Results 1 to 52 of 52
    Moderator please delete. Thanks.
    Problem solved. Kona took care of it. It was damaged in freight. Most derailled thread ever.
    Reputation: shiggy's Avatar
    Dec 1998
    New bike.. 2 millimeter Clearance on one side of rear cage. Need expert advice.
    Quote Originally Posted by STACK View Post
    I'm not a lbs basher, so I am going to be calm. But the back wheel of the bike I picked up today is not centered/true'd and there is literally 2-4 millimeters of clearance on the top right of the back cage. It is slowing the bike noticeably simply from the hairs on the back tire rubbing so deep. The clearance on the bottom of the back cage worried me when I picked it up, it's about a centimeter, I brought it up to the guy tht put it together and his answer was "it's not rubbing." I did not notice the off centeredness of the wheel causing the hair width clearance in the top of the cage.
    The bike is not high end, it's a kona mahuna. I did not expect it to be light, or anything spectacular, but I wanted to try a 29er for a couple years for some commuting and light trail. I had a blast as my first bike from 04 to 09' before buying a nicer specialized. The kona blast gave me ZERO problems for 5 years of trail riding for the price it was amazing. Anyways, how much clearance is the minimum which should be accepted from the bike shop? I can't imagine this bike not rubbing against the frame in short order, but maybe there is something about 29er bikes I need to know. I have previously liked kona's a lot, and I am a millimeter (literally) away from writing a really bad review. Also, I'm thinking about upgrading to a kula, would that take care of what looks like a bad factory frame and a lbs afraid to tell me that it is such?
    Some expert advice or other would be appreciated. I there is a kona rep on here, I was thinking about also getting a new blast to be my kick around 26, and Maybe you could save a couple future sales by explaining to me the best course of action.
    Cage? What Cage?
    If you are upset with the setup of the bike, ask to see the manager.
    mtbtires.com
    It sounds like the rear end is twisted. measure the dropouts from left to right in the same place, do this at different ends, and see if you get the same measurement every time, indicating they are parallel. You could also try putting on a different wheel to see if that is centered so you'll know if its wheel or frame. Generally, there's a lot less clearance by the chainstays (bottom cage in your terminology, I presume) because they have to be narrow enough for your pedals and chainrings to clear. Regardless, they should fix it and you should make sure another straight wheel works, as if they just redish the wheel to center it, you will have problems with other wheels and the frame is compromised as well as bent.
    Quote Originally Posted by shiggy View Post
    Cage? What Cage?
    The frame. The frame around the back wheel. I ordered the bike straight from the owner. She sounded like she barely had the money to pay for the shipping, respectively, I barely have enough to buy smaller tires and business is tough starting out. She already laid the "I won't be able to sell this" crap on me when I ordered the bike. I want a decent kona for light trail and commuting, I don't want to return the bike, but it looks like a frame problem and it's going to be a f'n hassle. This made in china crap needs to stop. Bikes are getting more expensive and the specs for the price and quality are going down dammit. I'm tired of it. It didn't have to be a raving bike, but these dam bikes need to WORK at over 700.
    Quote Originally Posted by PretendGentleman View Post
    Thank you. I could have lived with the oddly close chainstay distance, but the literal 2-4 milimeter on the top right side (as opposed to the 7/8 of an inch on the other side) is too much to deal with. I was a total easy sale because I just found the bike I wanted and ordered it without being a tough sale, and I feel as though being the easy guy to deal with is not paying off..
    It could be as simple as the wheel is in the dropouts crooked? If everything is in there straight, your LBS should be able to redish the rear wheel pretty quickly. You could that yourself, you need to tighten the spokes on the side it needs to move to and loosen the other side, 1/2 turn at a time. If you turn each spoke the same amount, the overall trueness should remain.
    Also, if you wheel is in there crooked and the brake is not rubbing, it will when you straighten the wheel. That is also a fast and easy fix.
    Is it offset on both the chainstay and seat stay positions?
    Thanks to www.weavercycleworks.com for my awesome bike frames!
    Hi There!
