Results 1 to 9 of 9
    Mar 2013
    Motobecane Fantom 29 X7 / What size ?
    I'm looking into getting this bike and I was wondering what the biggest drawbacks are. From what I've seen around this forum and few other places it appears that the bike is very solid. Also I'm not sure which frame size to get. I was thinking of getting 17". I'm 5'9", 30" inseam.
    One more thing. I was thinking of getting Airborne Guardian but there are supposedly clearance issues between the rear tire and the der? Is that true? Is the Motobecane experiencing similar clearance issue?
    Mar 2013
    Anyone, any suggestions please?
    Reputation: J.B. Weld's Avatar
    Do you have a bike now? I always compare top dimensions of a bike I may be interested to one that I already own that I know fits me well. If not then 17 sounds right for your size but there are a lot of variables, I would only buy a bike sight unseen if it matched up (size wise) to one you are able to test ride.
    Mar 2013
    I currently ride an old Raleigh, which is 20", but that's 26" tires on it. This is why I was thinking of going with a 17" for the 29er.
    Tire size doesn't really effect frame size, I rode the same size 26 inch mtb as my current 29 inch one. 20 inch frame sounds way too big for you, 21 inch is usually considered XL and is the size I ride @ 6 ft. 3 in.
    Mar 2013
    I agree that the tire won't impact the frame size, but it will impact at how high off the ground the top tube is.
    AZ
    AZ is offline
    Reputation: AZ's Avatar
    Stand over is irrelevant. Buy with reach to the bars in mind. If your current bike is a good fit try to approximate the dimensions that work for you.
    Quote Originally Posted by luke79 View Post
    No, bb height (or drop) determines stand over height.
    Old mtbs, especially old lower end mountain bikes (don't know what you have) often had seat tubes that were longer in proportion to top tubes than modern mtbs. It is possible that the top tube on your current 20 in. bike is shorter than the new Moto-bacon. Measure and check!
    Oct 2013
    I am also interested in that same size I am 5'9.5" with 31" inseam barefoot book measurement. I don't have a older bike to compare. Was hoping if Luke79 could shime me In.
  1. Motobecane fantom DS Pro
    By dworley505 in forum Beginner's Corner
    Last Post: 04-01-2012, 10:24 AM
  2. Motobecane 700DS vs Motobecane Fantom Trail
    By kalroot in forum Bike and Frame discussion
    Last Post: 12-06-2011, 10:39 AM
  3. Replies: 7
    Last Post: 06-11-2011, 02:14 PM
  4. 13" Motobecane Fantom Pro SL
    By bncrshr77 in forum 29er Bikes
    Last Post: 03-24-2011, 09:09 AM
  5. Sette Ace or Motobecane Fantom
    By jhud51 in forum Bike and Frame discussion
    Last Post: 03-16-2011, 07:42 AM
