Results 1 to 27 of 27
    Light-bicycle wide rims = Flow EX's??
    this might be far fetched, not sure. tried and true top end alloy rims in the Flow EX, to the new comer with a young but good reputation from afar using a totally different material. part of me wants the best tough rim and peace of mind (the flow) the other part wants the same, but the new fangled weight reduced, still stiff as hell has big appeal. both will be very spendy with the light bicycle even more so. the reputation of LB while not spotless does continue to improve. tough call...
    LB is significantly lighter and significantly stiffer. You take some risk as there have been some issues, but mine have been bombproof so far in very rocky conditions....I would go LB without hesitation when choosing between the two.
    significantly stiffer? wow, quite the endorsement for LB, given the new Flow's stellar reputation.
    i'm going to put a "that's what she said" sticker on my lb rims. or go with a blue theme on my bike. and call it viagra. lol
    Been on the wide LBs for over a year. Thrashed the hell out of them. Lots of rock strikes. They scratch, but are still solid and true.
    Reputation: Atomik Carbon's Avatar
    The biggest drawback to the Flow Ex is the inside rim dimension. There is an article written by Richard Cunningham on pinkbike that explains what a huge difference the width makes.... I will look it up and try and post it.
    banjo plunker, wrench
    Reputation: swaneedawg's Avatar
    Thanks for sharing! I have always felt "wider is better" for tubeless...now there is evidence for the madness!!!
    any time spent riding a bicycle is re-cycled goodness....
    Bicycle Addict
    Reputation: J3SSEB's Avatar
    WTB Frequency i-23 is another viable option. They are light, stiff, and relatively inexpensive. The inside diameter is 23mm, hence the name.
    The unexamined life is not worth living - Socrates
    Bearded Women Racing
    Quote Originally Posted by YaMon View Post
    So I must be missing something. Last I saw the LBs were 23mm inside and the Flow EX are 25.5mm so the Flows have the advantage on width.
    OG Ripley v2
    Carver 420 TI
    YRG
    YRG is offline
    Feb 2012
    How wide a rim are you running? Are you confusing the low profile of the bead with the width of the rim?
    Flows are amazing, and lb rims are looking better!
    Quote Originally Posted by TwoTone View Post
    Exactly....
    Mine are currently 23mm, but I am upgrading to a new set of carbon fiber hoops and the I'd is 24.8mm. The exterior is 34mm x 26mm.
    Oops. I had meant the LB. the flow ex is quite wide....
    I guess the main issue is how current their web site is regarding their product offerings. I would like some WIDE light carbon rims, and I can't tell if they make them or not. I'd take a little narrower than Flow Ex, if I can save 150gms per rim and run them tubeless?
    AZ
    AZ is offline
    Reputation: AZ's Avatar
    Quote Originally Posted by Wish I Were Riding View Post
    The wide LB rims come in around 395/400 grams and can be run tubeless w/ Bonty rim strips.
    Are we talking 29er rims? In what ID width? Because this is something I am interested in. I haven't really gone through those other threads because they are just too long...
    LB rims are 23mm ID, ENVE is 24, I believe Flow EX is 25.5.
    Always Learning
    Reputation: BruceBrown's Avatar
    Quote Originally Posted by Dirty $anchez View Post
    Game changers compared to the Flows - at least the older ones. I've run Flows (I9 Enduro wheels) and the Light Bicycle rims on my RIP. Love the carbon rims (use the Bonty strip and have never burped, airs up easily with a floor pump).
    Ran the Flows on the RIP until the carbons arrived and were built in mid-April 2012.
    <a href="http://www.flickr.com/photos/7166535@N05/6982027119/" title="Nics by BBcamerata, on Flickr"><img src="http://farm8.staticflickr.com/7209/6982027119_7a632c37e8_z.jpg" width="640" height="438" alt="Nics"></a>
    Here they are a year later and as I said - game changers.
    <a href="http://www.flickr.com/photos/7166535@N05/8671710371/" title="XCRIP9Tires by BBcamerata, on Flickr"><img src="http://farm9.staticflickr.com/8261/8671710371_1869c844c7_z.jpg" width="640" height="403" alt="XCRIP9Tires"></a>
    Quote Originally Posted by BruceBrown View Post
    Old Flows were 22.6mm. Not even in the same zip code as the new Flow EX.
    Reputation: rob1035's Avatar
    Isn't one of the benefits of the Stan's bead shape a wider tire profile?
    Always Learning
    I was addressing the OP. I am of the opinion that the light weight stiffness factor of the LB carbon wide AM rims usurps the Flows - and changes the game out on the trail in performance. I have both and simply base it on how my wheels perform under a variety of conditions. In spite of the inner rim width being a mm or two narrower than the newly designed rim hook of the Flow EX, the stiffness on a full suspension bike is a huge . Not to mention my carbon wheelset with the LB's are 300g lighter than my I9 Flow Enduro wheels.
    Width aside, the performance of the carbon rim is - IMO - justifed over and above the Flow rim at least in terms of the genre of XC and Trail bike (whatever that is for various opinions).
    And that's saying something because the Flow is a great rim.
    BB
    I'm not convinced. Okay I am. Did you build the wheels yourself? I think I'm ready to take the next step here...
    Always Learning
    My LBS built them. AC hubs and the kit to convert back and forth between regular QR and 15mm TA, Wheelsmith spokes, LB AM rims.
    <a href="http://www.flickr.com/photos/7166535@N05/6885905902/" title="Carbon29erRims by BBcamerata, on Flickr"><img src="http://farm8.staticflickr.com/7053/6885905902_3bf29d2911_c.jpg" width="800" height="623" alt="Carbon29erRims"></a>
    <a href="http://www.flickr.com/photos/7166535@N05/7075413691/" title="AM Chinese Carbon Wheels by BBcamerata, on Flickr"><img src="http://farm8.staticflickr.com/7269/7075413691_f35c3ec4fe_c.jpg" width="800" height="394" alt="AM Chinese Carbon Wheels"></a>
    <a href="http://www.flickr.com/photos/7166535@N05/7082751231/" title="1540g by BBcamerata, on Flickr"><img src="http://farm8.staticflickr.com/7239/7082751231_555cb80f27_b.jpg" width="804" height="1024" alt="1540g"></a>
    Mulleticious
    Reputation: BigwheelsRbest's Avatar
    Bonty rim strips?? I've heard that tape is good enough - is this not true?
    Mulleticious
    Very sexy. What finish did you request - UD with the matte finish ??
    Quote Originally Posted by BigwheelsRbest View Post
    Tape works, but the rim strips are fantastic. It's like they were made for the wheels. Totally effortless tubeless setup with a floor pump and Schwalbe TLR tires.
  1. Original Stans Flow vs Light Bicycle carbon wide in 26"
    By baltik in forum Wheels and Tires
    Last Post: 04-09-2013, 04:17 AM
  2. Replies: 53
    Last Post: 03-04-2013, 02:34 PM
  3. Some 650b flow EX's for my Fuel EX
    By ptbo_mac in forum Trek
    Last Post: 01-25-2013, 01:34 PM
  4. anyone riding on flow ex's?
    By bhigdon101 in forum All Mountain
    Last Post: 08-08-2012, 12:13 AM
  5. Replies: 5
    Last Post: 12-04-2011, 02:40 PM
