Results 1 to 87 of 87
    Jul 2013
    Most Fun and Flickable 29er?
    What are your opinions in regards to the most fun and flickable 29er.
    Examples? Pics?
    Reputation: Jstews's Avatar
    Oct 2011
    Hardtail or FS?
    I've been having a good time flicking my Nimble 9 around..
    Workin for the weekend!
    Reputation: -Todd-'s Avatar
    Honzo!
    Banshee paradox
    Jul 2013
    Quote Originally Posted by Jstews View Post
    Hardtail or FS?
    I was thinking more Hardtail, but open to opinions on FS as well.
    Also, I have a question. How much of an effect does the chainstay length actually have on the overall "flickability" or "26ER feel" if you will?
    What about the weight of the bike. I saw a video of a guy that seemed to be throwing around a Charge Cooker 29ER quite easily and that bike is ~30.00lbs.
    Feb 2013
    Mine weighs in around 30 and have no problem throwing it around. Dropper post and flick away.
    Elitest thrill junkie
    Reputation: Jayem's Avatar
    Quote Originally Posted by For Waukee View Post
    A lot I think. My Karate Monkey had 16.9" stays and was plenty fun and flickable, in fact I think they had that one nailed right at the beginning. There are a lot of fun flickable FS bikes as well, but realize if they start to get slack they are not going to be super flickable, they'll be more relaxed and steer slower, etc. Just like a 26er all mountain or DH bike compared to a 26er XC bike, an all mountain 29er is going to be more sluggish than a 29er XC bike. What you want is for it to remain maneuverable enough that it excels at the things you want it to excel at. To that extent, for an all-mountain bike, I waited to get a 29er FS bike until they could make something with the chainstay length I thought would be acceptable. I'm loving the bike right now, but again, it's more sluggish than a 29er XC bike, so realize that there is always give and take.
    The Karate Monkey was really fun with a rigid fork, because the steering was so precise and you could "push it" into turns much harder. It's hard to describe, but the flex with ANY suspension fork gives you a lot less steering precision and control, although it gives you more control in other ways obviously. Going around switchbacks you could really whip it around due to the low front end and rigid fork. I'd still take suspension over the rigid fork for fatigue and obstacles, but it's fun to ride the rigid every once and a while for it's benefits.
    I really like that new Kona Process 111, cool idea with shorter travel but still slack with shortish stays. That would be fun for a lot of places that don't call for a ton of travel, but again, not as nimble as an XC bike of course.
    Weight is not a huge issue to me unless it's significantly more than 32lbs or so. Everyone is different here, but I've been training and getting stronger for the last few years, which has helped dramatically. If you are used to single speeding or can ride like a single speeder, you can often outclimb anyone that's not at that level of fitness. I'm riding a heavy snowbike at times and busting out the climbs just fine with a standing-technique. It's like riding a single speed and you always have to remember SS guys climb your hills just fine with only one gear, so you can darn sure do it on an easier gear than them without having to go into the "easiest" combo. This just means that it's not the weight of the bike so much, it's your conditioning and strength.
    Jul 2013
    Forgive me for not being in tune with the terms, but what exactly does 'slack' mean? Also, thanks for the detailed response.
    Reputation: Mr. 68 Hundred's Avatar
    Very happy with how my Banshee Paradox flicks *IF* you can get the seat low enough to get it out of the way. If I slam the seat without a dropper post, it's perfect. With the dropper post slammed (Kindshock Supernatural 125 mm), the seat is still just a bit too high. IMHO, seat tube should be 2" shorter on the Paradox if you want to run a dropper.
    Steve
    Proponent for an Evidence Driven Life.
    Occupation: Disposable gene transfer machine
    Current HTFU status: 4/10; increasing
    Mar 2011
    Usually this refers to the geometry of the bike, most notably the head angle although seat tube angles vary a fair bit too. The head tube angle is what most people focus on though. For 29 ers I'd say anything under about 69 degrees is fairly slack.
