Page 1 of 2 12 LastLast
Results 1 to 100 of 146
    Long vs short chainstays
    Bought me a new frame, Silverback Mercury 29 and it has longer chainstays than my still to be replaced Axis. It is about 20 mm longer, to be honest I can not say that it has a real effect on cornering and climbing. A 29er shootout in a local mtb mag favoured shorter stays for climbing and cornering , but states that longer stays are more stable at speed. Your expierience in this regard please.
    Reputation: seat_boy's Avatar
    For me, the biggest difference I find is that longer chainstays make it harder to wheelie. I'm trying a 69er project to really feel the difference.
    Reputation: OmaHaq's Avatar
    Jun 2010
    I've argued this point for a long time... people seem to deal with 20-30mm trail difference just fine w/ sliding dropouts or horizontal dropouts. I think it is a solution for a non-issue in most cases.
    - The only thing that keeps me on a bike is happiness.
    Reputation: Nutball's Avatar
    Count me as the type that really prefers a short chainstay. That being said, a difference of 20 mm is not an absolute deal breaker if the rest of the geometry is decent for you.
    For example, my two current bikes are a Niner Jet 9 and a Canfield Yelli-Screamy. Prior to picking up the Niner last year, I rode a Titus Switchblade for ~8 years. The SB chainstay is roughly 16.7 inches while the Niner's is roughly 17.7 inches. On the street i didn't notice a difference at all (at least not due to the chainstay). I didn't notice a difference for the most part on the trail either with two exceptions. On steep climbs I found myself losing traction more than normal on the Niner and it was definitely more challenging to get the front end up over largish rocks or trees (~1 ft for example). It was not impossible to get the front end up, only marginally more difficult.
    I originally chalked up the tires breaking free during steepish climbs to differences in tires between the Niner and the SB.. However, I picked up a Yelli-Screamy (chainstay: ~16.7 in) a few months ago and can better compare the effects of chainstay. I only have one set of 29er wheels so I swap them back and forth between the Yelli and the Niner. The Yelli climbs noticeably better (for me) than the Niner unless the trail is rough where the rear suspension on the Jet 9 really helps. Standing climbing is impacted the most but seated climbing traction is still noticeably better (for me). Popping the front end up over obstacles is noticeably easier on the Yelli as compared to the Jet. Even so, I ride the Jet on the same trails as the Yelli and can clear the same obstacles, I just have to work a bit harder on the Jet in the tougher sections.
    For what its worth, I bought the Yelli specifically for its short chainstay and slack head tube angle as compared to the Jet; that thould put my post into some perspective. Even so, it was the Niner's head tube angle that bothered me more than its chainstay. The ~1 inch difference is chainstay is only really noticeable (to me) on technical sections or steep climbs. I don't really notice much of a difference on chainstay during cornering unless we are talking tight switchbacks where the shorter chainstay (and wheel base) is better. (Actually, the Niner corners a bit better (for me) in most circumstance due to the improved traction afforded by having rear suspension vs a hardtail).
    -Nutball
    Single Speed Junkie
    Reputation: crux's Avatar
    Honestly think it is a matter of personal preference. Personally I am of the opinion that the shorter the stays and the fatter the tire clearance the better.
    mnt bike laws of physics
    Reputation: yogiprophet's Avatar
    My Sultan (with 18.2" CS length) is the best seated climbing bike I have ever ridden....so you can add that to your list.
    1) More stable at speeds - true with most any vehicle.
    2) better seated climber - and by that I mean steep climbs where shorter CS bikes are barely holding their front end down...common sense really.
    Personally when I am buying a bike, i look at CS length and what I am looking for depends on the intended purpose. Although I do think that a shorter CS is better all around for most cornering except steep swithbacks, if I am wanting a short travel racing type bike, I think shorter CSs have an advantage of being a better out of the saddle climber. If I am looking at a LT bike that I will not be doing that, I'd rather it be on the long side.
    Height may have something to do with it. The taller you are, the higher your center of mass and then a longer wheelbase in general is better IMO at least. I just read where Norco I believe is making their chainstays size dependent. IOW, the larger the bike, the longer the CS, so it would seem that someone thinks it important enough to go through all that trouble.
    Reputation: Bald_Ben's Avatar
    May 2005
    Short stays do help with climbing and cornering. Slacking out the head angle a tiny bit (usually by running a fork that's 10-20mm longer than stock) helps with downhill stability.
    get down!
    Reputation: appleSSeed's Avatar
    I sort of agree with the size dependent thing.
    Rudy Projects look ridiculous
    visit my blog, BEATS, BIKES & LIFE
    EXORCIZE
    Reputation: Ryder1's Avatar
    stuff in my head
    Quote Originally Posted by yogiprophet View Post
    My thought: taller height also shifts the rider's weight backwards. If a bike designer wants to keep the taller rider's weight centered in the bike, larger sizes will necessarily have longer stays (and longer stems and maybe steeper head tube angles) than smaller sizes.
    Nevertheless...I'm 6'2 with a 36" bike inseam and I still like a fairly short chainstay (17-17.5). But I ride hardtails. If I did a lot of steep seated climbing, longer stays would be preferred. And the high-speed stability does rock.
    2017 Diamondback Haanjo
    2016 Pivot 429T
    2011 Kona Unit
    Reputation: zonoskar's Avatar
    Hmm, that's the exact opposite of what @Nutball experienced. Strange.
    Reputation: serious's Avatar
    Jan 2005
    I am short (5'6") and ride a medium 29er and the shorter the chain stay the less I have to move my weight back to avoid slippage when climbing out of the saddle. I can see that for taller riders this problem is less apparent.
    As for stability at speed, I cannot say it makes as much a difference as in climbing and cornering.
    My rides:
    Lynskey Ti Pro29 SL singlespeed
    KHS Team 29
    S-Works Roubaix SL3 Dura Ace
    KHS CX 550 cyclocross
    I was always under the impression that short CS's made for better handling.The same principle as bikes with lower BB's equate to better handling.
    This theory would make the hardtail shine of course as suspension travel forces bike manufactures to increase BB height and stretch CS length to accommodate this travel.
    I've even read that some bike companies boast that there 29ers have the same trail,bb height and only slightly longer CS length as there 26" offerings.When i hear this it makes me think that the SQUISH compromises handling geometry.
    CP
    Reputation: C.P.'s Avatar
    Short Stays are chosen based on riding style and experience. For me, (MTBing since '83, with a BMX background) it's all about a riding style that is "playful" in nature - one where the saddle is lower most of the time, and standing through corners and tech-sections is the norm. A bike well suited for "playful" riding has geometry that encourages this style of riding, and doesn't hold you back; In no specific order, shorter stays make a bike ridden in this riding-style more intuitive and easier to:
    • Hop
    • Manual
    • Wheelie/wheelie-drop
    • Maneuver
    ...based on my experience short chainstays make this style of riding possible.
