Results 1 to 34 of 34
    Reputation: chernichovsky's Avatar
    Mar 2011
    My Custom made I-9 ( Infinity 29ER)
    All Columbus tubes@ fillet brazed
    Trail XC endurance geometry.....
    Mated with a Rohlof hub to become a solid working horse!!
    Got about 1500 miles on it.
    A dream in all aspects....currently building two more for clients/fellow riders (one is XXL).
    More pics less words
    Attached Thumbnails Attached Thumbnails My Custom made I-9 ( Infinity 29ER)-chernichovsky-35.jpg
    www,chernibikes.com
    HAND CRAFTED RIDING MACHINES @ Face Book
    Chernichovsky Bicycle Labs
    Moderator Moderator
    Reputation: driver bob's Avatar
    Internal cable routing is sick.
    No Clue Crew
    Apr 2005
    I agree. Very clean. What's the third cable do?
    Question- Could the internal routing on the rear stay comprimise the strength? I have never seen three...just one.
    Moderator Moderator
    Quote Originally Posted by Blatant View Post
    Rohlof uses 2 cables, one to shift up, the other to shift down.
    Mar 2011
    Hey and thanks !
    Cables
    Two for the hub gear change. Its a "pull-pull" cable method - no spring like open der. Third is obviously the braking hydraulics pipe.
    www,chernibikes.com
    Mar 2011
    strength
    Quote Originally Posted by jomissa View Post
    Those tubes are very strong for their intended job - condensing inwards delivering and absorbing energy to the top tube.
    That said the holes are round so there are no stress points. More than that the holes are brazed around with those leaf looking internal cable routing cowlings 1.3mm thick steel.
    And most importantly - its the " alloy of the legends....."
    No worries
    www,chernibikes.com
    Cheesiest
    Reputation: intheways's Avatar
    Sickbike! Have you though of using a monkeybone to replace the leverage arm of the Rohloff?
    Reputation: Hudnut's Avatar
    Apr 2005
    The cable routing is the highlight of this frame, even more so than the rohlof drivetrain!. is there access to the seatstay through the seat tube with the post removed?
    Teen Wolf
    Reputation: cr45h's Avatar
    love it
    Out spokin'
    Dec 1999
    Quote Originally Posted by Hudnut View Post
    Notice the seatstays do not connect to the seat cluster symmetrically.
    I'm not personally a fan of internal cable routing but this bike looks nifty.
    --sParty
    disciplesofdirt.org
    29" french team
    Reputation: rom1red's Avatar
    Jan 2005
    Why doesn't you build your frame with OEM dropout ? That will be more discret than a long torque arm (until on a custom frame !) ...
    Reputation: edouble's Avatar
    sweet bike....
    I love the internal cable routing. Do tell about the geometry and ride quality.
    EAST COAST
    CLYDESDALE
    DREADLOCKED
    STEEL RIDER
    Mar 2011
    Hey
    Quote Originally Posted by intheways View Post
    I was a bit worried that the paragon drop outs are not designed to take so much torque.
    But i am thinking of taking the next go with a monkey combined with a EBB and a belt drive.
    Make the "infinity" even more infinitive .
    www,chernibikes.com
    Mar 2011
    No access ...no real need....
    And I would not dare take material out of the seat tube at that specific point.
    Not worth the integrity of the frame loose at that area, Just to have access.
    The cables housings just slide down from TT to SS.
    I am an Industrial designer but had to consult with a talnted friend - a goldsmith jewelery maker regarding the precise distances between the cable opening and have those in precise composition regarding the fillet brazing tube proportions.
    He had his say and that was that
    www,chernibikes.com
    Mar 2011
    They are Classic sliding paragon C&C drop outs.
    www,chernibikes.com
    Reputation: Just J's Avatar
    Feb 2005
    That is an amazing looking bike, well done on doing it a bit differently! I'm off over to Facebook to find out more...
    looks like a great bike, the internal cable routing is just......beautiful. Do give us some geometry numbers and also curious about the weight with the rohlof hub
    Reputation: menzib's Avatar
    Sick bike. Makes you fall in love again. Job well done.
    Mar 2011
    Good job! spec
    Quote Originally Posted by Ilan123 View Post
    bike is 12,7 kgs if i remember the exact number
    Building custom bikes methodology at my shop starts with wheel base
    in proportions with height torso and inseam
    Its a 1905 mm wheel base a 71 deg on head angle and 436 mm chain stays - rails on tech descends fo my height . With no derailleur and chain rattling all over the frame, feed back is just awesome. Riding position is a bit high for dedicated performance bike.
