Results 1 to 8 of 8
    Dickhouse
    Dec 2010
    Low-stack Height Headset - S.I.R.9
    I'm looking for the lowest stack height headset that works with a S.I.R.9. Does anyone have any knowledge on this? The FSA, Cane Creek, etc. all have so many options, it starts to get confusing very fast.
    Something with wheels and brakes.
    92Fifty' Race Team
    Reputation: Nater's Avatar
    Crank Brothers is going to be the lowest.
    Dickhouse
    Dec 2010
    Ritchey has the WCS Carbon press-fit that claims a 18mm stack height, and the Superlogic Zero which claims 12.1mm stack. Are either of these for integrated? Does not say on Ritchey's website.
    92Fifty' Race Team
    Pretty sure both of those are Zero-stack models and require a 44mm ID headtube. Your SIR9 has a standard 1.125" headtube and needs a headset with external cups. Of those, the Cranks Bros headsets are the lowest stack.
    Down South Yooper
    Reputation: Plum's Avatar
    Sep 2004
    You don't need an integrated HS, the SIR9 takes a normal pressed fit HS.
    I think Nater is right, the crank bros is going to be the shortest stack height, I think it saves 10-12mm over a king or CC.
    Plum
    This post is in 3B, three beers and it looks good eh!
    "Ride Lots" Eddy Merckx
    Reputation: kkjellquist's Avatar
    Quote Originally Posted by DavidR1 View Post
    Crank Bros is the lowest.
    ^^this^^
    "Big Gulps huh?...Allllriggghhht....Welp, See ya later!"
    Reputation: DavidR1's Avatar
    CyclingCentralVa.org
    May 2005
    But be careful - if you use a Crank Bros headset you might have issues with the adjuster knobs on top of your fork hitting the frame if the wheel is turned all the way.
  1. Need a low stack height headset
    By Seanbike in forum Urban/DJ/Park
    Last Post: 09-29-2007, 02:08 AM
  2. Headset Stack Height Help
    By Manicmtbr in forum 29er Bikes
    Last Post: 12-18-2006, 10:32 AM
  3. headset stack height?
    By Ventanardr in forum General Discussion
    Last Post: 05-17-2004, 09:33 AM
  4. Stack height of FSA Pig headset?
    By COmtbiker12 in forum Downhill - Freeride
    Last Post: 02-22-2004, 09:45 AM
