Results 1 to 36 of 36
    Hope New to the wagon wheel club...need big rubber
    Here's the new pony in the stable; 2010 Intense Tracer XL / Reba dual air 140mm fork w/20mm maxle.
    Built up today with XT M770 drivetrain. Wheels are Staytru?? Never heard of them (but that's what I have now)
    So I'm giving this 29er thing a go! At 225lbs. 6ft 2in with a 36 inch inseam I've felt out of proportion with my past rides. Although I'm keeping my '07 Yeti 575 just in case
    Looking forward to re-learning to ride with the larger hoops. I purchased 2.4 Continental Mountain Kings and mounted them today, but they are pretty narrow for my liking. Actually ok for the back, but I need more girth in the front. Ran Maxxis Minions and High Rollers in 2.5 casings on my 26er, looking at Maxxis Ardent 2.4's...Any other suggestions out there?
    Biking Like Crazy!
    Reputation: blcman's Avatar
    Take a look at Schwalbe's Hans Dampf. It's says it's a 2.35 but it's massive and tubeless ready.
    Get the TrailStar compound if using it on the front.
    My 2c.
    2017 Niner Rip 9 RDO Pushed Version!
    2015 Ibis HD3 w/ Push ASC3
    2014 Niner Rip9 RDO
    2014 Knolly Podium
    Maxxis Ardent 2.4
    or
    Schwalbe Hans Dampf 2.35" Trailstar
    or
    Kenda 2.35 Nevs
    Conti always run small....
    used to be RipRoar
    Reputation: TraxFactory's Avatar
    Sep 1999
    Yep I feel the same, want more beef up front...Ardent 2.4 and WTB WW 2.55 some of the bigger tires I've run. I've been wanting to try the HD, not cheap..
    Reputation: kragu's Avatar
    I've used the Ardent, Rampage, Nobby Nic, Hans Dampf, and Nevegals. The HD is by far the best, with the NN in 2nd. Usually pricey, but can be had for $60 here:
    http://www.ebikestop.com/schwalbe_ha...ail-TR4915.php
    Buy from there or have CC price match and ship free...
    Mar 2011
    As others have said the Hans Dampf is a solid option. Ardents are ok, not as good at cornering in my experience. Nobby Nics are also ok. This is all fairly terrain dependent though...
    I'm told that Maxxis are going to make Minions and HR2's for 29ers, they should be available soon. It's going to be interesting to try those. Minions are my favourite 26" tyre (at least for fun riding) but the Hans Dampf is pretty good.
    R.I.P. DogFriend
    Reputation: jeffj's Avatar
    At two or three inches taller than the OP and a fair bit heavier, one of the first pleasant surprises for me with regard to 29" wheels, was that I found I didn't need quite so prodigious knobbage as I did with 26" wheels. I went from 2.5" Nevegal front tires to 2.2" and 2.3" front tires that rolled much better, and became faster in the process. I also went from 2.3" - 2.4" rear tires to 2.1" and 2.2" rear tires.
    You may still end up wanting to roll with something like the Hans Dampf, or Maxxis has recently announced 29" versions of the Minion and High Roller II. But I would suggest keeping an open mind about what may or may not work on 29" wheels as your experience with similar 26" tires may be different from what the same tread will provide on your new 29er.
    Reputation: millertm's Avatar
    Quote Originally Posted by jeffj View Post
    +1, Your 29er does not need the 2.5's. Air volume is much better on the 29 and your footprint is larger with a 2.2, then a 26er 2.5. Remember that your 29er is not a DH bike. You might pull off an AM setup but unless you have the 2014 Enduro from Spec, XC and light AM is all you can ask at your weight. If you do find a 2.5 to fit your fork take some pix, I would like to see that.
    Mark
    2012 XXL Carve Expert
    Surly Knard if they'll fit.
    May 2012
    Schwalbe or Kenda...
    MTB B'dos
    Reputation: LyNx's Avatar
    Jeff and Miller both speak the truth, before you go writing off the Mtn Kings just for their size give them a shot, you most likely will be surprised at the grip the longer contact patch the 29er has does to a tyres gripability (trademark of that word pending ) Seriously, you have suspension F&R, they should work well for you. Lots of recommendations for the Hnas Dampf, but one little bit of caution, if by chance like me you live where there's loads of sharp coral, don't get them they'll be toast in no time at all, knobs will just start to shear/rip off.