    Category Winner
    Reputation: teamdicky's Avatar
    I've been talking off and on to Steve Stickel about a short stay frame since 2008. He's been building them for either six or eight years now (I forget which), and I finally decided to plunk down a deposit last September.
    I'm gonna horribly summarize what he told me about stability and chain stay length. Stability is a sum of its parts, and a short chain stay bike can be stable if built correctly. I've been riding my Stickel with the sliders set at just over 16 inches, and I've got no issues with stability. I've been to Pisgah on it at least three times now, and it's just bomber coming down the mountain. Sh!t eating grin kinda fun.
    That said, I'm enjoying all the benefits of the short stays tremendously. As one other poster mentioned, it's just playful as all get out. Switchbacks, logs, tecnical climbing... you name it. I'm tired of trying to figure why I like it so much. I just enjoy the ride now.
    It's been set up with a 100mm Fox Terralogic equipped fork for the past few weeks, and it's the happiest I've been with squish up front in a long time,
    WWW.TEAMDICKY.COM
    I get paid 3¢ every time I post on MTBR.
    Isn't "short" chainstays on a 29er the same length as standard chainstays on a 26er. So really not that short.
    Redding Trail Alliance - www.reddingtrailalliance.org
    Exactly....bike companies want the same handling capabilities of there 26" bikes.
    I'm a big fan of 29ers so the closer the tire is to the seat tube the happier i am.
    Jun 2010
    Quote Originally Posted by Loki View Post
    Exactly... which is why I think this chainstay talk ends up being a non-issue. If a person can tell the difference in 1/2", then they are officially over thinking things.
    I agree with the statement above, the bike and how it functions alone is the sum of it's parts, not one specific thing. Add the rider to that equation and things get really loopy.
    Quote Originally Posted by OmaHaq View Post
    1/2 " might not make that much difference in the bedroom but its very noticable on a bike.
    Try moving your seat for/aft 1/2" or up/down 1/2" or using a stem 1/2" shorter or longer or cut an 1/2" off your bars,you'll feel a noticable difference right away.
    A small CS change made a big difference for me when it came to traction. I went from a 18t cog to a 21t cog on my track end SS with no chain length adjustment and the slight shortening really helped my climbing. I'm unqualified to comment on all the "bedroom" comparisons.
    Quote Originally Posted by Bird View Post
    You're right. If I added a 1/2" to the dimensions of my bedroom, I wouldn't notice it a bit, but on the CS I would.
    EXORCIZE
    Why do you think chainstay length should be proportional to wheel size?
    Are there other frame dimensions/angles that change proportional to wheel size?
    2016 Pivot 429T
    2011 Kona Unit
    EXORCIZE
    Are you saying you can't tell the diifference in 1/2" of chainstay length?
    2016 Pivot 429T
    2011 Kona Unit
    MTB B'dos
    Reputation: LyNx's Avatar
    Myself I'm a tall guy and I made the switch to 16.9" stay Paradox back in August 2010 and couldn't believe the climbs I could make, how nimble it felt and yet confident on the descents. Now fast forward to February this year and I got my Prime, with 17.6" stays and a 3" longer wheelbase, you know what, it damn well climbs better than the Paradox did with 16.9" stays and I think it's a two-fold reason; 1 - the rear squish helping track the trail better and keep the tyre in contact with it and 2 - the longer stays helping keep the weight planted over the rear tyre for my height. I mean honestly 17.6" is not long for a 130/140mm travel bike, 26" or 29" wheeled, actually about avg for 26" wheeled bikes in this range, so really for a 29er and for me on an XL quite short.
    Been saying it for years that if manufacturers really wanted to have bikes sized up properly they also needed to lengthen the stays for the bigger sizes (or shorten for the smaller) will be interesting to see if this is true and what people think.
    ..................Height may have something to do with it. The taller you are, the higher your center of mass and then a longer wheelbase in general is better IMO at least. I just read where Norco I believe is making their chainstays size dependent. IOW, the larger the bike, the longer the CS, so it would seem that someone thinks it important enough to go through all that trouble.
    Jan 2005
    LyNx: Been saying it for years that if manufacturers really wanted to have bikes sized up properly they also needed to lengthen the stays for the bigger sizes (or shorten for the smaller) will be interesting to see if this is true and what people think.
    Definitely agree with that!
    My rides:
    KHS Team 29
    Feb 2007
    I think this is true and can be completely justified on the fit argument. When a rider stands, though, the fit changes. I think ultimately how someone views the CS length argument is determined by how they ride. There is an ongoing contradiction over whether short or long is best for climbing. I think riding technique explains that.
    It would be really interesting to see how a long travel 29er FS would work with really short stays. It is possible, just beyond what frame builders seem willing to try.
    I think a lot of the quest for shorter chainstays is driven by the fact that they are so difficult to achieve on a 29er.
    We lust after what we can't have.
    Whining is not a strategy.
    I don't think you understood what I said.
    Quote Originally Posted by Ryder1 View Post
    I said that short chainstays on a 29er are the same as regular xc chainstays on a 26er... so in reality, they aren't short, they are just where they should be.
    Trail Junkie
    Reputation: dubdryver's Avatar
    Mar 2006
    I think there are a lot of variables that should be taken into account. I don't think long stays are necessarily bad, they just need to take the rider's input differently to operate in the same fashion.
    A longer stay bike is going to carve around a corner with more stability...but that's not an absolute because overall wheelbase, HA, and BB height play a factor as well.
    I have:
    Salsa Selma (29er) with a chainstay of 17.9" wheelbase of 42.62", 71deg HA, 22.83 TT
    Santa Cruz Blur Carbon (26") with a Chainstay of 16.6", wheelbase of 42.8", 69.5deg HA, 23" TT
    Santa Cruz Tallboy (29er) with a chainstay of 17.5", wheelbase of 42.6", 71deg HA, 23" TT
    None of these bikes I feel are unstable. The fact that the 26" bike has the longest wheelbase, but the slackest head angle all contribute to how the bike feels, how quick and nimble it is. I will have to say that there are times with the Salsa..having the longest stays but almost equal to the shortest wheelbase is sometimes a task to get that back wheel come around a corner. It feels like takes longer to do so, where as the Tallboy feels much faster at doing so. So I feel even .4" longer chainstay does have some real merit. Also the Salsa is the hardest to get the front end up, but makes up for it in stability when the trail points downward. Its a downright stable bike on descents!