    Reputation: TheGweed's Avatar
    This has got to be one of the oddest posts I've ever seen on here. Who is she? Who said She already laid the "I won't be able to sell this" crap on me when I ordered the bike. I mean, wasn't that a clue? Where and how did you obtain this bike? And why wouldn't you return it? "I want a decent kona for light trail" so buy a better or new Kona. I may be dumb, but none of this makes sense.
    NTFTC
    Quote Originally Posted by Manicmtbr View Post
    Surprisingly it is only off on the seat stay. The bottom (chain stay?) is too close for my taste, but it's a big tire in there and I could live with that. I do bike maintenance after I've ridden a few rough rides, but I really don't want to true a wheel the day I get a bike.. I mean wtf are we paying for??
    Quote Originally Posted by thegweed View Post
    I ordered a kona mountain bike (over the phone) from a newer bike place which is in a city an mostly rents bikes, dealt straight with the owner who was kind of off and on and who gave me her cell number for no reason (I didn't ask for it) and then acted annoyed when I used it after she told me to do so. I picked up the bike today, and the back wheel isn't true'd and there is 2-4 millimeters clearance on one side of the seat stay. The owner already gave me a guilt trip about having to pay for shipping, which was odd to me. So basically, this being my first 29er, I wanted to know whether I was over reacting to the basically zero clearance between the tire and the frame, or if bikes (29ers) had changed and tiny clearances were normal.
    If I am understanding, it is closer on the bottom than the top? Or vice versa? If so, I think your wheel is just in there crooked. Loosen the Q/R and see if you can straighten the wheel and tighten again.
    Or just take it back and have the shop check it out?
    squish, squish in da fish
    Reputation: fishwrinkle's Avatar
    ^^^yeah, that. make sure the skewer is plenty tight as it can be centered one minute then as you ride it will usually pull to the drive side. which sounds like what it's doin'
    Dec 1998
    Sounds like you just need to have the bike looked at by somebody that actually knows about bicycles. The fix is probably simple, but can not be solved over the Internet.
    mtbtires.com
    Elitest thrill junkie
    Reputation: Jayem's Avatar
    Buy a good (doesn't have to be expensive, maybe $500) bike from a shop and learn about bikes. Then go buying the craigslist stuff.
    I mag not have the lingo down, but I have taken apart a bike, changed/fixed broken chains, bled brakes, and added little things like new stems and parts to a bike. I have a bike multi tool, and I'm not afraid to use it. I'm also not a master obviously. But the guy who put it together is supposed to be better than me I believe, he does it for work. I could probably learn to do the job in a couple months of in the job training with what I have already done. But damn, when you buy a car are you suppose to have to change a f'n brake rotor the first day you get it?? And honestly, I think it's the frame, one side seems to flare out a little more than the other. It's china, they make sh** at low salaries and long hours as cheap as possible and they don't like the rest of the world that much, the lower quality while not really saving anything crap needs to stop. I have been pissed and ranty ever since I saw the problem. I bought a Scott last year that I got into an accident with (I got broadsided at night, almost head on but turned away last second) and the back tire rubbed against the frame.. I reset THAT wheel a centimeter every other week so I can still ride it, so this new bike looking like its going to be grinding it's wheel against the frame hit a bit of a soft spot.
    Formerly of Kent
    Reputation: Le Duke's Avatar
    First and foremost, perhaps you should learn a thing or two about bicycles. What looks to be a defect to you COULD be how the frame was designed. Assymetrical chainstays are nothing new.
    Also, you could have a wheel that is not properly dished.
    Or, the frame could have been damaged in shipping.
    There are literally hundreds of people on the "Chinese Carbon Frame" threads with positive experiences on $300 Chinese carbon frames. They've been raced by plenty of people, including the 2012 UCI XC Marathon world champion.
    Death from Below.
    Quote Originally Posted by Le Duke View Post
    I know more about bikes than my lack of correct lingo makes it sound. I'm thinking I should have just waited and got the moto titanium, speaking of chinese bikes.. I know about wheels rubbing against frames and how that is bad, because it happened to my Scott.. And I have been re-tightening it in the wrong spot so I can ride it and don't have to recycle the frame. The brake isn't rubbing, of I just readjust the wheel I can't see that staying the same. Could I mess with the back brake? Yeah, but I shouldn't freakin have to. I'm taking it back in 2maro to see of they can make it right, I know there is something wrong. And what you said about bikes geometry and me not being familiar with it, do 29ers have less clearance all around because of the size of the wheel? Because I have had a few decent 26ers and I know what they are supposed to look like..