    Some riders would prefer a lower BB (in about 23 mm) , personally i like sitting high on those open fields.
    Thanks for all the replays and feedback!!
    www,chernibikes.com
    1*14*29*2.1 & 1*1*29*2.4
    so...was not using the OEM dropout something to do with the routing?
    May 2005
    Please post some pictures of the XXL you are building......thanks !
    Now broadcasting from CO
    Reputation: PAmtbiker's Avatar
    Feb 2005
    Awesome. I really dig the internal routing for everything.
    Brought to you by rocks.
    Plays with tools
    Reputation: customfab's Avatar
    Quote Originally Posted by rom1red View Post
    Beat me to it. The torque arm is am eyesore of epic proportions. Paragon makes a left side dropout insert for the sliders in that frame that gets ride of it. And like you said there is always the dog bone.
    Mar 2011
    Will do
    Quote Originally Posted by Surfdog93 View Post
    A Shimano Alphine hub might be in use on this frame , so not sure the internal cable routing should be the same due the cabels having to run on both
    sides of the frame with the alfine. So another design would probably be implemented.
    It will be fillet brazed for sure though.
    Thanks.
    E.
    www,chernibikes.com
    Mar 2011
    I agree with this design wise
    Quote Originally Posted by customfab View Post
    Phisicswise, as mentioned by others,
    It makes sence to remove the torque forces
    away from the axle an dropout.
    I have to hand it to Rohlof for doing an amazig job, torque arm or not
    This thing puts the whole bicycle gearing industry in a
    prespective. Very important company for all of us.
    www,chernibikes.com
    I had not heard of this Rohlof hub and thought "man, why arent there more of these things out there."
    Then I did some quick searching and found out they are something like $1700 bucks.
    While that replaces a hub, cassette, shifter, derailleur, front shifter and derailleur, I am not sure it's $1700 cool. .
    Mar 2011
    Ho
    Quote Originally Posted by warimono View Post
    You can get them on ebay for ~$1000 or so.
    But do consider the fact that about 70 % of the open gearing dies
    Within a year....every year.....its a very costly method.
    Their fragility is stricktly the coperatives intrest, to make
    us consum and consum. ....
    The Rohlof lasts forever.
    www,chernibikes.com
    lpt1
    Reputation: lpt1's Avatar
    Asymmetrical seat stays near seattube?!
    (Left stay goes to the top tube, but right stay ends at the seat tube, see pic2)
    Mar 2011
    Totaly:-)
    Quote Originally Posted by lpt1 View Post
    Totaly
    One takes cables down to gears an disc brake!
    Internaly
    www,chernibikes.com
    mnoutain bkie rdier
    Reputation: rydbyk's Avatar
    Beautiful frame. How do you keep the water out of internal routing holes to prevent rust? Is it treated?
    GoCyco
    Very cool
    And with all the thought into running all these internal cables, I would have expected the front brake cable to be inside the fork to prevent damage and not "hanging out" as it is...
    Mar 2011
    Woww
    Quote Originally Posted by aizu1 View Post
    Not a bad idea actualy :-)
    Internal disc hydraulics on front sus forks:-)!!!!!
    www,chernibikes.com
    Mar 2011
    Zink
    Quote Originally Posted by rydbyk View Post
    Hey thanks
    Oil based treatments left to dry befor assembly
    And anual treatments as well driping in with a 15g
    Needle.
    A touch or rtv at openings on the top tube.
    Totaly none issue
    You can get away with wd40 every six months
    forever on bare steel tubes on on non exposed parts especialy with good ventelated
    frame openings.
    Frames left with just welding gas holes should be looked
    with more attention to my opinion.
    www,chernibikes.com
  1. Non-custom made steel frames made in the US?
    By bwheelin in forum Bike and Frame discussion
    Last Post: 04-03-2011, 01:11 PM
  2. Pics of my custom 29er made in Springfield OR
    By dougbot in forum 29er Bikes
    Last Post: 03-06-2010, 12:12 PM
  3. custom made for lefty
    By alhoff in forum Cannondale
    Last Post: 05-11-2008, 03:32 PM
  4. Infinity Hubs
    By Jason Boi in forum Wheels and Tires
    Last Post: 01-15-2008, 11:22 PM
  5. Made some custom stickers....
    By oly in forum Turner
    Last Post: 05-03-2007, 11:56 AM