    I think this is why people dissect these GEO numbers so much, because they know what the different numbers feel like to them, and how they translate directly onto the trail....I feel I do, and I can definitely see a difference as well.
    My newest purchase was a Lynskey Pro29 SL with sliders. I have a 17.3" length currently, but I can slam it all the way forward to 16.9". I absolutely notice a difference between that and the Salsa in terms of how nimble it is. The Lynskey has the same exact TT length, 1deg slacker HA, and .6" shorter stays with a slightly lower BB, but I don't feel its just the shorter chainstay alone. I think the combination of a slacker HA and slightly lower BB combined with the shorter chainstay as a package makes it feel that way.
    Ibis Ripley LS
    Intense Spider 29 C
    Cervelo S2
    Trek Boone 5 Disc
    Spech Tricross Expert
    Raleigh RX 1.0
    Keep on Rockin...
    Reputation: Miker J's Avatar
    Nov 2003
    Jackrabbit or greyhound style?
    Overall, short stays make for a bike that handles well for me. Trails and riding styles either lean toward a jackrabbit riding style or a greyhound style. Snakey, choppy, technical trails are better handled with the jackrabbit style and shorter stays work well here. A longer, stretched out, big cookie spin ride goes the other way. I gravitate toward the jackrabbit style and trails.
    However, a recent finding I've come across is to move down a size in frames. Usually I ride a large but am also close to getting on a medium. My most recent frame, a RIP, has slightly longer stays, and a tt that is a bit on the long side. So, I tried a medium with a setback post. My overall reach is about the same, but my seated weight is placed over the rear wheel a bit more with the setback post. So, the longer CS issue is somewhat offset. As an added benefit, the front to center on the bike is kept shorter, so when I'm out of the saddle I can weight the front end and the bike carves the turns like a knife. Furthermore, the wheelbase is kept relatively shorter relative to a large frame, and that helps with tight handling as well.
    The chain stay issue is similar to xc/backcountry skiing where longer skis are faster, more stable, and more comfortable in the wide open. On the tighter trails, shorter skis are the ticket.
    Being a creature of the NE, I like shorter stays, but that does not mean they are better for everyone.
    EXORCIZE
    Quote Originally Posted by Miker J View Post
    Great post!
    I liked my previous long-stay 29ers at high speeds, but otherweise, I'm a jackrabbit.
    I tried downsizing on a long-stay 29er and liked it for xc riding (great steering/handling!) but gave up on it b/c of it's tech ability (too front heavy).
    2016 Pivot 429T
    2011 Kona Unit
    i am split right down the middle on this one.
    i love the way my vassago bandersnatch rides with it's long chainstays and reliable downhill stability, comfy ride and going all out on it. i never had an issue with tight switchbacks or similar trails.
    on the other side of the coin my kona unit with the rear wheel slammed all the way in is fun in a different way. both bikes are predictable and stable. they each have their own unique characteristics and i enjoy them both. more so than a middle of the road "so it all" geometry bike that excels at nothing, but does everything just "ok".
    my personal life has changed to where i can only have one bike, so i am having a custom frame built to incorporate the parts of both these bikes i like without having a middle of the road bike(like most manufactures build) that is good at nothing and just "ok" at everything.
    it pains me to sell both of these(in the classifieds right now), but i am hopeful that i can combine my favorite parts and have one fun bike.
    so my answer is "both". long and short. they are both fun.
    Seriously? I'm tall, and the last thing I want is a bike that is long in the wheelbase and chainstays for no good reason. I need a certain amount of top tube for the bike to fit correctly, so the bike is already going to be pretty long.
    Apr 2005
    IME, most people who've ridden a lot of 29er hardtails usually conclude that for STANDING climbing, the shorter CS works better 'all else being equal' (which in reality is never the case). For seated climbing, especially if you have a long inseam, the consensus tends toward longer CS being either 'OK' or 'Preferable'.
    The OP may have missed the many threads on this topic reinforcing the above.
    Stability at speed is a different topic entirely, and it's simplistic to think of it as the inverse of the CS question. Most frame designers seem to agree that wheelbase is the main factor driving stability, but HA, BB drop, etc play a role too. Take a sliding dropout, move it all the way back, and you've simultaneously increased CS and WB; to separate these geo effects on stability, you'd have to fabricate different frames.
    my Yelli gets ridden a lot more than my other two 29ers, and it's possible that the short CS/slackish HA is part of the reason.
    Originally posted by bucksaw87
    I still fail to see how mustaches, fixies, and PBR are ironic.
    transmitter~receiver
    Reputation: meltingfeather's Avatar
    Maybe because all of those things affect the fit?
    apples and oranges
    this is one of those personal preference/perception things that has no answer... as evidenced by the totally contrary opinions expressed in this thread.
    and trying to compare geo metrics between 26" bikes and 29ers is flawed thinking.
    Quote Originally Posted by pvd
    Time to stop believing the hype and start doing some science.
    29er Tire Weight Database
    Bedwards Of The West
    Oct 2007
    I climb better on a bike with longer chainstays. It's easier to keep the front wheel on the ground and to prevent the rear wheel from spinning out on steep climbs, especially when transitioning from sitting to standing on technical steep stuff. I like shorter chainstays for everything else. they make the bike easier to manual and flick around. I think I need to design something like a 'dropper' seatpost design for chainstays...so you can pop them out to full length when you hit a techy climb, and suck them back to short mode for the rest of the ride. Once developed, this technology should be able to be easily applied to wheel size also, so you can go from 26er to 650b to 29er with a button on the handlebars.
    (no excuse for that either)
    Quote Originally Posted by OneBadWagon View Post
    It's probably not that much difference in length. Personally, I think having different wheel sizes for different heights works the whole CS length out. IMO, it makes no sense for short people to ride 29ers or bikes with longish chain stays...as much as it does for tall people to ride 26ers hardtails with super short chain stays.
    Reputation: masterofnone's Avatar
    In the moto world, specifically bikes modified for hill climb competitions they will fabricate a super long swingarm, like two or three times stock length to get the best compromise of traction and slippage. Just a hair too long it will spin out, too far underneath the bike will wheelie and flip over. I'm assuming the rear is adjustable to compensate for the steepness of each individual track. I can't judge by chainstay length alone or numbers on a schematic and assume I know exactly how a bike will handle, it's the whole package. Like a drag car on the quarter mile, you can't just shove a huge cam or heads in there and expect them to work, it's the whole package.
    I agree.
    The problem with the hill climbing motorcycle analogy (that is used so often) is that those bikes don't have to turn, and dive through trees.
