end bike to over $4500 in just 5 years.
    Quote Originally Posted by dirtdog View Post
    The niner cockpit and Revelation RCT3, 120mm are nice, I think the sun ringle rims are the deal breaker
    Other than which fork and tires here are were we at with specs
    Fork Fox 34 Talas 29 140 RLC FIT Black 15mm 1 1/8-1.5 110-140mm Disc 185 1
    FrontHub Hadley Disc | Gold | 32 1
    RearHub Hadley Disc | Gold | 32 1
    Skewer Salsa Stainless flip-off | Black | Stainless steel 1
    Rim Stans NoTUBES ZTR Flow 29er | Black | 32 | UST 1
    Spoke DT Swiss Competition 14/15g | Black | 64
    Nipple DT Swiss Alloy | Gold 64
    Headset Chris King Mixed Tapered Inset | Black 1
    Stem Crank Brothers Cobalt 2 stem, (31.8) 6d x 90mm black/silver 1
    Handlebar Crank Brothers Cobalt 2 | Black | Aluminum | 27.50 1
    Seatpost Crank Brothers Cobalt 2 seatpost, 30.9x400mm (0 offset) NLS 1
    Bandit 29 FTW!!!
    We only have ourselves to blame for the price hike. As far as the technology being better on a $4500 bike...well yes. Better components are going to cost more. I bought my wife's bike off the rack of my LBS. Not normal for me because I refuse to pay retail. I have since upgraded many of the components and the difference was night and day.
    The bottom line is if I want to pay $4500 for the lightest, strongest, rarest colored skewers on the market, what do you care?
    offroader
    Dec 2008
    If you care what other people have to say then don't post it up on the internet.
    Bandit 29 FTW!!!
    Asphinctersayswhat?
    This thread will be closed down in T-minus...
    Is there always this much trolling on MTBR or is the price point of this build bring out the jealousy out of a group of little boys that have to justify their lower level junk?? If I said you could have any build you want up to $4500 would you spend $1500 and give the change back?
    BTW I bought a MB Fantom Pro XT/XTR with CR brakes because $1300 was all I could afford. If I had the available funds I would have this build no question.
    Asphinctersayswhat?
    T minus 8sec
    offroader
    Dec 2008
    What surprises me is some people think that spending $4000 on a bike is fine and good and anything less is junk. These are likely the same people holding in ipad in one hand a lengthy credit card statement in the other and complaining out taxes and how out of touch our government is with the working people. Btw I love my 1500 bikes all 4 of them. I don't consider them junk. They're probably light and faster than most bikes.
    Sorry if this sounds like a sermon but its in response to the 1500 bikes are junk statements. And if I ever felt like spending $4500 (probably never) it would be on a custom titanium bike, and not on a pos aluminum throw away frame.
    rider
    Jan 2005
    I really like most of the parts that you have listed on the build.
    But the term recoiling in horror would describe the following:
    27 inch handlebar
    90mm stem
    Salsa Stainless flip-off skewer
    frame by Niner
    Wider bars and shorter stem would be a lot more fun. I'm 6'3" & 225#, riding a 50mm stem with 29.5 inch bars and my old bike has 27 inch bars and a 90mm stem. So I do have the direct experience to make this statement.
    A 5mm skewer with a 10mm dropout? Is the 12mm x142mm axle upgrade not yet available for the RIP9? Very good idea for a big guy & stock on the Bandit 29 and other modern bikes.
    HTA on the RIP9 will be 69.5 degrees with a 140mm travel fork. The Fox 34 has 51mm of offset. This HTA and fork rake will result in a trail # that is on the short side for the kind of bike that it is. An aftermarket RockShox Revelation 140mm with 46mm of offset might be a better match for that HTA and type of bike. The Bandit 29 was designed around the 51mm offset of the Fox 34 with it's 68.5 degree HTA.
    Why not go with a fully modern design? I will admit that it took me good while to decide to go out of my known comfort zone in bike geo and setup. But I am obviously wildly impressed by the results and am very happy that I made the leap of faith to Transition's style of bike.
    Me thinks I'm starting to understand.............
    the bandit 29
    Could use the xtra grand to buy canes for lil old ladies
    <iframe src="http://player.vimeo.com/video/27448362?portrait=0" webkitallowfullscreen="" mozallowfullscreen="" allowfullscreen="" frameborder="0" height="225" width="400"></iframe> from Transition Bikes on Vimeo.
    Feb 2012
    I might get some back lash but I have been subscribing to the buy two 2500 bikes rather than one 4-5k bike. I ride the 29 fsr stump
    Bryce Jenkinson Photography
    www.studioido.net
    Where is the nuke button?
    Decided I'm not ready to be banned quite yet.
    Reputation: Camel Toad's Avatar
    I thought I was looking to spend about $4500 as well, and ended up finding my RIP9 on ebay hardly used, for less than half of that including shipping. I spent about $300 for assembly, tune up, new cables, new tires & pedals. I will also spend a bit changing it from 3x9 to 2x10, but even after that I will still have a lot of that original budget left over. The bike came with ZTR Flow wheels & tubeless as well, which was nice.
    Good luck
    Thanks Bruce
    No not every one in the bay area is like this clown,but im sure guys like joe breeze ,steve pots, ross schafer,bruce gordon,scott nicholes,levi lipheimer,just to name a few will love the compliment as mouc as me butchering their names
    AZ
    AZ is offline
    Reputation: AZ's Avatar
    The confusion between "need" and "want" is common. No worries, someday you might stumble upon a clue. Until then, get permission from your mom before you log onto the computer.
    Sweep the leg!