    Chilling out
    Reputation: bear's Avatar
    Maxxis has some phatter 29er tires coming out this year (think Minion derivatives), I'm looking forward to them quite a bit.
    I've only a couple rides on the Hans Dampf but like it a lot so far. Would also consider the 2.35 sized Nobby Nic Snakskin as a possibility too.
    Great replies and opinions....Pretty sure I'll want to try the HD or The Ardent, but super excited to hear about the newer addition to Maxxis' lineup with Minions and HR II's.
    I am waiting on the brakes to arrive so I can finish the build, but I will try the Conti's since they are mounted. I will give a report back on them but just saying it looks wrong already. Most likely I will keep the front and use as a spare rear!
    I never described the trail conditions here in North Texas, but it is varied. ( rocky, root infested, hard packed, sandy loose over hard, sharp limestone creek bottom ledges, cactus, furry rodents and armor plated armadillos)... I have seen everything used, and have used many different tires. Conditions do vary from trail to trail, but for where I ride consistently it encompasses all the aforementioned elements. After experiencing failures on weaker more anemic models, I have been much happier with a stronger larger even dh casing tire.
    Case in point, I went out yesterday and possibly suffered a career ending blow to my beloved Yeti on one of the many rocky downhill sections. The front tire kicked up a brick sized rock (as has happened many times before ) but this hit higher up the downtube where the material is thinner and left a 2 - 2.5 inch dent so bad it creased the tube outer edge. Will have to have it checked out. I'll probably post this with pics in the Yeti site.
    Thanks again for the responses. Also scvkurt03, appreciate the heads up on the price match, will look into it.
    MTB B'dos
    Can only give feedback on the HR2, but my experience with the proto is that it's a great all around tyre and the EXO casing has stood up well for over a years use off and on on our coral rocks. Think there'll be a few different compound options, not sure and I think the size is 2.3". Passed on the DHF as it was just too much of a beast to me for what I ride, but I'm guessing you'll like it. Check out Bholwells post in the Banshee forum on the Prime Production thread, he has photos of the DHF on his Prime.
    Quote Originally Posted by keithrad View Post
    I never described the trail conditions here in North Texas, but it is varied. ( rocky, root infested, hard packed, sandy loose over hard, sharp limestone creek bottom ledges, cactus, furry rodents and armor plated armadillos)... I have seen everything used, and have used many different tires. Conditions do vary from trail to trail, but for where I ride consistently it encompasses all the aforementioned elements. After experiencing failures on weaker more anemic models, I have been much happier with a stronger larger even dh casing tire..
    Nov 2012
    Big Rubber
    TR
    TR is offline
    Angry bunny
    Reputation: TR's Avatar
    Will depend on your trail conditions but I found the Ardent awful up front.
    Hans Dampf is great but I want to try the Geax Sturdy.
    Loved it as a 26 and it looks every bit as aggressive as the HD.
    Does not seem to get much love here though.
    MTB B'dos
    I'm on the same page as you with regards to the Ardent, one of the few Maxxis tyres I do not like, at least not upfront, great volume though. I'd love to give a Sturdy a try, but you can't find them anywhere to buy easily. Also was some talk that the compound was hard as hell and offered not much grip, unlike the Dampf, who's compound seem smaybe too soft if you've got jagged coralstone rocks to deal with.
    Quote Originally Posted by TR View Post
    Nov 2012
    just got a set of geax sturdy's on my bike but haven't had the chance to get much riding in but so far so good. I had Geax mezcals on which are totally the other direction. Mezcals are small knobbed and pretty light, the sturdy are heavy as hell but have some pretty meaty knobs on them. They are 2.3 but they seem to be pretty damn big, there is barely clearance in the rear of my yelli screamy with them.
    I hope the sturdy proves to be a good tire because I was also able to find it much cheaper than the other options like $70 for the pair of them shipped to me.
    MTB B'dos
    So, why not share a link for those Sturdy's? ;-)
    Quote Originally Posted by cpfitness View Post
    Nov 2012
    Re: New to the wagon wheel club...need big rubber
    Think I got them from bikemans eBay site. Search Vittoria sturdy instead of geax sturdy. I distinctly remember them.being listed that way
    Sent from my DROID RAZR using Tapatalk 2
    Nov 2012
    I checked. Got them from bikewagon s eBay site. They were probably clearance, I wonder if geax is going to come out with a bunch of new tires Cruz it seems.like they aren't very popular right now
    Jan 2009
    I'm a 5' 10" 185 lb. rider in Utah, so plenty of hard pack, rocks, and loose dirt. I replaced a Panaracer Rampage 2.35 with an Ardent 2.4 up front and have been very happy with the improvement. Faster rolling, better braking, and much more lateral grip. All the talk about how much better other tires are has got me thinking I'm missing out!