    MTB B'dos
    Reputation: LyNx's Avatar
    Instead of strutting on here, why don't you try what has been suggested and see if maybe the wheel is not sitting in the drop out properly, even an experience person can make this mistake if in a hurry putting back in a wheel. If that's not the case, then at least say you tried that, so those on here trying to help can know you actually are giving a go instead of being an ass. If that doesn't work, then as said, you might have an out of alignment frame and that's between the bike shop and Kona, nothing to do with you, how much they paid to ship it in, anything, that's why you bought from a shop, let them deal with it.
    Lastly, a photo is worth a thousand words, especially when your terminology could be wrong and leading people astray in terms of what's going on.
    Kona would definitely warranty this if it is what it sounds like: a bent rear triangle.
    Stack, when you communicate with us, try to be more concise so we know what you're talking about.
    29ers do not have clearance problems with stock tires, It's possible, but very unlikely. The frame is probably the problem, but if they are able to fix the bike without making you wait for a new one, make sure you find another 29er wheel to put in the frame to make sure they didn't just dish the wheel. If they did you'll also notice that they may have fixed the gaps at the seatstays, the chainstays have uneven gaps, this is impossible to avoid when adjusting a wheel to a twisted frame.
    This is not something that is your responsibility. Go in there and ask them to warranty it; you do have legal rights. If they give you trouble, hopefully you payed with credit card and you can dispute the charge and move on to a different bike shop and get a new bike. If you did not pay with credit card and the shop won't work with you, contact kona ASAP. You need pictures of the problem too. Go check out Kona's website and compare online pictures of the bike.
    This has nothing to do with the quality of labor or machinery in chinese manufacturing. The chinese did not wrong you, the bike shop did. Low-cost manufacturing makes bike parts cheaper and better overall. Globablism has other problems, but its not a general decline in manufacturing quality of bicycles by any means. In general, you get a lot more bike for your money now than ever, but it's sometimes hard to see due to inflation and technology change.
    My CPU at home recently broke, and all I have is an I-phone. (go china!! Lol)
    I could text a picture, but I've never embedded a pic off a phone on a forum. I really wish I could though.
    Dec 1998
    If this "mechanic" and shop owner are as you portray them, they are not competent. Period. Seek other help.
    mtbtires.com
    It sounds like a warranty issue to me. The manufacturer will likely not be too keen on working with him through another shop. If you go to another shop and they warranty the frame, they might (reasonably) charge to change the parts over: charges for stripping one frame and rebuilding another can easily exceed $100. On a new bike the seller should take care of this as long as you get to them quickly. If they won't cooperate, hopefully you payed with a credit card, and your credit card company, assuming you have reasonable terms, has plenty of muscle to reign in a recalcitrant bike shop.
    Ok, I took it back today, after picking it up yesterday. The owner was there and she was very appropriate and courteous. She had the mechanic look at it pretty much right away. I went for a walk with the lady by the water while he looked at it. He couldn't fix it. It was actually making noise from running this morning. She is going to talk to the kona people and we are going to try and work it out. If a new frame is necessary I may upgrade to a better frame/model. I was as friendly as I could be, and she didn't make me feel to stupid for it, which I appreciate. But I knew there was a problem there, an I was right. It may have been damaged in transit or something. Like I said before, I had kona blast I rode HARD for 5 solid years not needing to make any major repairs even once.. So I guess this incident balances that out lol. I'm sticking with them because a bike you ride rocky/roots single track with that you got for less than1g is nothing to sneeze at, I hope it gets taken care of soon.
    get down!
    Reputation: appleSSeed's Avatar
    Stop bashing on China bro. You sound like an idiot when you toss that around.
    Rudy Projects look ridiculous
    visit my blog, BEATS, BIKES & LIFE
    Dec 1998
    Quote Originally Posted by appleSSeed View Post
    Agreed. I have seen bad stuff come from everywhere, including the USofA.
    mtbtires.com
    Dec 1998
    I can not say that yet.