    As far as the original question goes my vote, like a lot of the others, would be for an all mountain hardtail like a Honzo in terms of being flickable.
    Needed Less ~ Did More
    Reputation: Singlespeedpunk's Avatar
    OS Bikes Blackbuck Gen1 with the 435mm forks. Crazy responsive handling, even with the longer / less rake Salsa Cromoto Grande forks it is more responsive than most small wheeled bikes
    Mark Slate nails it again....I would expect nothing less from the designer of the WTB Phoenix!
    "Put any one on one of these singlespeed bikes and they could not help but have fun"
    Otis Guy talking about klunkers c1976
    I know the list so far has leaned towards HT, but the Transition Covert is a super flickable FS. I never thought I'd own a 29er that is so playful.
    Uh-huh, uh-huh. Okay. Um Can you repeat the part of the stuff where you said all about uuhhh, things. Uhh... the things.
    Jan 2013
    I will probably get blasted for my opinion on this, but i think the short chain stay "flickable" buzz is kinda silly.
    I surf on a 10' longboard. It has huge advantages over short boards when it comes to catching waves, but being a longboard it is *supposed* to surf like an aircraft carrier. Thing is, when i position my self correctly and carve hard i can cut back no problem. I kick spray and lip bash like a shortboarder as long as my technique and set up are correct. I get all the wave hog advantages and really have not felt limited in maneuverability since i got the feel for it.
    When i got my 29 it felt the same way. Some of the very advantages i love about my bike involve the longer wheel base and stability of the thing. A longer chain stay and LESS flickability actually helps on steep climbs and fast descents. The faster i go the better the bike handles. When i find my self on trail sections that your flickable bikes excel at, it comes down to proper technique, set up, and weight distribution. I have not felt limited in maneuverability since i got the feel for it.
    Not hating on anyone for personal preference, outside of races the best rider is the one having the most fun after all... but i think to much weight is being placed on how well a bike performs at under 10mph. There are people who will seek out bikes with this style of geometry because of threads like this without understanding why and what they are giving up.
    Competent User
    Reputation: Mr.Quint's Avatar
    Mar 2012
    The most fun I've had on a 29er was a Tallboy LTc demo with enve wheels. Popped off everything! It's a big bike, with relatively long chainstays, but it didn't matter. That thing was great fun. I was completely sold.
    If I could afford it obviously.
    Jul 2013
    Quote Originally Posted by BigRingGrinder View Post
    With you 100% on this. I mean, I'm not the best rider and don't have the most experience riding different bikes, but your explanation just makes total sense to me. Just based on research, I feel that what you lose in stability and climbing strength with shorter 'stays and wheelbase is harder to make up with proper technique then that of longer 'stays and wheelbase.
    With long 'stays, sure you're sacrificing a bit of maneuverability, but proper technique and conditioning can make that up in the long run.
    What about headtube angle? how much does it have to do with the steering and control of the bike? Would anyone say that it is more/less important than chainstay length and wheelbase?
    MTB B'dos
    Reputation: LyNx's Avatar
    I dunno, I think my Banshee Prime is very fun, but if I flick it I find it hurts my finger, maybe the alu is too hard to make it a nice flickable bike
    Reputation: seat_boy's Avatar
    You ask a good question. Many fellas these days really like their short stayed/slack front bikes (eg, Paradox, Nimble 9, Honzo, etc), but after briefly owning a Nimble 9, I really didn't care for it. Yes, the short stays made it very easy to loft the front wheel, but I didn't get along with the slack front end when the front wheel was on the ground, which was most of the time. It just handled in a very dull manner. So for me, the head angle has more importance than the rear chainstays (and of course, these are both part of the overall package, rider position, etc etc)
    I think two good candidates have already been mentioned:
    - Karate Monkey: still relatively short stays, but a steeper head angle. I've had one of these in the past, and will probably get one again in the future
    - OS Blackbuck: the short fork makes this very, very responsive.
    I currently have a Blackbuck. One idea I have kicking around is to combine the Blackbuck fork with the KM frame...