    Jan 2003
    I'll echo the Schwalbe's Hans Dampf comments....guy around here rides them, they're like freaking monster truck tires.
    Climbing Builds Character
    TR
    TR is offline
    Angry bunny
    MTB B'dos
    Thanks TR. I got a guy coming in from Scotland next month, may ask him if he could bring one of these down for me
    TR
    TR is offline
    Angry bunny
    No free shipping to you from Wiggle?
    That is what I love about them.
    Free shipping above a small minimum and a lot of the time I have the stuff to me in under a week.
    Zaf
    Zaf is offline
    Reputation: Zaf's Avatar
    Mar 2012
    Beauty of the Ardent is you can get it in a UST format; if you're riding rugged terrain is a really hard thing to pass up when it comes to durability, can stand up to a fair bit of punishment. Weight wise, mine hit the scales at about 850g, but it is true tubeless, has amazing sidewalls on it and you could practically seat it by blowing softly on the valve stem.
    change is good
    Sep 2004
    Gato TNT. I'm 230 and I'm running 16lb on the front of my FS. I didn't want the volume of the HD, but I'm amazed how much traction this tire has.
    Root Master
    Reputation: TwoNeener's Avatar
    I am really liking the Hans Dampf on the front of my bike. A lot. Traction for days and it's a legitimate representation of the width it claims. Only con is that it's a bit heavy, but, whatev.
    Join the Tribe...
    MTB B'dos
    They don't even ship to Barbados, would have to ship to a forwarder in the US and have them send it down While CRC posts directly down here and are my go to online e-tailer these days, but they don't have any of the Geax tyres - would like to maybe try the Gato as well/instead.
    Hmm, that looks a lot like the Captain. My Son's RH has one on the front and a fast track on the rear, they work great.
    Mark
    Attached Thumbnails Attached Thumbnails New to the wagon wheel club...need big rubber-captain-grid-ust.jpg
    TR
    TR is offline
    Angry bunny
    Sorry, about the only similarity I can see between the Sturdy and the Captain is that they are both black, round and have knobs.
    Having used both I can assure you that is where the similarity stops.
    I was looking at the twin gaps of nothing between the center nobs and the side nobs. That tire just reminded me of the Captain. I know that Spec is dropping that tire for the GC. However, it is a nice XC tire with low resistance. My son is fast with that combo. However, when we start downhill the GC shows up and Cole has had a few falls trying to stay with me.
    Mark
    OP: you bought the wrong Conti "King"
    The Trail King 2.4 folding...they will seal up as tubeless, but will take a couple of tries. But they weigh like a boat anchor...1110g ea! But, they're BIG...
    Rod
    Rod is online now
    Reputation: Rod's Avatar
    Oct 2007
    I've haven't ridden tires as big as the OP wants since the last time I drove a tractor... sheesh!
    There is not much choice between rotten apples.
    New to the wagon wheel club...need big rubber-dat-bike-tire.jpgNew to the wagon wheel club...need big rubber-dat-bike.jpg
    Quote Originally Posted by Rod View Post
    merst have burnn a mirty fiern trakTer that' un!!
    Here's the Conti. in the fork, and the build coming along!
    So the Conti's run small...more like an 2.1 actually. Does anybody know if a true 2.35- 2.4 will fit in the Reba Team 140mm?? Added to the Intense forum...
  1. Replies: 8
    Last Post: 09-27-2012, 04:50 PM
  2. Neon wagon wheel top cap?
    By greasemeat in forum Specialized
    Last Post: 04-19-2012, 06:58 PM
  3. "Wagon Wheel" top cap
    Last Post: 02-11-2012, 06:34 PM
  4. Jumping on the wagon wheel train
    By Truckee Trash in forum 29er Bikes
    Last Post: 10-21-2011, 02:09 PM
  5. 10spd on your wagon?
    By markyboy1980 in forum Maverick
    Last Post: 03-25-2011, 11:54 AM