    A tall guy, on a tall bike, with a long wheelbase is a hell of a lot harder to navigate through twisty terrain than a shorter rider a shorter frame on a shorter wheelbase bike. Since I can't do much about my height, nor my seat height, I can certainly try to keep the wheelbase compact. If shortening the chainstays also makes it a livelier ride (and in my opinion, it does) then sign me up!
    Someone make me a Niner Air9 with a lower bottom bracket and 16.7" chainstays like my Yelli. I'll be in absolute heaven.
    EXORCIZE
    Last Saturday I swapped gears and went back to a 17.2 CS length from 17.6. I wasn't surprised when standing climbs felt more efficient, but I had forgotten how much better the bike steers/handles when set up like this. I got that "telepathic" feeling again. Definitely felt more fun. I also noticed the front end feeling a bit lighter, which is nice seeing how its rigid - I was naturally floating over rocks better. If the bike had gears, steep sitting climbs would probably be a problem (36" inseam). But it's a SS, so not an issue. I really can't understand long CSs on a SS unless (maybe) its a high-speed XC bike.
    2016 Pivot 429T
    2011 Kona Unit
    I too can feel a cog change ... but we're not supposed to! Short is nice for climbing.
    I personally have come to the conclusion that my short cs 29er is the closest option available that incorporates the positive attributes of my 26 inch bike while achieving the benefits of 29 inch wheels. The downside being the shorter the stays the less the options for front derailleurs and tire clearance issues (ingenuity and creativity aside) . The front derailleur issue was easy enough for me to solve by just running single speed. Single speedin on a short stay 29er and loving every minute of it! Aside from the occasional creak its grab and go baby
    Jan 2009
    I always keep my axle as far forward on my Karate Monkey as I can. this makes wheelies easier, which is all that matters.
    MTB B'dos
    For no good reason If you ride SS and/or constantly stand on climbs, then a short CS is super, but if you sit and spin up climbs you'll appreciate a longer CS, especially if you're a tall person - that's MY opinions anyway and thankfully whether you like it or agree/disagree with it doesn't matter, because it's MINE and I can like/think what I want
    Oct 2007
    easy wheelies x2. Priorities, people.
    There is more to riding a bike than climbing.
    MTB B'dos
    ....there is more to riding a bike than going DH.
    ....there is more to riding a bike than riding on the flats.
    ....there is more to riding a bike than .......
    Fact is, it's all one endless compromise, you just have to chose which is the most important to you. For me it's climbing, I just love to climb, the more tech the more fun, however I happen to have lucked out and my XL Prime, with 48" truck" wheelbase climbs like a demon and descending is very confident and nimble TO ME and suits me to a T. Only thing I'd like to change, is for a production one when it comes out with an estimated 700g frame weight loss and some nice tweaks
    Neg reppers r my biatches
    Reputation: FoShizzle's Avatar
    good thing that is the case given the average phat assedness of the 29er population who get winded downhilling
    Quote Originally Posted by mack_turtle View Post
    do you keep your front axle in the same spot at all times? why are there no adjustable fork dropouts? in carbon
    That's such an interesting change of position from a man who so vigorously touted the Paradox as the best bike in the history of ever.
    If you don't ride trails that wind through trees for miles at a time, then maybe wheelbase isn't a big deal to you. Having to take super wide lines to get the bike around will slow ya down. Ride what you like man.
    Don't let "for no good reason" get you all wound up. Your new bike has suspension, which is a sufficiently good reason to have longer chainstays, since it's pretty much mandatory.
    Quote Originally Posted by FoShizzle View Post
    I get winded getting my bike out of the truck!
    North Van/Whistler
    Agreed
    Quote Originally Posted by C.P. View Post
    • Hop
    • Manual
    • Maneuver
    and Agreed
    and see these comparative charts for bikes with shorter chainstays and shorter wheelbases from this review
    Locals' Guide to North Shore Rides http://mtbtrails.ca/
    it shouldnt surprise you given that the vast majority of Barbadians are well versed in hypocrisy. I will not be surprised in fact if LyNx's next bike is a Niner
    MTB B'dos
    It still is, but the jump for me in chainstay length was huge coming from my previous bike to the Paradox and flexy FS to super solid HT. Think the stays on the FS were 18.1" or something and then going to the Paradox @ 16.9" was a real eye opener. Now going from the Paradox to the Prime with 17.6" stays (not long at all to me for a 5" travel FS) I've found the bike climbs easier, but I think it's a lot to do with the FS factor and all the other parts that make up the whole, just like some said chainstay length is only 1 small part of the equation that = bike.
    Also as noted, the previous FS was like a wet noodle in terms of how flexy it was, so now having a really solid FS with a decently short CS and nice angles=heaven
    But you're making the comparison far more convoluted than it needs to be. I have a Performance Access that handles like absolute butt. The only real difference between it and a ton of other frames is that the Chainstays are almost 18" long, and the wheel base is right at 45". You get that thing in the trees and it's painful. I've ridden a billion other frames and you absolutely can find commonalities based on geometry specifics. So no, every short chainstay bike isn't fun to ride, just like every bike with long chainstays isn't a school bus. However, wheelbase is wheelbase, and when things get tight, it definitely has a dramatic effect. Even riding either of my bikes that are only .5" shorter feel notably easier to make tight switchbacks.
    If I was riding a medium, I probably wouldn't care nearly as much.
    Let me also add that the Prime looks like a lot of fun.
    Feb 2007
    Yeah, because 10mm out of 1100+mm is crucial.
    Quote Originally Posted by craigsj View Post
    Crucial? Not exactly. Beneficial? Absolutely.
    i agree. the single parameter of chainstay length it not meaningful, frame material is the only thing that is noticeable (e.g,. carbon) and nothing else matters, not rider skill level, not build quality, not other geometry, not components, not tire PSI, nothing
    Feb 2007
    Dramatic? Hardly.
    Dramatic? Hardly.
    You're welcome to demo my two bikes back to back, and get back to me on which one you prefer, and then you can look at the numbers and tell me why one magically rides better.
    You're showing your ass if you don't think that a half of an inch in wheelbase is notable, especially when we're talking about the far upper end of bike sizing.
    I used to ride a 19" framed 26" bike. Besides being absolutely ridiculous looking and feeling, it was very easy to navigate through twisty corners. Was it the wheel size? The Angles? Probably all of the above, and... here it comes... one of the contributing factors was that it had a 42" wheelbase.
