Page 2 of 2 FirstFirst 12
Results 51 to 76 of 76
  1. #51
    Administrator Administrator
    Reputation: rockcrusher's Avatar
    Aug 2003
    Quote Originally Posted by bluestatevirgin View Post
    Rockcrusher, you still rocking the fat tire on the front of your Jones, or have you gone to a regular 29 inch front? Or do you switch a bunch and have preference? Lastly, you ever hear of anyone running a wide 26 inch rim on the back of a jones with a big old dh tire?
    I have mostly used the 29er setup I have, just haven't dabbled too much with the fat front because I never settled on a tubeless setup and here in AZ I prefer to be tubeless vs. adding more weight with sealant in a tube. Plan on messing around with the tubeless this winter as I get into my riding season again. That said the bike is just insanely good in the 29er config it is hard to convince myself that I need to add something to it.
    Not sure how much you could cram in the back...My purgatories on Flows are pretty good with clearance but I wouldn't go that much fuller back there without worrying about rubbing the CS. Sounds like Jones need to get to work on a full fat with a 83mm BB area in a hurry or you need to steal Carpenter's bike.
    Try this: HTFU
  2. #52
    Quote Originally Posted by rockcrusher View Post
    Thanks. I have the Purg on Flows out back too. I wonder if a 73mm bb would make any difference? I guess it's not much of a gain on the 68. I'll have to go look and see what the Krampus is using in the bb area. Yes, I want Carpenter's bike. Or Drevil's. I'm not picky.
  3. #53
    Fat front Jones really is the way to go. I originally bought my Jones Diamond frame and Unicrown fork from Jeff with a 29er wheelset. He advised me to try it out with the 29er wheels to make sure the geo was a good fit for me, but also said that once I tried the fat front I wouldn't want to put the 29er front wheel back on. He was mostly right.
    My front wheel is a Paul WHUB laced to a Surly Large Marge Lite rim with a Husker Du tire. It is a really awesome setup - pretty light, wide enough, great grip, etc. I run the fat wheel 90% of the time. the only times that I run the 29er front are either for bikepacking or on a select few trails that are really buffed smooth. Otherwise, if the trail has roots and rocks, I'm going fat.
    I know, I know...pics or it didn't happen, so here it is...
    Enjoy the ride!
  4. #54
    26in knard
    There seems to be some hinting that a 26x3.0 Knard is on the way.
    where did you hear this?......any more news? sounds like this might be the total package to go in the front of my 1x1
  5. #55
    Quote Originally Posted by jayoutside View Post
    Just some rumoring and hinting in the fat bike forums. Nothing to get too excited about. Just hunch.
  6. #56
    Neg reppers r my biatches
    Reputation: FoShizzle's Avatar
    Quote Originally Posted by Enel View Post
    Wait til you try it without the boat anchor wheel and tire!
    Enel, dont bother...moderators have super small penises- its a prerequisite , dont expect logic either
  7. #57
    Aug 2003
    Quote Originally Posted by FoShizzle View Post
    Thankfully me and my small rooster are quite content with the 29er wheel. When i get around to it, I might convert a fat fronter to tubeless to cut some weight and increase its usefulness and just play around with it. I mean Fo plays with his all the time, if he didn't it wouldn't get any use and then it would just be deflated and sad. Can't let it go to waste when you still have it.
    Try this: HTFU
  8. #58
    agu
    agu is offline
    Reputation: agu's Avatar
    Sold two of my bikes to fund a Jones diamond unicrown build...will definitely post progress on this thread or in the Tai Jones one.
    Hurry up January!!!
  9. #59
    Thanks for posting up this review. I'm going to order the diamond/uni setup now and if the geo is good, I'll be going for the space frame next year. I was going back and forth between fat and 29er, but I think I'll go with a 29er (Velocity Blunt 35) for now. I've had a fat front in the past, and while fun, it wasn't quite what I was looking for.
  10. #60
    Don't be a sheep
    Sep 2004
    You're a dIck. Hehehehe. Do you miss me?
    "Do not touch the trim"
  11. #61
    agu
    agu is offline
    more teasing courtesy of Mr Jones:
    Singlespeed Bike | Jones Bikes
  12. #62
    SyT
    SyT is offline
    I guess I don't understand the teasing element. One could speculate he is entertaining the idea of accomodating the Knard in the next version. Is that what you're referring to?
  13. #63
    agu
    agu is offline
    Quote Originally Posted by SyT View Post
    Jones has said a Knard+rabbit hole fits the truss and unicrown forks, and a non-Knard and Rabbit Hole will fit in the rear.
    there has been speculation as to when the release date of the said Knard and Rabbit Holes will be. Obviously Jones has a bunch and in fact he has said that he will be building up some wheel sets.
    I myself am waiting for my Jones frame and possible Rabbit Hole front wheel combo, hence the teasing.
  14. #64
    Jeff has been running a 50mm rim on the back of his bikes for some time...he had a prototype built before the Rabbit Hole came out. But the Ardent is as big a tire as can fit. No Knard out back.
  15. #65
    SyT
    SyT is offline
    I will be all over the Diamond frame if it becomes Knard-able
  16. #66
    bro, if you are happy with that bike that is all that matters, as for me I would throw up in my mouth every time I looked at that thing. I am big on design aesthetics and Jones appears to have none.
  17. #67
    Quote Originally Posted by shreddr View Post
    All subjective, I guess. I think it's a beautiful frame. At worst, at least a breath of fresh air from the mundane double triangle.
  18. #68
    agu
    agu is offline
    Indeed it is all subjective. It's more fun to ride your bike than stare at it. (Though we are all guilty of the latter!)
  19. #69
    Quote Originally Posted by phsycle View Post
    I'm cool with the fram, it's that wheelbarrow of a front end I can't stomach. If I was gonna go fat I would do a mukluk
  20. #70
    I have diamond with truss; I don't like the look of the truss, but it rides so much better than any other rigid fork I have used.
  21. #71
    Aug 2010
    Sorry to bring this thread back. It's been three years, is the Jones still your one bike?
  22. #72
    Reputation: fixgeardan's Avatar
    Mine is! My one and only mtb. On it about 4 years now I think
  23. #73
    Aug 2003
    Heck yes. I just moved to Washington and am waiting to try it out on the trails out here! I have used it for commuting this winter here with some 700x35 tires mounted to my stan flows and, aside from being too low geared for the down parts of seattle hills, it is a great bike for that too. I have logged some great miles on it, love it with the fat front, love the jones loop bars and really really look forward to getting it out on the trails out in Washington.
    Try this: HTFU
  24. #74
    My only bike for 3 years. If I could change one thing: Have it ride the exact same with about 1 inch higher bottom bracket.
  25. #75
    Powered by ice cream.
    Reputation: Enel's Avatar
    I still own and ride my Jones/Truss SS. No need to change a bike in 3-4 years. That is a huge record for me.
  26. #76
    Enki loves you
    Reputation: gravedoja's Avatar
    Dec 2005
    Got my steel space frame in 2013, its a good road bike, mountain bike, touring bike, commuter bike, wall art, everything is better on my Jones.