    I think the bike should be looked at by somebody else, but that does not need to be another shop, just to see if there is a simple fix or if the problem is bigger.
    Does sound like his shop is willing to work with him--after he actually went in rather than just whine about it here.
    I would still recommend getting a 2nd opinion. No decent shop mechanic would let a new bike leave the work area--let alone out the door--in the condition described.
    mtbtires.com
    That's an odd post, or a post from an Asian, respectively. CHINESE people greatly respect American manufacturing standards, that is a little secret they are tring to not let out over here, but when the CEO of freakin Hershey's unveiled their new line of chocolates in china he repeatedly spoke about how "these chocolates will be made under traditional American manufacturing standards," because that is a BIG selling point on china right now. We probably should not ignore that the Chinese people feel that way themselves. I mean, THAT makes us look stupid. We have stricter manufacturing standards, if they know it we probably should too. I have a couple chinese frame bikes that have been no problem. And like I said, I am considering a moto to finish my collection in the near future. But I'll say it one more time, if American manufacturing standards and quality are a HUGE selling point in china right now, and that I how Chinese people feel, how stupid do we look ignoring it ourselves? I just like quality stuff. Replacing innovation with cheap labor has not been the best thing for our civilization IMHO. I respect Asian culture very much as a whole, to be honest.
    I barely said anything about china. Strange. It is a problem that 95% of the worlds bike are made in china. It shows you that the old models of comparative advantage that use to make sense out of the world economy are now useless.. It's not what you are truly good at, it's who has lower standards of living and less regulations. Well those things don't really dictate who makes better bikes. I believe china should of coarse make bikes, so should everybody else, them we can see whose are better. But everybody went there at once for a better quarterly balance sheet and it hasn't really been that good of a thing for the world. Bless that country, honorable people, but don't deny facts or ignore Whatvthe Chinese themselves think about it.
    But anyways, bike shop did the right thing. I think I will still get the bike I want in the end, and if it happens within 2 weeks I will be a satisfied customer looking at 26er..
    They tried to fix it today, but could not. The owner is going to contact kona to seek a remedy. The frame just looked off in the back. I have owned more than a few bikes and I could tell.
    Hi There!
    Just get your money back and go somewhere else.
    NTFTC
    Dec 1998
    Ummm...more than "barely" and very loud and clear.
    ...This made in china crap needs to stop...
    ...It's china, they make sh** at low salaries and long hours as cheap as possible and they don't like the rest of the world that much, the lower quality while not really saving anything crap needs to stop...
    My CPU at home recently broke, and all I have is an I-phone. (go china!! Lol)...
    And this whole post
    These make you look very bigoted and foolish.
    And while we are at it, 1cm of tire clearance at the chainstays is normal, and fairly substantial. I seriously doubt your bicycle knowledge. You ask for advice, then find reasons not to take it.
    mtbtires.com
    nothing to see here
    Reputation: Stevob's Avatar
    The first step to diagnose alignment issues is to remove the wheel and refit it backwards. If the alignment problem doesn't change, then it is probably a frame issue. If it does change, then it's a wheel build issue. Also inspect the dropouts to see if there is any imperfection there. It could also be a bent rear axle, but unlikely. Failing all that, bash China (insert sarcasm smiley). It seems you missed the first couple of steps.
    I see hills.
    I want to climb them.
    Look, it's ok that we sent our most important industries there, and many experts say its a bigger threat than terrorism to our national security, it's ok. I mean, architecture, engineering, IT, and other white collar jobs tht use to be the American dream are next. But it's ok, just except the trade deficit which allows them to buy our debt which we pay back at an interest ensuring their economic growth for the foreseeable future. The service jobs tht are going to be left in America are the jobs traditionally done by the third world contingent residents in first world countries. You can find more and more articles/scholarly papers on what off shoring is leading to (the American firms won't compete with china -its not a level playing field over there- with the Chinese firms and we will have just given them out technology/infrastructure secrets with absolutely no long term benefit) and white collar jobs up to and including legal services are going to be done by lower paid labor with little regard for quality. Luckily, re-shoring is actually happening. Quality issues, and the realization of short term freed decisions not being good long term plans are bringing jobs back to first world (regulation/manufacturing standard wise) places. Once I get to a CPU I will link a few articles to this thread done by some former high ups on what has really been done.. You can attempt to find articles to the contrary, but there are not that many. I am totally free market pro capitalism, but like absolutely everything else that exists, if it is not done with ethics or "right" it fails.