    Jul 2013
    Sorry If this is getting a little off topic, but would you guys consider a XC 29er (of course!) with 17.72 chainstays, 43.34 wheelbase, 24.61 TT, and 72 degree HT to be more on the short and "twitchy" side or long and stable side?
    By reading all of these detailed and intelligent responses I can tell you guys on here really know your stuff and just want to get your opinions.
    Those look like pretty typical numbers for a size Large XC bike. In my experience, that's more stable than twitchy. But, my trails are largely flattish and twisty, not fast downhills with lots of chunk. For people who ride that kind of thing, they will probably cry, "too steep!"
    One more thing: when you're looking at head angle, you also need to think about the fork rake. These two numbers combine to give you trail, which has a big influence on how the bike steers. Most 29er forks have standardized around a narrow range of rakes (45mm, give or take), but there are a few outliers (Trek/Gary Fisher G2 and the Blackbuck mentioned above, both have more rake = less trail= quicker handling for a given head angle)
    I made some trail comparisons at the bottom of this bike review.
    Oct 2011
    There's some good thoughts (and some effort at actual experimentation) on chain stay length here: All-Mountain or ?Just-Mountain? and other related numbers. 44 Bikes
    Chainstay length certainly plays a role in a bikes handling, as does headtube angle, and a number of other synergistic factors, that's why we're discussing them. One thing I think is sometimes overlooked is what sort of terrain you ride (as Seat_boy mentioned) and what you want you bike to do on that terrain.
    @seat_boy, got the N9 built up, by the way. Loving it sofar! Thanks again.
    Jul 2013
    I just switched from a Niner Rip to a Yeti SB95C and I feel like I am on a 26" bike as far as being flickable and getting air. The Niner did not air out like this Yeti! Hands down the most predictable and best pedaling 5" travel bike around.
    Nimble9 or the Yelli screamy
    Reputation: metrotuned's Avatar
    Most fun and flickable? Any frame sized down one.
    Producer, Actor Will of the Sun, Author Platform Pedal Shootout 900K+ views
    YRG
    YRG is offline
    Feb 2012
    Longboards don't surf like short boards. They can do some of the same moves, but are slower. You only get used to doing things in slow motion. Your analogy supports flickable (at least for people who have ridden short and long boards)
    Also not sure why you think flickable is only done at slow speeds?
    Trophy Husband
    Reputation: geolover's Avatar
    Quote Originally Posted by illnacord View Post
    +1
    At 6'2, I generally ride medium sized frames with slack head angles. Medium to keep the wheelbase in check and a slack head angle to keep it stable. YMMV.
    Extreme stationary biker.
    FM
    FM is offline
    Reputation: FM's Avatar
    Apr 2003
    Quote Originally Posted by geolover View Post
    +1
    I sized down to a small on my Kona Honzo... and it has super short 16.3" chainstays...
    I am actually finding it to be too far on the "flickable" end of the spectrum.
    Yes it manuals and wheelies super easy, easier than most 26" bikes I've owned. And it makes quick work of switchbacks and schralping corners. However at higher speeds on rocky terrain, it gets knocked off line easier, rides rough, and generally feels skittish.
    I do love the Honzo, just not for high speed rocky stuff!
    I never had these issues with my yelli screamy, which had similar reach/TT length, but .4" longer chainstays. The Honzo has sliders so I think the fix is just to move the drop-outs back a bit. And CERTAINLY not an issue on my banshee prime.
    So far my experience is that short stays and wheelbase add some playfulness back into the mix, but there can also be too much of a good thing.
    Jul 2013
    So sick of this "flick able" term. Who started this nonsense anyway? I get what it means but it just sounds like marketing jargon. Each bike will handle slightly different. Test some out and determine which you like.
    MTB B'dos
    I'll second this. Also don't see why people want 29ers to handle like 26ers, it's like having a Porsche and a Jeep and expecting.
    Quote Originally Posted by Brodon View Post
    Reputation: Colin+M's Avatar
    Quote Originally Posted by FM View Post
    Exactly, otherwise we'd all be on Unicycles.