    Everything related to bike handling is subjective. What I like and what I feel works well for my locale may very well be different than you feel about yours. I've chased enough fast dudes to notice their lines, and watch mine and try to figure out how to get a bike from point A to point B quickly. What is considered one of the best riding 29ers made? Check the jones space frame out, tell me what Jeff Jones has to say about wheelbase. Why do xc racers size down, sometimes to extremes? Less weight and a more "flickable" bike. Where do you think that term comes from?
    Reputation: vindiggitydog's Avatar
    I am always amazed at how someone can truly feel a .4 in. difference in CS IMO, there needs to be a more significant gap to see any real changes in performance.
    EXORCIZE
    opinions are like axles
    Quote Originally Posted by vindiggitydog View Post
    It's not amazing - my experience is different than your opinion.
    2016 Pivot 429T
    2011 Kona Unit
    May 2012
    I do a lot of back to back blind comparisons specifically related to bike geometry and i can tell you that most people cannot tell the difference in small changes(1 or 2 degrees) to ht angle or cs length in a blind test. I Have real world data that shows if you think you are on a short cs bike then you will tell everyone how short they are and how great the bike took corners even when they are not. Your mind is a powerful thing.
    MTB B'dos
    Yes, if I run my KM with the stays slammed all the way I can feel the difference between that and using the 10mm monkey nuts - bike feels a bit less squirely. I can also feel the difference when I run the same size tyres on it and when I throw a bigger one upfront, can def feel the steering relax a bit.
    All this being said, I thought like you while waiting on the Prime, my mind was going crazy thinking I should have sized down because I kept looking at the WB length and the fact it was 3"> longer than the Paradox, the bike I'd come to love and judge other bikes by - too many times people had their own HTs and hope on my Paradox for 2 minutes and when they hoped off were looking to order one because it felt much better than theirs. When I received the Prime I was still sort of freaking out and once I had it built I couldn't believe how big it was sitting there, but once I actually sat on it and pedaled it the extra 3" melted away.
    Now don't ask me exactly where or how Keith did it with the Geo, but he did, the thing barely feels any different from the Paradox in terms of handling and maneuverability, the biggest thing I noticed is the extra weight of the frame (gained about 4lbs from the Paradox) but other than that, very nimble. I'm not really a "fast" type rider, I love slow, tech, rock crawling type riding, but when faced with sweeping, fast trails, most especially with tight trees, the longer wheelbase and 31" wide bars I seem to manage just fine getting through them, in fact guys were on my tail on the open sections often get dropped in the tight, tree lined sections.
    Most powerful tool/weapon in the universe So as I say above, when I swung a leg over my Prime knowing full well it had a 3"> WB to my Paradox and it felt no different I was blown away.
    Quote Originally Posted by PeopleForScience View Post
    Feb 2007
    Right, and you are full of arbitrary hyperbole on the subject.
    A half inch of wheelbase may be "notable" in some respects but not in others. Just because 1/2 inch of extra BB distance may have an effect on some handling traits doesn't mean other traits are "dramatically" different. A bike's turning radius is determined by its wheelbase, but a difference of less than 1% results in a change of less than 1%. A minute difference, not a dramatic one.
    Where have I heard that before? You resort to the "feel" argument when you can't win the fact argument. Typical MTBR tribalist garbage.
    Feb 2007
    Half an inch on almost anywhere on a bike is going to be noticeable if your bike is on the edge of acceptable.
    If your bottom bracket is low, and then you ride a bike with one a half an inch lower and you start smacking pedals like crazy, is it noticeable? If you're riding a frame that's a little too small and you lose .5" off of your ETT, is it noticeable? Seatpost a half inch too low? If you're riding a Karate Monkey and then you ride a frame with a degree steeper headtube?
    If you're honestly telling me that riding a bike with .5" longer chainstays and < .5" longer wheelbase has no real effect on a rider's ability to get a bike through tight corners, then I'm not sure what to tell ya.
    Feb 2007
    There you go with "noticeable" again when it used to be "dramatic". There's a difference, you know...
    And while 1/2 inch may be "noticeable" in some dimensions, it is not in all.
    A 10mm change in ground clearance is much more than 1%.
    "Noticeable" maybe, dramatic no. I don't accept the popular wisdom here that bike sizing is that critical. Riders can easily adapt to multiple sizes. There is typically only about 20mm difference between sizes so all you are talking about is 1/2 a size, not very significant.
    These are all irrelevant. You claimed that 10mm of wheelbase makes a dramatic difference, not that 10mm of ground clearance can be noticed. Not all 10mm dimensions are created equal and it doesn't take much intellect to understand that.
    You can't tell me anything. I don't buy into your fantasy. 10mm of wheelbase is not at all significant.
  67. #67
    First off, 1/2" is 12.5mm, so stop trying to trivialize the number by rounding down. This is where I should point out that you're using hyperbole.
    If your bike is on the edge of acceptable. I'm guessing you just glanced over that one. If the bike is not in that happy medium of sizing or angles that you like, then differences will be noticeable.
    You're saying that a half inch doesn't make a difference, I say that it does. I have two bikes built up that are almost identical except for one of them is 44.4" long and one is right at 45" long. The longer one has a slightly steeper STA and .5" longer Chainstays. I have ridden them back to back, in addition to dozens of other frames. The difference between the two is noticeable, I'm not telling you to sell your bike and buy a shorter one. I'm telling you that my trails are tight and winding, and being able to square off the corners on a shorter wheelbase bike is MUCH easier and faster.
    Do your thing, broseph. How much would it take to be significant? Would 1" added to the chainstays on your current frame be significant?
  68. #68
    North Van/Whistler
    I ride prototype bikes and equipment for a variety of different companies (no divulging names due to confidentiality) for both biking and skiing. The engineers/designers almost always do not give us tech details re changes for reasons that are explained as not wanting to colour our input. The other people who test like me have decades of experience and literally have ridden tens if not hundreds of frames, bikes, skis, boots, etc etc.
    The majority of us (say 9 out of 10) cannot tell the difference between 1 deg of HTA or STA change; or 12mm of BB delta; or degrees of bevel of edge. Some of us can but those who can tend to be the ones who are really picky about bike setup - eg one guy knew that his test bike had a less than 5mm change in chainstay length.
    I'm throwing this out there to give a real world small sample of anecdotal unverified data. Fwiw speaking for myself personally, I adapt easily to different bikes and doubt I could tell differences between 10mm in wheelbase but that maybe, possibly somebody else could
  69. #69
    Quote Originally Posted by LeeL View Post
    wow! you are almost as awesome as JNC
  70. #70
    North Van/Whistler
    Almost! Wish I knew who JNC is so I could compare e-penises
  71. #71
    Feb 2007
    I didn't glance over it, I just think it's pathetic that what was once so dramatic has now devolved into b*tching about the difference between 10 and 12.5mm on bikes that are barely suitable to start with. Why do you even bother?