    Anyways, like I said, my bike which I happily purchased from wherever it was made apparently was not fixable according to the two bike mechanics that were there. The centimeter clearance (at most)at the chain stay did make me a little nervous, but I could accept that that was normal for the model. The clearance at the seat stay(?) that was less than half the tire hair length and actually rubing slightly this morning was obviously not acceptable. The owner agreed. I now wait. I think I'm going to throw an extra 350 down for the next model up, it may be the only 29er I have for 5+ years..
    Dec 1998
    Look, it's ok that we ...
    Stop digging and do not post the articles. It has been beat to dead.
    mtbtires.com
    Hi There!
    some people don't know when to quit.
    NTFTC
    Dec 1998
    Or where to start.
    mtbtires.com
    Or where to start.
    Wow, that was witty. I was exactly right with what I thought was wrong with the bike, and got the service and expect the result I also desired. Most Americans with a brain agree with the reality of what shipping first world jobs to third world places based on immediate quarterly profits has done to the middle class and the western economy. Use your "rep" to school me on bikes please, because I was right with everything I thought and said in this thread. Sorry I called the part of the frame that surrounds the wheel like a cage "a cage." I don't back down to a few people in a forum saying things that are contrary to the truth or trying to gets to change my accepted by many others opinions. Ssssssssorry.
    Reputation: Jakerz's Avatar
    Jun 2013
    lol this made me laugh, you came here to ask for help but already know more than anyone else on here? I also agree with Shiggy that a lot of the products coming out of China are not crap, and the savings the company gained are passed to us as the customer, as we no longer have to pay 5 union employees to do 1 mans job lol. (Yes, I'm union and I can make fun of it all I want)
    But anyway glad you found out your problem and hope you get if fixed.
    Jake
    Dec 1998
    And the hole gets deeper.
    When you have issues with a less than day old bike it is best to start by returning to the LBS, not by whining about it on the forums.
    I believe you when you say the wheel is off center. We still have no idea why.
    Do yourself a favor and have somebody, someplace else look at the bike. I can not correct your problems over the Internet.
    mtbtires.com
    Reputation: elcaro1101's Avatar
    You should either provide pictures or take it to a person for a second opinion as posted above. The lack of terminology isn't a huge issue, it is the way that you come across as a giant know it all, but your still asking for help on an Internet forum? See the juxtaposition here? They don't match.
    I couldn't resist.
    TR
    TR is offline
    Angry bunny
    Reputation: TR's Avatar
    This thread is a joke, right?????
    Reputation: Epic_Dude's Avatar
    May 2010
    Quote Originally Posted by TR View Post
    Yes and no, it's a drama thread. To recap:
    1) Original poster bought a Kona Mahuna 29" bike at a LBS.
    2) After owning the bike for a day noticed the clearance on either side of the chainstay isn't the same.
    3) Rather than taking the bike back to where it was purchased, posted his complaint on this forum.
    4) The LBS wasn't happy about placing a special order for their customer.
    5) OP bashes anything made in China.
    6) After several suggestions from forum members, OP doesn't want to spend time taking any advice and further diagnosing the problem, doesn't know how to post a picture from a smartphone.
    7) After complaining on the forum, the OP took the bike back to the LBS and they will call Kona on Monday to determine if a warranty claim can be submitted.
    8) Bashes US and Chinese manufacturers some more.
    9) After returning from the LBS, OP arrogantly posts that he was right even though nobody disputed his claim that there was a problem with the bike.
    10) Now says he wants to pay more money for an upgraded (but still Chinese) Kona 29er but continues to complain that US companies are to blame for the downfall of the American middle class.
    I think that sums up things so far. Stay tuned for the next episode of "As the Wheel Turns..."
    ride more
    Re: New bike.. 2 millimeter Clearance on one side of rear cage. Need expert advice.