    Trophy Husband
    I never had these issues with my yelli screamy...
    This is because the Yelli Screamy is rad.
    PS - I rode the full suspension version of the Honzo a few weeks ago. Initial review: I would like to ride it again.
    Dianetics Junior
    Reputation: CBizzie's Avatar
    Mar 2011
    tell me more...do you mean the Satori?
    Trophy Husband
    Re: Most Fun and Flickable 29er?
    Not the Satori...the Process 111. (thread jack complete)
    http://www.konaworld.com/process_111.cfm
    Sent from my Galaxy Nexus using Tapatalk 2
    Reputation: OldZaskar's Avatar
    Oct 2007
    I know what you're going through (I think). I rode 26" GT hard tails since 1995. I was soooo concerned about making the switch to 29" and FS. I didn't want to lose that feeling of being on my BMX bike (circa 1983)... I guess that's the "flickable" thing. I ended up on an XL Cannondale Scalpel 29er Carbon 1. I was blown away at the ride - WAY more fun than I expected it to be. Oh, I knew it'd be faster on the descents, more planted on roots, etc. I was surprised at how much better it climbed. But I was really blown away at just how fun it is to ride. It is absolutely as much tossable, flickable - whatever cool mtb term ya wanna use - as any of my 26" bike. I've never had had more fun riding.
    Edit note: I was also surprised at how easy the transition was. After 25+ years on hard tails, I raced the day after picking up the Scalpel... and podiumed
    Mountain bikers who don't road ride are usually slow.
    Roadies who don't mountain bike are usually d***s.
    YRG
    YRG is offline
    Feb 2012
    KONA BIKES | 2014 BIKES | ENDURO | PROCESS 111
    Just built a devinci atlas with a 140 fork. Very similar geo to 111. Bike is looking like it is exactly how I'd hope it to be (couple rides). Tremendously playful. Can't tell what the wheel size is until leaning into a corner and then feeling massive traction. Reminds me of one of the most playful bikes I've ever ridden, commencal meta 6 sized down. Can't really power through (pedal) heavy chunk, but I did not really expect that. Definitely looking as fun as the Yeli Screamy, but with added benefit of 4" travel.
    Reputation: SeaBass_'s Avatar
    I would have to differ in relating the two. I snowboard on a what could be described as a long board (a 169) because I like the stability at speed but when I get in the bumps and have to carve I'm at a disadvantage when I have to quickly swing that big ***** around in a tight space. It's doable though and I have demoed shorter boards and while they were better in the bumps, they were too fidgety at speed.
    My Nimble 9 SS has 16.2 stays and a G2 fork. It is extremely flickable on tight switchbacks and narrow singletrack compared to my former frames (Dambala and SIR9). It's also the most confident descender I have owned due to it's slack head tube and Canfield's DH geometry. When I stand and mash on steep climbs the rear wheel is right under me which means my weight is right over the rear wheel, leading to better traction when the trail surface is sketchy. Riding it is definitely the most fun I've had on a MTB on any terrain.
    To each their own though. Ride what you like and what works for you.
    Only if I was towing a trailer. Sounds like an endo machine to me.
    Reputation: Fuglio's Avatar
    Agree. Id rather muscle a long bike through the jumps and turns then trust my life on a short bike through high speed chunk.. The process 111 looks good though lean down to take advantage of the long top tube in the high speed. sit up a little straight to tale advatage of the short stays in the low speed...
    need to see first hand though
    Quote Originally Posted by Woodson View Post
    Bandoleroooooooooooos!
    I own a Kona Process and yes it is very flickable and still very stable at high speeds. I describe it as a 29er 4x bike
    Quote Originally Posted by YRG View Post
    Yes but your talking about an Ultra-light XC race bike " the scalpel ".
    I have that exact bike and can relate, spot on Geo.
