Results 1 to 2 of 2
    Bonking ... not feelin' well New Built- Supercaliber 29 FS- MAIN PIVOT Play- STRANGE ??
    Hi there all,
    This will be my new baby when built. Will post soon some pictures.
    I got frame- 2 pieces (main, swingarm) and shock separately.
    When putting it together, there seems to be a big gap (play)- 2 mm (millimeters) when swingarm installed on the main frame with the Thru Axle.
    CAN ANY OF YOU GUYS WHO KNOW THIS FRAME ADVISE IF THIS IS CORRECT.
    MANY THANKS !!
    More details: Looks like the thru axle only hold the bearing to the main frame and then the swingarm still slides freely on the thru axle. Then there are 2 bolts which tighten the swingarm to the bearing- which will prevent from sliding. BUT IS THIS SUFFICIENT- IS THIS DESIGN GOING TO LAST- LOOKS VERY LIGHTWEIGHT AND AND IMPERFECT TO ME.
    Many thanks for any insigth.
    P.
    Samsonite Tester
    Reputation: Evel Knievel's Avatar
    Pictures would help. It sounds like a bushing is missing.
    Yeah I gotta question. You got any excuses tonight Roy ? -Antonio Tarver
    There is room for it all, just ride what you like to on what you like to...that's freeriding. -rbn14