    Yeah, 1% easier and faster. You couldn't tell that in a blind test of your life depended on it.
    I say do your own thing as well, just don't tell us how special the benefit you imagine is. You don't understand how trivial the change in wheelbase is because you don't want to.
  72. #72
    dont get carried away...i was very clear in saying "almost"
  73. #73
    You're really good at multi-quote. Even better at ommission!
  74. #74
    Reputation: JoshM's Avatar
    It's actually 12.7mm
  75. #75
    EXORCIZE
    You're very confident of what others are perceiving and when they're being delusional. OneBadWagon and I have posted some of our experiments and findings. Its true that we can't prove we're not fooling ourselves. On the other hand, have you conducted any experiments or are you just eyeballing the geo numbers and announcing what you think looks significant?
    My interest has largely been the effect of shortening chainstays upon standing climbs. On my Niner, I shortened the CS .5" w/o changing the WB one iota and then rode trails I've ridden 100+ times. The CS was ~3% shorter. Please tell me if I should have been able to tell a significant difference in climbing and handling.
    2016 Pivot 429T
    2011 Kona Unit
  76. #76
    Not meant as a dis......
  77. #77
    Your experiments are all blind, I assume, to preclude the very powerful and well documented effects of confirmation bias. Right?
    As I'm sure you know, blind and double blind testing, particularly when human interpretation is involved, is a crucial component of experimental protocol for a reason. Without it, most results are considered worthless.
    Nobody can make an argument against what you think you feel/see/hear. Getting defensive if questioned is a typical response. That's why these discussions usually dont go anywhere.
    If I told you I saw a unicorn ****ing a leprechaun trail side, you'd probably be suspicious.
    Oh, and you also changed the fit of your Niner in that experiment. Of course, that has no effect on your results.
  78. #78
    Feb 2007
    I quoted the comments that I responded to and am not interested in your misrepresentation of my position. If making the basic observation that 10mm, or even 1/2 inch, is a trivial change to overall wheelbase then my "eyeballing" should be celebrated, not condemned. It's a simple fact, no experiment necessary. Wheelbase does affect maneuverability but it takes more than 1% for a "dramatic" dfifference. The fact that OneBadWagon doesn't understand that should tell everyone how tainted his opinions are. He is no scientist and I suspect neither are you.
    That is a difference subject than OneBadWagon's turning radius. Go bait someone else.
  79. #79
    I've decided that I'm going to sell my bike that has shorter chainstays and wheelbase. You've convinced me that all bikes ride the same, and there is no reason for me to have any preference at all. Since we've determined that according to you, chainstay length, wheelbase, and to a certain extent fit measurements don't matter, I'm saving myself a lot of money. Please keep our little secret long enough for me to make my money back out of two bikes that I previously thought rode great.
    Hopefully you can share some more enlightenment on components next. I'd previously been using parts that I found had good feel and good durability. I'm waiting with bated breath for you to fill me in on the next round of "My opinion is better than yours 2012".
    You've chosen to ignore plenty of my points, and misconstrue / manipulate many of the others. There's no point in discussing things with you. I could tell you that i average 1mph faster on my bike with shorter CS/Wheelbase, and you'd say that was ******** too. Have a nice day sir.
  80. #80
    Feb 2007
    Grossly misrepresenting what others say is a sign of a weak mind. This clearly makes you angry but that's not my fault. Next time, don't say stupid things and try to learn something.
    I've offered no opinion. That's your domain.
    Yes it would be, but an approach like that would be right up your alley. As for "manipulating points", look at you. Go ahead and tell some more outright lies, it's done so much good so far.
    It's fine if you wish to wallow in ignorance, just don't inflict it on others.
  81. #81
    Completely ignoring that I said that reduced wheelbase AND reduced chainstay length had a cumulative benefit that is noticeable. I also said that I didn't want a bike that was long in both regards due to wheelbase, which is the reason I don't ride XXL bikes.
    The point that you don't seem to understand is that given the choice to somehow cram the ST and ETT that I want onto a frame with a 22.5" wheelbase would be ideal. I'd love to have a bike as maneuverable as a "normal" bike, but since my height precludes that, I have to worth with what I can. You are the only schmuck I've ever seen on the internet or elsewhere that will spout forth about a reduction in wheelbase not having a difference in the feeling of what motorcyclists would call "flickability", or a reduced turning radius, decreased steering effort and a more playful feeling bicycle.
    The fact that you won't address any of my questions directly only further proves that you have no interest in the discussion and only look to be swinging your e-dick around.
    following these statements:
    Please show me where I said it was crucial. You start trying to put words in my mouth here, a practice which you obviously use to flavor the readers interpretation.
    Dramatic? Hardly.
    I thought you said that you weren't offering opinions? Here's a little snippet of subjective information. Thanks for stopping by.
    Do you ride a bike with a 45" wheelbase? Please answer the question. It has a lot of bearing on your opinion on the subject, since your entire argument is flavored on what does or doesn't make a difference on XL+ bikes. What would constitute "dramatic"? To me, any tangible benefit is a benefit just the same. I didn't say that jesus came down and blessed my shorter CS/WB bike, just that it handled better. And it does, and you have provided zero evidence that a bike with shorter chainstays and wheelbase wouldn't handle better, because there isn't any.
    The only straw you're grasping at is the linear relationship to wheelbase and turning radius, ignoring the easier maneuverability/easy to manual nature of a bike with a shorter back end and belittling any rider opinion, because it's anecdotal. If I had liked the way my long chainstay bike rode, I would have never purchased another frame! It rode like crap, so I looked at the differences between it and the frame previous. Guess what the difference was? .4" shorter Chainstays and a slightly slacker HTA. By your mentality, none of that matters, but since I'm out riding my bike everyday, and riding the one that I don't like makes me enjoy that time just a little less, I gladly made a change. Just as I would make a change to a bike that I felt was too twitchy, or too soft in the bottom bracket, or anything else I didn't like.
    The simple fact of the matter is that I can tell the difference between two of the bikes that I currently own. It is a very real difference, and just because you don't care to believe that doesn't make it any less true. This isn't internet speculation, this isn't me letting my mind run wild, this is me riding bikes back to back and picking the ones that I like more. If I like the one that has a shorter wheelbase and shorter chainstays, but overall the rest of the geometry is very similar, then call me crazy, but I'm going to have to say that those variables are the deciding factor.
    Yes it would be, but an approach like that would be right up your alley. As for "manipulating points", look at you. Go ahead and tell some more outright lies, it's done so much good so far..
