jabber frame
black sheep ti fork
hopes on arches (i9's ordered)
white ind. cranks/32t chainring
crossmark r/racing ralph f
formula oro bianco brakes
boone 17t cog
thomson masterpiece seatpost
wtb devo carbon seat
truvativ carbon riser bar
titec pluto carbon stem
esi foam grips
king headset
xpedo ti/ti pedals
fsa team issue chain
phil wood ti bb
last weighed 20.37 lbs with bottle cage
hoping to be under 20 when the new wheels get here
PoorBehavior: Nice Jab! Are they On-One Fleegle bars?
Thanks, and yeah they are fleagle's. I have some Mary's I am going to give a shot as well.
Well, that is as soon as Uncle Sam lets me loose for a while.
My bike will be finished up tomorrow and I'm going to FLY back home to try and pick it up before the shop closes tomorrow. If I'm successful pics will be up tomorrow, if not friday morning.
Most of the parts are taken from my old ride which was 2005 rig, ridden only from the last year. I've upgraded the cockpit with new shorter stem from kcnc and with monkeylite handlebar. My legs are relatively long so i had to get a 500mm post for me.
I feel like that more or less every bike has too much standover for me or are just too low. Maybe next one will look a bit better and I get to shave off some grams from seatpost.
With a little weightweenie in me I really can't weight it or else I would get the obsession to get it under 10kg mark. It's pretty much stock Rig2005 so its not that light or bling, just the best bike i've owned so far.
Here is a bad angle pic of my Jabber. I put the Vassago fork back on it the other day and I must say it is a really nice steel, especially for the money. I will try to post a pic of the current build later today.
Some parts I kinda threw on there and will be upgraded soon. Im loving Vassago fork offset! Goodbye toe overlap!
Specs:
Avid BB7 w/ SD7 levers
SRAM cable kit
Vassago ODIS black
Chris King black headset
Thomson X4 stem 90mm
Titec Enduro XC bars
Oury lock on grips
Thomson Elite 410mm post
WTB Pure V saddle
Salsa lip lock silver
Race Face Evolve ISIS cranks soon to be Middleburn RS7
Salsa 32T chainring soon to be Middleburn Uno
Shimano PD520 soon to be Crank Brothers Candy SL
SRAM PC870 8-sp chain
Gusset 18T cog SS conversion kit soon to be CK stainless steel
Alex TD17 front & ZTR Flow rear both w/ LX hubs soon to be Spinergy Xyclone white
Chase titanium cage bolts
Vassago 18in frame
Vassago steel fork (previously had the first generation Black Ops carbon fork)
paul hubs/alex rims
old xt cranks and bb
old xt brake levers
avid bb7 brakes
salsa cromo stem
salsa shaft seatpost
salsa low rise carbon bar
old school san marco saddle
geax saguaro tires
ergon enduro grips
Looks like you are using ENO cranks, did you have problems with the torque on the driveside crank bolt? Im using 68x113 shimano un26 and the lockring rubs with the BB cup stalling the entire crank. Should I be using a longer spindle? WI suggested a 68x113.
I have run a 113mm BB with my ENO's on a Jabberwocky and the cranks lock ring never came close to rubbing the fixed cup of my BB.
Are you SURE your's is a 113mm???
Oh me oh my, I showed the bb to my LBS and the axle is offcentered! The spindle is recessed on the driveside by at least 5 mm. Can't believe i didnt notice. It's 113 mm but clearly more spindle is showing on the nondrive side. Defect! No more UN26's for me!
Vassago 18in frame
paul hubs/alex rims
old xt brake levers
avid bb7 brakes
salsa cromo stem
geax saguaro tires
ergon enduro grips
Captain Bob
Cap. Bob - Could you tell a big difference between the carbon fork and the steel fork? Nice build, BTW.