    I just purchased a Yeti SB95 to replace my Intense Tracer 29. I never did feel quite comfortable / confident in tight rocky steep sections with the longer w.b. and or geometry of the Intense. I am really digging the SB now after only one 12+ - mile ride last week. It does feel closer to handling like a 26er and it's overall just more responsive. Also the large Yeti is around 1/2 an inch smaller in all areas than the Intense. When the rain lets up I will get some quality seat time to really get to know the SB.
    May 2005
    I believe experience and "active" technique have a lot to do with "flick ability"
    Ride 'Til Your Knees Hurt
    Reputation: cycljunkie's Avatar
    Canfield Brothers Nimble 9 is very "flick-able" IMHO. Made me a believer in terms of the whole short CS concept.
    Dec 2013
    If you put a shorter stem and shorter bars on any bike, in my opinion that makes it "flickable".
    Quote Originally Posted by matty.d. View Post
    Would have to disagree. 50mm stem on a frame with an 18" CS will not handle as good as say a 75-85mm stem on a frame with 16.25" CS.
    Sent from my Samsung Galaxy S3
    Mar 2005
    I know this quote is from last year but had to comment. No f'in way a longboard is even close to short board performance...this coming from a guy who has mostly ridden shortboards but also own high performance longboards and has been surfing for 35 years. The weight of a high performance longboard far exceeds any shortboard and that is just the beginning of the differences. If that is not enough to tell, you only ride waves and don't actually surf them.
    Dec 2013
    [QUOTE=cycljunkie;11288626]Would have to disagree. 50mm stem on a frame with an 18" CS will not handle as good as say a 75-85mm stem on a frame with 16.25" CS.
    Agree, but if you have a bike already and want to change the way it feels without getting a new bike stem and bars change it a lot.
    [QUOTE=matty.d.;11288652]
    Quote Originally Posted by cycljunkie View Post
    You are correct but I don't think changing your bar/stem setup will have as big of an impact as switching to a short CS frame. I've owned many 29er frames (too many) and my current frame (Nimble 9) has 16.25" CS's. This was my first "short CS" bike. I noticed the benefit of having short CS's right from the "get go". Made me a true believer! Just my $0.02 and your mileage may vary.
    Dec 2013
    [QUOTE=cycljunkie;11288673]
    Yeah your probly right I've never road a short CS bike although I've broken a CS ☺
    Reputation: Settertude's Avatar
    Jun 2013
    FS but---Salsa big mama. rides like a 26r methinks
    b
    I'm afraid of heights so a 26'r fits me to a T.
    DJO
    DJO is offline
    Apr 2014
    I'm new to MTBR but not to Mountain Biking. I think weight, frame material, suspension, chainstay and AtoA length all play into flixability. A light weight, carbon frame with stiff suspension, short chainstay and AtoA is much more flixable than a longer plusher, aluminum bike.
    Quote Originally Posted by DJO View Post
    By "AtoA" do you mean wheelbase? If so, I agree! My Nimble 9 has a short wheelbase and when approaching a steep tight downhill switchback I can grab a little rear brake and the whole back end just slides around into position for an easy entry into and out of the turn.
    Apr 2014
    Banshee Paradox is a frickin' ripper...built one for my dad and can barely help but pick one up for myself. Back end is stiff as hell, it's nice and short, and the angles aren't so slack that it flops around.
    2014 Banshee Spitfire 650b
    2011-ish Chromag Samurai
    DJO
    DJO is offline
    Apr 2014
    Yes the axle to axle length makes a difference. My Anthem X is smooth and fast but not quick, my Epic Comp Carbon is stiff and fast and very quick.
    Reputation: funnyjr's Avatar
    Flickable fun Ti
    Quote Originally Posted by funnyjr View Post
    Flickable fun Ti
    Jealous! Very nice!!!
    Flickable fun Ti
    Custom builder? Who?
    Reputation: jrsbike's Avatar
    Not a 29er, but today I tried a 27.5 Pivot Les and was astonished at its light handling and ease of whipping around. It was like a CX bike on steroids.
    Reputation: pascale27's Avatar
    Very pleased with my Misfit, not exactly a short chainstayer but just a blast on the trail......very nimble and still a confident descender.