    Please tell me where I'm manipulating points. I'm simply trying to find out how big of a change in geometry are us feeble minded riders supposed to notice.
    Care to support any of your previous statements, or is this just more diarrhea of the keyboard coming from your end?
  82. #82
    Feb 2007
    It isn't a cumulative benefit when it is one change. You also said "dramatic", then changed it to "noticeable" when you got caught.
    I have said nothing like that.
    Again, look who's talking. The biggest e-dick here is you. I have, in fact, addressed your absurd statements more than once.
    Where did I say you said that?
    Tiny intellect on display again. Flavoring the interpretation is your game, not mine. You said the difference was "dramatic".
    Claiming a 1% difference is subjectively small isn't opinion, it's well established fact. You just can't accept it because you want to believe otherwise.
    Creating special meanings for words in another tactic of the desperate. It doesn't matter what I believe constitutes "dramatic", the word means what it means. If you wish to communicate, learn the language. Your illiteracy may be the problem here, but it's not my problem.
    I've provided as much as evidence as you, I just don't make indefensible claims.
    It's you that's ignoring that linear relationship because (a) it's a fact, and (b) it disproves your position. The easier "manual nature" of the bike is a different subject, and I won't let you change the subject.
    By your mentality, none of that matters, ...
    I do not have that mentality, you just wish to represent me that way.
    That has nothing to do with your claim that small CS length differences result in dramatic differences in maneuverability. You are welcome to offer your retraction on that statement; I'm not interested in your other b*llsh*t.
    Have done so repeatedly. It's funny that someone so eager to tell the feebleminded how it is should say something like this.
    What more do you need? It's clear you are neither able nor interested in learning here.
  83. #83
    get down!
    I guess this goes to show you that whether the chain stays on a bike are long or short, people can still be @ssholes
  84. #84
    Moderator Moderator
    Reputation: Walt's Avatar
    For those who are interested
    There is a lot of science in determining the "just noticeable difference" in all areas of human perception (commercially, this is a great way to, say, make your candy bars just enough smaller that you spend less on ingredients, but customers don't notice). I doubt anyone has done this with bikes, but for most stimuli, humans are pretty bad at judging differences in magnitude (regardless of sense) of <10%.
    If you have a lot of expertise with something (say, you're the QC guy who picks up and weighs each candy bar and you've done it 10,000 times) you can get quite a bit better at it, but off the top of my head I'd say that most people are not "expert" to the point that they'll notice a 10mm difference (or more) in most bike dimensions (I include myself in that category, btw, so don't get offended).
    If you want to try testing your visual just noticeable difference ability, you can do it online (but it will take you a while, you have to do 200 comparisons!)
    Weber's Law of Just Noticeable Difference (Edit: apparently you need to be a psych student to log in and do this, sorry)
    That said, the fact that you can't *feel* the difference between 420 and 435mm chainstays does NOT mean you are wrong to prefer the shorter ones. That would be akin to saying that the smaller candy bar is just as good as the bigger one - it's not, even if you can't quickly tell the difference by look or feel.
    Some benefits/drawbacks of shorter chainstays are indisputable - with an infinitely long chainstay, you'd never be able to lift the front wheel, for example. A chainstay length of zero, on the other hand, would make it impossible to keep the front end down on almost any climb. I could go on and on but the bottom line is that picking shorter (because you're short, or you want to be able to wheelie just a little easier, or whatever) chainstays isn't wrong, even if the differences you think you notice are mostly in your head.
    -Walt
  85. #85
    EXORCIZE
    you're all conducting a case study, but ignore all your findings
    Quote Originally Posted by meltingfeather View Post
    I generally agree with you. You deleted this portion of my post: "Its true that [OneBadWagon and I] can't prove we're not fooling ourselves." And it's because one rider's experience is not conclusive that I read/post in threads like this one. I want to read other people's experiences like those by OneBadWagon, Lynx and Leel. Yes, Lynx may be deluding myself, but until I see blind data of seasoned riders, I'll consider his and others' experiences. A collection of testimonies, while still not journal-ready data, is more reliable than a sample size of one.
    What I don't find helpful is the use of arbitrary math in a vacuum to form a "fact argument" while not doing any testing and ignoring/ridiculing the experiences of others. The data must derive directly from the ride itself, not selective math calculations. Would a bike journalist reviewing a frame analyze the frame's geo and carbon layup and not bother to build and ride it? A 1% delta may sound insignficant, but I would need to add 4.4" to my chainstay to increase the WB by 10%. And if tonight I somehow alter my bike to have 22" stays, I'm not going to sit around caculating the WB delta. I'll go ride the thing!
    Yeah, exactly my point. The math quickly appears futiley when multiple variables are introduced. And any single change causes multiple variables.Solution? Ride it!
    2016 Pivot 429T
    2011 Kona Unit
  86. #86
    EXORCIZE
    Yes, it's a fact. I just think its not very useful - especially when you can conduct the experiment.. I don't see how you can take a number on a page and become convinced what a rider is or should be experiencing. What does a 2% delta feel like? 3%? How do you make that leap, that nexus? It seems like you're just shrugging, and saying, "looks small to me; person X is obviously delusional."
    2016 Pivot 429T
    2011 Kona Unit
  87. #87
    I think a safe assumption is that everyone here rides mountain bikes. "Ride it!" is not a novel concept. There is no "math in a vaccum." We all ride bikes. Some of us also think analytically. We talk about bikes in analytical terms because we like both of those things. It doesn't mean I'm sitting in a lab somewhere poking a bike with forceps. I'm sitting at my desk in a kit cooling off from my early afternoon ride.
    I myself mostly ride singlespeed with sliders, so I have a pretty solid base of comparative riding on differing chainstay lengths.
    I don't quote all of every post I respond to... just the parts I'm responding to... for clarity.
    Most people here seem to respond better to stuff like, "flickability was way high, bro" than any type of quantitative look at things. The thing is, "flickability" doesn't mean anything... or at least it doesn't mean anything that I can understand when two different people use it.
    The irony in the whole thing is... I (almost) only ever talk about bikes analytically here on mtbr... which is where people inevitably say, "go ride your bike." Well... I just got back.
  88. #88
    Feb 2007
    This didn't happen, of course. The claim made was that a 1/2" difference in wheelbase made a "dramatic" difference in turning ability. Pointing out that a 1/2" amounts to 1% is in no way "math in a vacuum". It is exactly the opposite.
    A 1% delta may sound insignficant...
    And it is...with respect to the subject at hand.
    This was your failure, not mine. I did not introduce additional variables nor change the subject as you did. In fact, I resisted those things...and for a reason.
