Results 1 to 13 of 13
    Jan 2015
    New carbon frame with "old" 12x142
    I'm looking to buy a new trail frame to accommodate my current carbon wheels and expensive hubs which are 15x100 12x142 and pike 120mm. I'm wondering who makes a frame that would match that except the Specialized Camber. Or maybe a use one would be better because there would be better choices? I currently have a 2014 fuel ex 9.9 and I'm looking for a shorter Rear center and longer front center.
    I thought about an older tallboy, but that wouldn't be much of an improvement.
    Need help. Thanks
    Fat Skis/Fat Tires
    Reputation: rangerbait's Avatar
    Turner Czar
    Jan 2015
    Quote Originally Posted by rangerbait View Post
    Turner Czar
    That is not a trail bike, that is a xc bike.
    Evil is selling v.1 Followings for about 2g right now. It fits your requirements. I'm kind of in the same boat, but looking aluminum just to save few bucks.
    canfield EPO is a trail hardtail (I just bought one). Also have a turner czar with 120mm fork which makes a great trail bike. If you need a little more bike the following is a good choice.
    Fat Skis/Fat Tires
    Quote Originally Posted by Alain2 View Post
    Fake news. The Czar with a 120mm Pike is a very capable trail bike.
    Elitest thrill junkie
    Reputation: Jayem's Avatar
    Look at Pivot, I'm sure there are some 2016 and 2015 models running around online that are 142.
    Reputation: kragu's Avatar
    Just built up a used v1 Following. Sounds like it'd work for you.
    Can you convert the hubs to wider?
    The bike industries master plan is working...
    Small ring in front makes it easier. Small ring in back makes it harder. That blows my mind.
    Jan 2015
    Wow, I didn't know that was possible. Problem solved I guess. I'll probably get a norco optic and bump my pike to 130mm.
    You said longer front triangle? Yes, the Czar fits the hub spec, but the reach is pretty darn short to begin with. With a 120mm fork it's a great trail/race bike, but it also shortens the reach and slacks the seat angle a bit. I couldn't make my 120 Fox 34 Czar fit perfectly for climbing (I'm 178cm/5'10") no matter what I did with stem, bar, spacers, saddle adjust, etc. whereas others have great success. Returned my Czar to 100mm and sold it to a family friend who is now shopping for a 2018 Camber Expert for the wheel situation the OP writes of.
  1. Replies: 4
    Last Post: 03-31-2017, 04:42 AM
  2. what frame fits my wheelset 12x142 tru-axle
    By Spattah in forum Bike and Frame discussion
    Last Post: 07-17-2016, 08:08 PM
  3. "Budget" HT frames w/ 12x142?
    By bopApocalypse in forum 29er Bikes
    Last Post: 12-30-2014, 06:09 AM
  4. Reynolds Carbon 29er 12x142
    By freak6767 in forum Cannondale
    Last Post: 03-27-2014, 08:37 AM
  5. Replies: 3
    Last Post: 11-06-2013, 12:41 PM