    Salsa Timberjack 27+
    Niner Jet 9
    Misfit diSSent 1x11
    May 2012
    Waukee, sounds like a Niner Air 9 geometery.
    Seabass are you saying that the Air 9, is an endo machine? I hear that they were pretty solid bikes, and now you have me a little worried. Building up a frame right now.
    Quote Originally Posted by yourrealdad View Post
    I didn't know the Air 9 was that steep, but a 72 degree HTA is steeper than most stuff on the market these days. My 2008 Intense Spider 29er is also that steep. It's a blast to ride, and maneuverability around switchbacks exceeds a lot of 26er bikes.
    Different bikes require different riding styles, but you can adjust to something like that.
    A steep HTA moves the wheel in, but a longer top tube can compensate for that. I ride a short stem and lay back post on that bike to keep my weight back.
    Obviously I can't bomb rocky downhills like I can on my TBLTc but I do plenty of technical stuff with no problems.
    Ibis Tranny 29 just announced today!
    Quote Originally Posted by smilinsteve View Post
    +1
    what the hell is flickable anyways??
    I will spare the flickable debates here and support the fun part.
    It's more than just a short stem. The bikes I've ridden with short chain stays, low stand over and more slack are fun and probably what many call flickable.
    My fun 29r is a Honzo and that's got to be up there with value too. My real world experience is with a few Kona models that have gone short chain stay, slack and short stem but have to believe a Nimble 9, Banshee, and others all have that fun factor. Other 29r even with shorter stem or wide bars didn't have that fun feel I've got with my dirt jumper. The Honzo is like lumber truck or steam roller meets DJ/park bike. It works for way more than I ever expected and I'm riding it more than expected. Most other 29 bikes I've tried were just the lumber truck or steam roller part.
    Most probably have a hard time finding a Nimble 9, Yelli, or Paradox but the size of Kona dealer network probably gives you a chance to try that style geometry.
    Jan 2013
    Quote Originally Posted by Dr Sloth View Post
    Obviously short boards and long boards are different. If you re read what i wrote, i said i can cut back, kick spray, and lip bash "like a short boarder", not that my long board WAS a short board.
    Monday morning i had one of the best surfs i have had in my own 35 years of surfing (not exaggerating). I was uncontested at the outer peak and caught my pick of every set that rolled through. Im sure the guys out on short boards would agree with you that i was not "performing" like they could have.... that is if they were not just floating and watching.
    Quote Originally Posted by jrsbike View Post
    I saw that, pretty neat looking bike, but I'm pretty sure I read 71 deg head angle. The "fun" 29r bikes I found were or are 68.
    Sure fun for many is grunting out a race or fastest lap times on phone app, but my interpretation here is grunting to the top for air, steeps, drops and pumps fun on the way down. My fun or AM type 29 is still better for XC than I expected, and probably most limited by my choice for gearing.
    The OP asked for imagery. The Nimble 9 is not what I ride but I'm guessing anyone with one, Honzo, Paradox, Yelli, and others gets this.
    Did Someone Say Fun?
    I'm definitely not a XC racer or a DH guy. I just prefer to ride my bike up and down hills with a big smile on my face...
    For me the Nimble 9 is the most "fun" I've had on a bike...just my two cents. Of course my wife would disagree and tell you her Yelli Screamy is way more fun (because it's hers).
  67. #67
    Fun? who is gonna ride a bike that is not fun. Or rather one that they wouldn't describe as fun?
    Just when I thought bike descriptions couldn't get more vague than flickable.
    chainstay length is over analyzed . I feel some people look at numbers individually rather then as a set with all numbers having a cumulative effect.
    fun and flickability are decided by riding styles.
    all aspects of bike geometry are trade offs.
    Riding a 29er requires more body english than smaller bikes. Bikes with steep head angles could be considered more flickable for their ability to dart around rocks at high speed.
    A mod may want to rename this the
    " What's the best-est 29er?" thread.
