Results 1 to 20 of 20
    Reputation: ernesto_from_Wisconsin's Avatar
    L.A. Gear edition Cranks
    I heard L.A. Gear will make a limited edition 29er crankset.
    It will be 31/32/33
    You know, for kids
    Reputation: madcap's Avatar
    with red blinky LEDs built in??
    and...
    Quote Originally Posted by madcap
    quadruple multi colored crank bolts for this season's fashions.
    EPO
    EPO is offline
    Training in Mexico
    Reputation: EPO's Avatar
    Sep 2004
    36-24-36? Ha ha, only if she's 5'3"
    Quote Originally Posted by ernesto_from_Wisconsin
    It will be 31/32/33
    Reputation: Soupboy's Avatar
    Nice shout out to SMaL.
    Quote Originally Posted by EPO
    Do the LA Gear cranks come with a Biopace option? 29er bikes have larger dead spots in their pedal strokes...sure would help some.
    Professional Amateur
    Reputation: PeanutButterBreath's Avatar
    Useless.
    They should have made it 29/30/31.
    is buachail foighneach me
    Reputation: sean salach's Avatar
    any chance of getting it in a 3,4,5t version? if bottom bracket makers don't make something to accomodate that configuration, they are seriously behind the ball and missing out on unlimited sales to an obviously significant portion of the biking population. i've done calculamations n sh!t, so i know dis stuff fer real.
    its fo real n' fo shiznit!
    I'm from da streetz!
    These cranks will be available with 28mm offset for a bling'd out grill
    Low speed, High Drag
    Reputation: kevhogaz's Avatar
    I heard from a reliable source, that will be an online store, only accessible from a code within your crank set box, that has exclusive items for the purchaser of these fine crank sets.
    My source tells me to look for acid washed jeans, limited edition "29er" swatch watches, and L.A. Gear exclusive Vuarnet sunglasses, all within this members only (pun intended) store.
    I need a cool saying to put here.
    just ride
    Reputation: chequamagon's Avatar
    we should immediately establish a new standard dictated entirely from MTBR to tell the industry that we need special parts for 29ers, it will have a 6 arm 78mm bolt pattern for the proper ring sizes. Davidcopperfield can campaign the manufacturers to make it and we can have a poll to determine the proper tooth counts. And when it comes out, Mikesee can buy every single one to be the BIG man in charge, and then ernesto can make innuendos all day long about female body parts, neon pink cables and teflon coating on the new special 29er chainrings.
    Steel is Real: www.advocatecycles.com
    Tires for real rides: www.terrenetires.com
    and then mikesee can be banned for advertising that he has them, so that noone can access them.
    (was) Big in Japan
    Reputation: TheSingleGuy's Avatar
    and Rainman can tell us that they have sharp edges so we should be careful.
    Ride.
    (was) Big in Japan
    Edit: Why did this not post for an hour and then pop up twice?
    Edit x2: Should I have used a smilie?
    Ride.
    and then, during the beginning of next decade, this will all be a nice love sandwich with mayo
    I've been testing a prototype for a month now, and we have discovered it is NOT 29er compatible. Please move this post to another board.
    mcd
    mcd is offline
    uh, uh...oh, i forget
    you better lock this thread down before david copperfield reads it and begins to demand an in depth comparison of chainrings, with many new vids because we know you make, and will it work with new santa cruz all mountain fork he emailed santa cruz about
    disclaimer: i (NO LONGER) live with my mom...
    29er Geek
    Reputation: tozovr's Avatar
    You guys are going to LOVE my B.U.M. EQUIPMENT 29er only handlebars. teh hawtness!!!!
    unityhandbuilt
    What will the Q factor on these cranks be? Can I offset them 45mm to the non-drive side to accomodate how I like to "wear" myself within my chamois?
    Also, will they come in Kross Kolours and have threading opposite of standard?
    i'm hoping for a q-factor of zero.
    Reputation: grawbass's Avatar
    Quote Originally Posted by Soupboy
    Wanted: broken Titec 2 bolt seatpost, any size