    Quote Originally Posted by Epic_Dude View Post
    , nice
    I don't mind buying a kona from china, my first kona from china was the best under 1000 bike in history. I wasn't "right" about anything, other than there was a clearance problem. I was ranty because people who feel like they got ripped off usually feel ranty at first. In the midst of my phone rant (auto correct errors and all) somebody should have seen that I really just wanted some information on 29er bikes and whether they had really small clearances, like millimeters. In one of my early ranty posts I uses the term "cheap china crap" and was jumped on. The Chinese themselves prefer things made under American manufacturing standards, and they are more nationalistic and self proud than we are. Cheap china crap is a problem. Many products coming from china (with American/other technology a lot of time, and especially in the beginning) are of decent quality. I don't mind having a bike made there, but I don't like barely having an option either.
    People come here for actual help, your clogging it up with nonsense trolling.
    Go ride your bike, time spent doing that will be better than trolling the Internet.
    So buy a US made bike and stop whining like a little girl. Apart from US made frames, you can also buy components that were made in at least Japan if you buy XTR, keeping the $ in what you describe as the "civilized world". There are even US made handlebars and other parts.
    Crash Dummy In Training
    Reputation: PauLCa916's Avatar
    Jun 2013
    +1 Jayem
    Remember you get what you pay for.
    Some People want a $4,000 product for $1,000.
    No comment on the Political portion of this thread it really don't belong here O.P. And in most Forums would be grounds to close the thread.
    Good luck hope it all work's out in the end.
    Feb 2005
    I'm pretty certain this should have been posted in the Surly Troll thread...
    AZ
    AZ is offline
    Reputation: AZ's Avatar
    Nice troll. This thread is a masterpiece in the making.
    Reputation: SlowPokePete's Avatar
    Mar 2006
    Quote Originally Posted by Dirty $anchez View Post
    Every once in a while a new thread like this is born.
    SPP
    Rigid.
    Quote Originally Posted by Jakerz View Post
    This made me laugh. Costs get passed, savings are called profit and everything is on the margin. Anti-union Americans, makes no sense. Most Chinese manufacturing is not to US standard and the manufacturing world knows it; however, it isn't because they aren't capable of extremely high standards. LED technology for example has been mostly advanced by the Chinese and is the most advanced there. Americans make crap to but it's due to lowered standards to compete with the margins of most Chinese manufacturing. Lest no one take into consideration that most products were designed to be in the trash within a 5 years of production, or less. That has nothing to do with it.
    Quote Originally Posted by GTR-33 View Post
    This isn't necessarily true, it depends on the market, whether or not other manufacturers experience cost/savings changes and things such as how people respond to price changes. When costs go up, manufacturers may pass it on or eat it or, most likely do some of both, same goes for savings.
    If the kona people get back to the bike shop soon with an answer I'll probably upgrade to a kula. I'm also going to buy my next 26 from them, if they keep making them. I apologize this thread got weird. I should not have ranted initially, but I really just wanted to know how small of clearances were acceptable on a 29er, like if they were different than other bikes. But after posting I realized it could not have been mechanically correct. It looks like the frame got damage in transit or something. I know my 04' aluminum kona is still the best fitting frame I have (for me) and I'll be fixing that up too. I went 5 years riding single track black trails up sizable forrested hills with only falling off the bike hard ONCE. When I got my specialized I went over the handlebars three times my first trip out, I was sooo embarrassed and with the people I was with I wanted to explain that the bike must not fit me, but wtevr. Looking forward to a new bike that I paid for over two weeks ago, hopefully gets taken care of soon.
  1. Looking for a side-entry bottle cage
    By wschruba in forum General Discussion
    Last Post: 01-05-2014, 08:16 AM
  2. Lightest side load cage
    By dan4jeepin in forum Weight Weenies
    Last Post: 04-25-2013, 12:45 PM
  3. Play of rear wheel (rocks side to side)
    By darnelli in forum Wheels and Tires
    Last Post: 04-19-2012, 09:49 AM
  4. Easton Havoc AM - play in rear hub. Expert advice needed.
    By y0bailey in forum Wheels and Tires
    Last Post: 07-25-2011, 08:08 PM
  5. Short cage vs long cage-rear mech
    By Qcamel in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 03-23-2011, 02:55 PM