    It is incredibly useful and there would be no experiment that would shed more light on the subject. Experiments aren't needed for everything, that's why we have educations.
    Because I think logically and am familiar with the concept of "just noticeable differences" that Walt referred to earlier. A change of this nature as small as 1% would not be noticeable without some means of discriminating. Just because there are people who don't understand this on MTBR doesn't mean it can't be understood.
    Start here. There is a science to this and not everyone is ignorant of it.
    Just to be doubly clear, I never said that riders couldn't tell the difference in CS length. I have taken no position on that. I said that riders couldn't notice a 1% difference in wheelbase in regard to turning ability. People love to talk about CS length and it's effect on turning, most of which is ridiculous. CS length affects the behavior of the bike when out of the saddle, it's effect on turning is grossly overblown.
  89. #89
    EXORCIZE
    I'm not saying, "just ride." I'm saying "ride AND analyze". My criticism is of the "analyze and don't ride" camp (not that you're part of that camp - I was simply continuing my thought).
    2016 Pivot 429T
    2011 Kona Unit
  90. #90
    Feb 2007
    Your ongoing personal attacks are tiresome. I know that one and one makes two and I don't need an experiment each time I need that answer. If you need an experiment to understand that, by all means do it but don't come here afterward claiming the answer is three. The answer is what it is whether you realize it or not.
    When you try a new bike, do you try every size in order to know what you like best, or do you rely on your personal fit experience? Does using your experience put you in the "analyze and don't ride" camp? Do you start over again every time you make a purchase? If you like a 100mm stem, do you try every stem length again when you switch models? How could you know without an experiment?
  91. #91
    This whole thread sucks a bunch of e-dick.
    Who let you guys on the internet anyways?
  92. #92
    I just went from 18.3" chainstays to 17.3", with an increase of 1" in the top tube, with a 72-69.5 HA. Bike felt more sprightly and eager to change direction than the one before. I can't believe how much the handling improved...or maybe I just can't believe how bad the handling was on the old bike.
  93. #93
    EXORCIZE
    asking the same question twice
    Perhaps you two (and I) don't disagree all that much. If OBW narrowed his claim and said that shortening a bike's CS by .5" (and therefore its WB by .5") causes a dramatic change in tight stuff, would you say his claim was necessarily false?
    Still not clear to me. I don't see how you can be entirely agnostic towards CS length while making a universal (?) statement about WB. Question: Are you saying that your statement holds true even in instances when the 1% comes soley from shortening the chainstay (e.g. sliding dropouts forward)?
    2016 Pivot 429T
    2011 Kona Unit
  94. #94
    Old school BMXer
    Reputation: Blaster1200's Avatar
    Quote Originally Posted by Walt View Post
    -Walt
    That was the only sensible post that I could tolerate to read the entire post.
    May the air be filled with tires!
  95. #95
    EXORCIZE
    I don't see how I attacked your person. I summarized your method as I understood it and actually made a point not to personally refer to the method as being yours. That's as impersonal as I can get.
    Yes, I still experiment quite a bit. Based on past testing and working conclusions from that testing, some types of testing are no longer necessary (I've owned a medium frame and several XL frames and now have the basic size question fairly narrowed down). Of my current build, stem and bar dimensions are TBD. I'm also going back to 175mm crank which will be interesting. And I'll be trying the fork at different lengths. I'll be sure to post every detail about every change I make and each dramatic difference I find.
    2016 Pivot 429T
    2011 Kona Unit
  96. #96
    Don't mind craig, who has been blatantly attacking everything about my argument and me personally while failing to address my initial claim of a bike that was .5" shorter in BOTH WHEELBASE & CHAINSTAYS is quicker steering than a comparable bike with .5" longer wheelbase and chainstays. Since I must absolutely be making up my assertion that I can tell the difference, he's made no bones about attacking my intellect, because we disagree on something subjective.
    Craigsj, you're doing everything that you claim I'm doing in this thread, and you look like a chump because of it. There's no reason to continue posting here, as you've already made your mind up to the difference (or lack of) in handling between two of MY bikes.
  97. #97
    Feb 2007
    He has said exactly that and I already responded. I say it is not dramatic and generally not even noticeable.
    CS length defines the relationship between the BB and the rear axle. It only affects WB if you assume the front-center stays the same. It would be equally valid to assume that altering CS length changes the front-center because WB stays the same. People don't typically think like that but I do. With interdependent dimensions, you can't change one thing without changing another; you need to understand what effects are attributable to what.
    CS length has no influence on steering. Wheelbase and steering geometry do. CS length can change body position and body position can influence the perception of steering. There is a difference between how a bike turns and how you perceive it. I liken that the the difference between the front and rear seat of a roller coaster. You may like the feel of being further back on the bike, but you can move further back on a bike with longer stays, too. People can be very close-minded when it comes to fit. Once you stand, though, your seated fit becomes irrelevant.
    I am not agnostic regarding CS length, I just haven't expressed opinions here regarding standing handling. Standing vs. sitting is at the heart of the issue, not wheelbase and turning radius.
  98. #98
    Feb 2007
    You objectively summarized me as an "analyze and don't ride" person based on what? What did you hope to accomplish with that description and why did you think it so important to tell MF that he didn't fit that description so as not to offend him? It's hard in that context not to take that comment as a personal insult because that's precisely what it is. It is unfounded as well.
    So it should be easy to understand that the issue here is that you don't know why this is so easy to know without further experimentation.
    If developers took the "always start over from scratch" approach, we would never have progress in anything, bicycles or even the wheel. We build on past knowledge and achievements and do that through education. Some of us have that education and others do not. Forums make it appear that those groups are on equal footing, and people who lack basic knowledge often believe temper tantrums can get them their way.
  99. #99
    Feb 2007
    You cannot change one without the other unless you make another change. These changes are one in the same. They are interdependent measurements.
    Yes, I have been attacking your argument because it is delusional and you are wrong.
    The personal attacks start with you, you are absolutely making up your assertion, and this is not a subjective matter.
    Yes, this is called "tit-for-tat". Look it up. Everything you do to me comes back at you and will continue. You will never dominate an argument with me by being a bigger a-hole. I can play your game too. As for looking like a "chump", look who's talking. At least I know what I'm talking about and I couldn't care less about your bikes.
  100. #100
    Of course they are interdependent, when talking about two different frames with comparable specs otherwise. However when you have two frames that are virtually identical, with the most notable difference being a half inch off of the CS length, thus a half inch off of the wheelbase, it's a bit easier to compare. How ****ing hard is it for you to understand that?
Page 1 of 2 12 LastLast
Members who have read this thread: 37