  68. #68
    Jun 2013
    When I was a kid, I had fun on my 20" Schwinn.
  69. #69
    I didn't have a hard time interpreting what was meant or the majority of responses. It's not about a race or XC type bike here even though racing and those bikes can also be called fun.
    There's no over thinking chain stay length here unless I'm riding one of my bikes with 1+ inches more of it and trying to figure out how to do same sort of riding the DJ/park bike and "fun" 29r do.
    With 67 - 71 degrees in our MTB fleet I know pretty well "flicking" a racer bike around the rocks isn't same as slack bikes.
    The posts dismissing or questioning geometry (design?) are off the mark for me because with diversity in bike types, it's the bikes with 67-68 head angles, short stays, long top tubes and low stand over that facilitate a most fun sort of riding compared to all the stuff I've had since my 1981/82 StumpJumper.
    P.S. Definitely merritt points to family with his and her Canfields!
    P.S.S. What's that ti looking bike with bent seat tube or it's specs if a custom?
  70. #70
    Quote Originally Posted by bitflogger View Post
    I think people in this thread have mentioned the benefits and the downsides of short chainstays. So, fun can mean different things to different people.
    I have never "flicked" a bike, so maybe I am not qualified to discuss this , but steeper head angles have always meant sharper, quicker, more precise steering. Are we redefining the laws of physics now? Like so many things in the MTB world, the latest trend is sold as the solution to all problems while all alternatives are dismissed. As with chain stay length, changing HTA changes bike characteristics, but depending on the rider, the most fun HTA is up for debate.
    I know that I can do *much* better on tight switchbacks with XC geometry than with a slack bike, but I don't know what flickable is, so I'm not sure if that is relevant.
    I think fuglio was pointing out that you need to ride a bike to know it, not just look at numbers on a geometry table. I totally agree, and was surprised when I was test riding, how hard it was to predict in advance how a bike would feel. Bikes I thought would be big felt small, bikes I thought would be sluggish felt nimble, 2 bikes with the same numbers on paper would feel totally different from each other, etc.
  71. #71
    I think flickable means people want to flick it... like a carbon bike , people love flicking those
    the only frame that is more flickable might be bamboo. People cant keep their fingers off them.
  72. #72
    It's the axle
    Reputation: Gregg K's Avatar
    Just to cause more misery- I recall the term "flickable" showing up in motocross magazines back in the 80's, and it referred to how a cycle behaved after leaving the ground. Like going up the side of a hill, and getting airborne. At least that was my understanding.
    Note to self: 85% of FTP for 20 min.
  73. #73
    Quote Originally Posted by Gregg K View Post
    That's context and understanding I have. I'm just the old fart who started the bike park in my area but have heard it over and over in a circle of moto riders, dirt jumpers and the guys who get big air at our ski club trails.
    I get the flickable context or idea and 29r with my Honzo because it's a big wheel bike that can behave like my DJ bike. Friends and associates with racer type and fat bikes have been trying it on rides so getting on a racer or XC type bike and it in same ride are quite an illustration of what I think is meant in most of these posts.
    I have a racer type bike too and classify that as a different flavor or type of fun.
  74. #74
    Reputation: monty797's Avatar
    Don't know what you'd consider flickable, but this thing is stupid fun.
  75. #75
    Quote Originally Posted by monty797 View Post
    Rootdown? Nice. I haven't had the pleasure to try one but recall it has the build style like the N9, Yelli, and Honzo discussed here.
    ƃuoɹʍ llɐ ʇno əɯɐɔ ʇɐɥʇ
  76. #76
    Yup similar build style as the Yelli and Honzo. Super fun bike, loves to jump, loves to go fast and is really just a blast through everything. It's just one of those bikes that makes you forget what you're riding and just fun.
  77. #77
    http://www.cannondale.com/fsi/video/
    These bikes look flickable. I wonder how much of the "flickability" is the rider in this case; or if they had a longer chainstay bike if they could do this? (sarcasm) On that note my 20 year old son can make any bike look flickable. I think spending time on what ever you have and learning to ride is the key.