    Reputation: Caffeine Powered's Avatar
    Mar 2005
    Quote Originally Posted by jdusto View Post
    It pays to have a wheel builder with a clue but I'll argue that you can't tell a properly built 26" from a properly built 29er wheel on a trail. Wheel flex is all in your head. Tire flex is another matter.
    With a $4500 budget if you buy the wrong part it's your own fault. A big budget opens the possibilities considerably.
    Authorities speculate that speed may have been a factor. They are also holding gravity and inertia for questioning.
    rider
    Jan 2005
    For what it is worth, I was talking to the Transition guys today and they said that the Talas is sticky in it's travel compared to the Float.
    I'm currently riding my Btwo9 with a Loop 140. Love the fork, just thinking about getting another frame & fork to hang my HD wheelset on for days when I shuttle or ride lifts.
    No, I do not need two of these bikes...
    Quote Originally Posted by 41ants View Post
    I have and it has doubled or more in the last 2 years.
    Always Learning
    Well, I guess we won't be seeing you on the likes of an Air 9 RDO, an S-Works Stumpjumper, a Scott Scale 29 RC, etc... .
    Guys are actually riding these bikes, and not hanging them on walls. Imagine that?
    Reputation: SeaBass_'s Avatar
    I loved my 950ADV!
    Bent my front rim too!
    Quote Originally Posted by SeaBass_ View Post
    I loved my 950ADV!
    Two words "Woody's Wheelworks"
    I would like to see the reaction of some of the $$ weenies when they see $2000 for a set of Woody's 9fidy wheels. I'll get around to posting my 950 story in the Moto thread. Sure do miss it.
    Pretty much the combined wisdom for the forum. Stiction , weight and add cost overhaul due to complexity out weigh the benefits in my mind.
    looking around for deals on XT parts to come in at that $3500 pricepoint on a two9 hung up on the differences in bottom brackets and what I need for the bandit.
    Reputation: Spinning Lizard's Avatar
    I must be out of touch, my last set of wheels cost more then $1500, how do you buy a whole bike for that?
    Always Learning
    Quote Originally Posted by Spinning Lizard View Post
    We all know it has to do with the cost of the components that are hung on any particular frame. And we all know that top end frames can easily blow the doors off the price of a $1500 bike just for the frame alone.
    Although $1500 for a full build bike is not a bad price at all to get into a bike (something like a Trek X-Caliber as an example), compared to some of the parts one sees on more costly bikes - it's easy to figure out why the price differences between an S-Works Carbon bike with Carbon wheels, carbon cranks, lightweight 10 speed drivetrain, etc... offset it from an entry level bike's price.
    Those arguing in this thread for why anyone would want to or need to spend a lot of money on a bike are pretty much talking into the wind for those of us who do spend our discretionary $$$ on bike parts. The OP is talking about building a RIP, not a lower end HT.
    Typical culprits of increasing the cost today include...
    Carbon Wheels (Rovals are $1700, Easton Havens are $2300-2400, etc...).
    Top end "non-carbon" wheels from the likes of Industry Nine, etc... are easily $800-1100.
    Forks (SID XX World Cup is $1100-1200, FOX Float Terralogic is $900-1000+, etc...).
    Lightweight 11/12-36T 10 speed cassettes are $250 - $300
    Schwalbe Tires are about $80 bucks a pop (no pun intended)
    Top end clipless pedals range from $150 - $375+
    And on and on it goes.
    Having built my own RIP 9, JET 9, Salsa Dos Niner, Surly Karate Monkey, my wife's Air 9.....it all adds up rather quickly and a target in the $4K - $5K for a RIP 9 is pretty realistic. And it's easy to even go over that range without too much difficulty. Even going Plain Jane with a wheelset for $600, a decent 120-140mm fork for $800, and a closeout RIP frame for $1539 starts the build off at $3K before hanging all the rest on the bike.
    OK guy's vote in my poll here
    Feb 2012
    Niner RIP XT
    $3440. Moved up from Switchblade. Just got it a few days ago. 29lbs. Sweet ride.
    Pass the popcorn, please.
    Reputation: The Prodigal Son's Avatar
    I love my XL Niner r.i.p. I built it with my older xtr triple ring crankset I had been using on my Canzo. Had big problems and had to purchase custom middle and large rings (30 and 40 tooth) from a guy in Austin, to get it working right. I'd suggest going to a 2x10. I'd also suggest going tubeless. I have two set of wheels. A pair of Arches and a pair of Flows. I went with the Reba RLT ti fork and set it up at 130mm. I got it with a 20mm thru axle. Love the way it performs out here in Flagstaff and Sedona. It's a small difference, but you might enjoy having larger tires to grab a bit more surface area when dealing with some sandy Florida trails. A lot of r.i.p. riders are running 2.35's up front and 2.2's on the rear.
    Quote Originally Posted by RandyBoy View Post
    Quote Originally Posted by bomcq View Post
    how did you get a XT build for $3440
    Sure... I'm talking about broad market passive index Mr. CFA.
    I know very little - only what i do. I just know if you go cash during downward movements and then move to a typical index fund on the up swings you can make a little money along then way ...
    konahonzo
  67. #67
    Feb 2012
    Asked local Niner dealer for a quote on XT build of RIP. Came back with around 4k. I told him I could get a Tallboy XT for around 3k. He said he'd build one for about the same: Niner Hot Tamale Red, XT brakes (larger in front), XT derailers, XT cranks. XT pedals,XT shifters,XT cassette,XT chain, Easton wheels, sram9 hubs, Mavic 2.25tires, RockShox Revelation 140mm. $3.4k did not include 6.25% sales tax. You can spend a lot more (I have $1k Mavic wheels on my Switchblade). I'm 6.2 210, so I'm not a weight wennie.
    It may not be your ride, but I was just saying you can get a Niner RIP for less than 4-5K.
    I'd send pics but they won't let me post a link.