  78. #78
    Rootdown, thats Chromag right? Looks tasty. How much does that frame go for?
    Niner Jet 9
    Misfit diSSent 1x11
  79. #79
    Rootdown can be had for around $800 I believe. It's the Taiwan made more economical version of the Surface
  80. #80
    Clueless Bastard
    Reputation: WA-CO's Avatar
    Nov 2013
    Examples? Pics?
    Honestly this is impossible to answer. Here is why.
    First ya gotta define "flickable" This can mean different things to different people. In general an ex-motocross term, it eludes to the maneuverability of said bike. That may translate into HOW a rider rides, and this can vary greatly. If you're an ex BMXer or trials rider, your feeling for flickability is very different than being a downhiller.
    Secondly, there are several traits of a bike that can help define it's flickability, and others have mentioned them. Weight, Chain Stay Length, Wheel Size, some may say a particular frame material (steel) is more flickable than another material, like aluminum. My SS is much more "flickable" than my geared full sussy, part is overall weight, but part is where that weight is located.
    Third has got to be terrain. A smooth fast flowy trail will need different flick than a super chunky rock embedded fock fest. Different bikes, and riders will behave differently in these conditions.
    Fourth, it depends upon your experience and where you came from in your riding background. As I eluded to above, a BMX rider looks at that attribute differently than a Downhill rider.
    Lastly, and potentially most important, if flickability is important in your bike selection critieria, why would you want a 29er? If you want flick, a 20 inch BMX, will stick!
    So the question is back to the OP, what kind of rider are you? What are you looking for? What bikes have you ridden? What did you like and not like? What is your experience? What is your terrain? Why do you want flickable and do you know what that means on the context of all these other factors?
    It's kinda like the "best" bike argument on MTBR. Without some info our crowd sourcing model can't help and frankly with half of the bad advice you get here, you'll probably end up worst off.
  81. #81
    Yup frames go for $800ish. Fun little bikes for sure.
  82. #82
    Reputation: c-wal's Avatar
    What size is the rootdown? I wanted a surface for the longest time but seemed like I was between a lg/xl.
  83. #83
    Mine is a L and the fit is pretty much spot on. I am running a 50mm stem and the fit is awesome.
    I've gotten more time on it over the last couple of days and I'm blown away with how capable it is. I bought this to be my just mess around play bike, I have two other bikes in a Knolly Chilcotin and Banshee Prime and both of em are currently collecting dust for a little bit.
  84. #84
    Anyone whom has ever had an affair with a short chainstay 29er will realize how much fun, maneuverable it is and tough to give up and go to a bike with longer stays. And when I say short stay i mean under 17".
  85. #85
    DJO
    DJO is offline
    Apr 2014
    Anyone whom has ever had an affair with a short chainstay 29er will realize how much fun, maneuverable it is and tough to give up and go to longer a bike with longer stays. And when I say short stay i mean under 17".
    I agree with this post 100%.
  86. #86
    Yep, 29er wheels are already more stable due to gyroscopic motion, they don't need longer wheelbases than 26ers so they can be "more more" stable. We got 18"+ chainstay bikes because the designers were lazy (well, more because they didn't want to really commit and took a "lowest cost possible" approach). Lots of these bikes still exist and are being sold, but we are finally starting to see some shorter chainstay XC bikes even, although they still have a ways to go.
  87. #87
    Reputation: CRAZY FRED's Avatar
    Agreed......Most fun on any bike I've ever owned...
  1. Flickable Big Wheels!
    By jncarpenter in forum 29er Bikes
    Last Post: 06-03-2012, 03:21 PM
  2. Replies: 14
    Last Post: 11-13-2011, 07:35 PM
  3. Replies: 3
    Last Post: 10-20-2011, 05:33 PM
  4. Replies: 13
    Last Post: 05-25-2011, 04:31 PM
  5. You say 29ers aren't nimble or flickable?
    By LyNx in forum All Mountain
    Last Post: 04-23-2011, 08:12 PM
